Question about Kenmore 75173 Stainless Steel Gas Kitchen Range
C to F
Power problems with storms going through may have caused this to happen. Oven reads in Centigrade not Fahrenheit any more. How do I change it back?
Hi i have a Kenmore gas stove and the oven has a problem. when I turn on the oven the electric ignitor works well and the gas starts with low pressure and after few seconds starts with the normal pressure.At that point it starts to turn on and off, over and over for awhile. It doesn't appear to be normal as it did not do that before. If you can please give me an answer I appreciate it.
Posted on Nov 22, 2008
22-7080419 WS. How do I change it from Centigrade to Fahrenheit, and to set the temperature?
I can not find that number on the Williams-Sonoma website . the only one that shows with dual temps has a button on the front to change the settings from centigrade to fahrenheit
Nov 26, 2015 | Williams-Sonoma OXO Digital Leave-In...
CAN'T SET OVEN HIGHER THAN 250DEG.F, DISPLAYED ERRO AND THEN START APPEARS. OVEN WILL COME ON, 250DEG. F MAX.
It sounds like you got the electronic oven control to expect temperature settings in Centigrade (Celsius) instead of Fahrenheit. Check your owner's manual to find out how to change it back to Fahrenheit.
Jan 26, 2015 | KitchenAid KGRT607 Gas Kitchen Range
Oven control won't let me raise temp. above 287, is there a way to reset control panel
Yes, you are in Centigrade (Celsius) mode. Check your owner's manual for instructions on how to switch between Centigrade and Fahrenheit.
Sep 09, 2014 | Kitchen Ranges
How to change from Celsius to Fahrenheit
To convert degrees C to degrees F, Multiply the Centigrade temperature by 9, then divide by 5, then add 32
Or, degrees F= (9/5 degrees C) + 32
Here's link to website which explains difference between Fahrenheit & Centigrade scales, & how to convert between them:
http://www.mathsisfun.com/temperature-conversion.html
Jul 11, 2014 | 1996 Buick Park Avenue
Write a computer program to change fahrenheit to centigrade
'Convert fahrenheit to centigrade
dim cent as int
cent = Val(Text1.Text) // Text1.text as your input
cent = cent - 32
cent = cent * 0.5556
Text1.Text = cent // Converted and changed the same textbox
Feb 21, 2014 | Microsoft Visual Basic 6.0 for PC
How do you change from Fahrenheit to centigrade
degrees centigrade; C = ( F - 32 ) x 0.56 F = degree fahrenheit
Jan 15, 2013 | Cars & Trucks
Can't change temp reading from centigrade to Fahrenheit on Howard Miller 645 697 weather sentinel
On the indoor panel...hold down the alert button until you hear 2 beeps and see up/down arrows displayed on front (bottom). Use the up/down buttons on the front until you get F instead of C. Push the alert button again so the up/down arrows disappear on the front panel.
Dec 28, 2012 | Measuring Tools & Sensors
How to change outside temperature guage from F to C
You can switch the temperature mode
between Fahrenheit to Centigrade as follows:
While pressing the OFF button, press the
AUTO button for 3 seconds or more.
The display will change from Fahrenheit
to Centigrade, or from Centigrade to
Fahrenheit.
Feb 04, 2011 | 2011 Hyundai Elantra Touring
My oven won't heat above 255 degrees. just curious what the problem might be.
You do not state if this is in centigrade or fahrenheit.
If it is centigrade, then it will not reach more than this if it is a domestic oven, if fahrenheit, then it should get hotter, so I would suspect a faulty oven thermostat as being the cause of the problem
Jan 05, 2011 | Ovens
Whirlpool oven flipped from Fahrenheit to Centigrade
You inadvertently changed the setting. Go to whirlpool.com and look up the manual and it will tell you how to change it back to F instead of C. I cannot see your reply due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Nov 27, 2008 | Kitchen Ranges
Kenmore 75173 Stainless Steel Gas Kitchen Range Logo
105 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
