Question about Gigabyte GA-7N400V-L Motherboard
Please help!!!!!!!!!!!!!!!!!! award bootblock bios v1.0 bios rom checksum error
  • rick00001 Aug 08, 2008
    my motherboard doesn't have any jumpers to flash bios?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 79 Answers
Check the manual , there is a jumper plug that allows you to move a jumper over to reset the bios to default , ie , the jumper makes a connection between two pins for 10 secds and then replace back to rest position..do this with the pc off and unplugged of corse,
Posted on Aug 08, 2008
One short beep one long beep continuous and power green led flashes continuos
I would say you have a failed memory (RAM) module. Probably a module in one of the secondary slots since the computer is able to POST and will attempt to boot.
Mar 20, 2012 | HEWLETT-PACKARD Computers & Internet
DISK BOOT FAILURE, INSERT SYSTEM DISK AND PRESS ENTER... i have a mother board K7S741MG-6L, bios version 426wp225, i have this problem BIOS CHECKSUM ERROR , KEYBOARD ERROR or NO KEYBOARD PRESENT (which is...
your hard disk is disconnecetedor loose . pls check the hard disk power cable & IDE or SATA cable. Then check BIOS hard disk detected or not if hard disk is not detected your hard disk is faulty.
Dec 11, 2009 | Foxconn WinFast K7S741MG Motherboard for...
BIOS ROM checksum error
sounds like your bios is corrupted, try going to the motherboard site and update your bios software. It could also be bad memory modules.
Nov 01, 2009 | HP Computers & Internet
Bios rom checksum error
Hai, That message dosn't sound like an error. i suspect the ram is faulty/incompatible and the pc won't boot because of it.
Change back to the old ram and reset the bios (jumber on the motherboard)
Aug 07, 2009 | Computers & Internet
When i boot the computer what comes on the screen is (''award bootblock bios v1.0'' copyright(2) 2000, award software, inc bios rom checksum error detecting floppy drive A media insert system disk and...
it means your boot sequence is first booting your floppy drive or your hard disk is not detected.i think you should check the cmos set-up.you can set it by pressing delete while the pc is booting.disable floppy drive seek.also the boot sequence.the os installed is maybe corrupted, is also one of the problem. refer to the manual if you have.
May 16, 2009 | Computers & Internet
BIOS CHECKSUM ERROR
Normally a bios checksum error is caused by a dead cmos battery. In a laptop that can be a pain - some are specialty batteries, some soldered directly to the motherboard, etc.
Start the laptop and enter the bois, there usually will be something to tell you what key to press, most of the time it is f2 or f10. Once in the bios set the date, time and boot order, then save and exit the bios. If it boots ok then try to determine what type of battery and it's location on the laptop to replace it.
If you let me know the make and model of laptop I will try to help determine that info and also where you can get the battery. That will more than likely be from eBay....
Hope this helps
May 02, 2009 | DFI CB61 Motherboard
Bios check sum error
You can try flashing/updating the BIOS if nothing works.
Nov 28, 2008 | Computers & Internet
Biostar P4M900-M7 SE BIOS ROM Checksum Error
The bios upgrade procedure stopped at half , leaving the bios corrupted. The computer now cannot do a regular boot procedure, this is the reason why it cannot recognise some device. If you are still able to boot from floppy, you can restart bios upgrade procedure from floppy. Just download floppy version upgrade and re do setup. Even if you do not find latest bios version, just download a floppy upgrade that is working, so that you can restart your machine regularly , and then do the update to latest version.
If you are not able to complete the bios setup, the only way to fix your motherboard will be flashing the CMOS chipset with a chip programmer device that will reinstall bios straight into cmos chipset.
You can have this done at the service point, in this case consider also replacing your motherboard.
Regards
Apr 03, 2008 | Biostar P4M890-M7 Motherboard
Gigabyte GA-7N400V-L Motherboard Logo
264 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Tony
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
