Question about KitchenAid Kitchen Ranges
One of the elements on our countertop stove Kitchenaid model# kecc502gbl3 has mulfunctioned! Stays on even when we turn the knob to the OFF position! Please advise on how to troubleshoot and if I can get instructions on how to replace the element or the switch/knob Thank you Tony
jsrock516
  • 5911 Answers
SOURCE: One element on my KitchenAid
Sure can. One element can easily be replaced. If your model number is correct, you can find replacement parts at searspartsdirect.com. Type in your model number in the Search menu and the surface elements can be found under the "Cooktop Parts" heading. I do not know which element you have that is bad, but they are identified as item 12 and by wattage rating. Use care when selecting to make sure you identify the correct element. The smaller elements have a lower wattage rating than the larger elements. There's also an illustrated view for easy part identification. Some parts come with directions on how to replace. If no instructions are available, or if you need further guidance, go to my profile page and click on "Tips and Tricks. I have a write up listed there on how to replace a glass cooktop. Those same instructions can be used to replace a single element. Instead of removing all the elements and cooktop, you will only have to remove and replace the one element. Just make sure you unplug the range before starting and handle the elements with extreme caution. They are considered fragile. It may also help to have a second person assist. I hope this answers some of your questions. If you need further assistance, please post back and let me know.
Posted on Apr 21, 2008
ranger25
  • 72 Answers
SOURCE: GE Oven bake element not work
It sounds like a problem with the selector switch. You have to remove the back panel to get to the back of the switch in the head unit, and find what wire goes from there to the bake element. With a meter set on 240ACV, or whichever setting is on yours that's HIGHER than that i.e. 400ACV, with the red probe on the terminal and the black one going to ground, see if you are getting 210-240 through it. If so, then it's either a faulty neutral wire connection (the other wire coming out of the element) or the selector switch. Hope this helps.
Posted on Jan 29, 2008
SOURCE: ge stove bottom element not working (top working)
The bottom element has probably "blown" out. See if there is a small spot that looks like it exploded. It is similar to an extension cord getting warm and melting in a spot. The only answer is to obtain a new element.
Posted on Dec 18, 2008
  • 1214 Answers
SOURCE: ELEMENT WONT SHUT OFF
Sounds like that specific element has shorted to ground inside it's sheath. You'll probably find the element does not get as hot as it normally would.
A fuse will not blow, or breaker not throw, because of the point in the element that the element has grounded.
Elements are available from a number of resources.
A way to test if the element is shorted to ground:
Tools needed -
Ohmeter
1)Disconnect power from the appliance
2) Remove the element (Sometimes they are plugged in, sometimes the wires screw onto the ends of the element.
3) Set the Ohmeter to Rx1000 or more.
4) Measure the resistance between the outside metal sheath, and either of the two power connection points on either end of the element. Under any condition, you should not get a reading. If you do, the element is bad, and you need to get a new one. They are not repairable.
5) Re-install in the reverse removed.
6) Check all connections are clean and all is re-assembled as you originally found it.
7) Turn on power and check if element comes on.
It is unlikely the problem is with the control, but it is a possibility. Give me more info about the cook-top (make, model) so I can investigate further.
Posted on Jan 14, 2009
SOURCE: stove top elements on high only
Yarsu Spiros
I like you purchased one of these thinking you can trust the name simpson(pope) but after putting on a fry pan with sum saucages in and having a major fire in my kitchen, I through the heap of junk out and bought a *** oven (current technologie) howerver to answer your question you have pulled the elements and trays out to kleen them (that seems normal) but you need to make sure the element terminals are clean and so are the spring clip things they fit into, use a peice of emery cloth (not wet & dry) this should fix it
alternativly not buy this junk again and get a proper stove
regards Graeme
Auckland NZ
Posted on Dec 12, 2009
Cooking element on stove top goes on full heat,even when dial is set on low.
Electric, I presume. Disconnect power to stove, open backsplash, remove knob, replace control unit.(usually universal type). Available appliance repair shop. Careful with 220volt power!!!!
Sep 20, 2014 | Kitchen Ranges
Element won't turn off
Bad control knob? Hard to say with out more info. To check if it is your control knob, you can unplug the stove, switch the wires from the nearest control with the one you are having problems with and then plug it back in. If you are now having the problem with a different element, then you can pretty much be certain its in the controls. Hope this helps.
Feb 06, 2013 | KitchenAid Kitchen Ranges
Kitchenaid electric stove burner stays on high
The dials you mentioned are called infinite switches and if they control, or regulate should i say the amount of power applied to the burner, so those are the parts you need to replace. You can order online or go to a local appliance parts store, just make sure you take your model number with you, not the number in your owners manual but the model off the machine itself.
May 08, 2012 | KitchenAid Kitchen Ranges
I bought a refurbished kitchenaid countertop toaster oven for a super great price and it works like a dream. The only problem is the broken timer knob. I've searched on the internet and I can't find a...
I would suggest calling Kitchenaid Customer Service. They would be able to replace that broken timer knob for you at no cost.
Their toll-free telephone number is 1-800-541-6390.
May 10, 2009 | KitchenAid Toaster Ovens
KitchenAid Proline Waffle Maker doesn't cool down when turned off
You should always unplug a waffle iron because other wise there is a constant direct current to the iron element which if left unattended could cause a fire damage and/or death, any heating element that you cannot break the current(unlike a stove) needs to be unplugged because of the danger and the juice it is also pulling from the power company that you are paying more money for. That goes for all heating elements irons,toasters,fryers,curling irons, even hair dryers **** juice. Let me know if this helps and GOD bless goofballlovers
Apr 23, 2009 | KitchenAid Pro Line¿ Waffle Baker
Tools needed -
Ohmeter
Jan 14, 2009 | KitchenAid 32 in. KECC502 Electric Cooktop
Kitchen Ranges Logo
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
