Power light keeps flashing on and off and there is no picture
  • 8,617 Answers
Whats the model number of your set? also how many times does the power indicator blink? Please respond to this same post when replying
Posted on Aug 08, 2008
Keeps switching inputs
WD82837: Mitsubishi 82" Rear Projection
Problem: The "status" light flashes yellow while no picture display. Nothing happens when pressing the power button. The light keeps flashing if plugged in. I cannot test for codes by holding for 5 seconds as there is no place to check the code problem due to no display. HELP!
Feb 07, 2014 | Mitsubishi WD-82837 82 in. HDTV DLP TV
The power light is just blinking red on my panasonic 1080i hdtv. cant even switch it off using the power button. picture and sound come on for about a second when the tv is switched on after power cord...
The power light keeps flashing and the tv won't turn on. If you unplug for a minute and hit the power button it sound like it is coming on then it shuts off and the red power light flashes slowly. The TV is a Panisonic 1080i HDTV, about 6-7 years old.
Jan 01, 2011 | Panasonic PT-53WX53 53" Rear Projection...
No picture, no sound. Turn power on, but the standby light keeps flashing 5 times.
alba 32in lcd no sound no picture stanby light flashing on / off.
Aug 20, 2010 | Televison & Video
The picture goes off, the power/standby light
Sony KDF-60XS955 picture goes and power/standby light light flashes
Most likely you have bulb failure. First step in troubleshooting is "Change the Lamp or Bulb". Lightning, power line bumps and collisions with vacuum cleaners can all shorten lamp life. Rough handling in shipment can also happen without your knowledge.
+90% of all Sony LCD Rear Projector "No Picture or Intermittent Picture" faults are related to bulb failure.
If new lamp does not improve the situation, then hands-on troubleshooting by someone that has parts and knows how the unit works is the only practical remedy.
easyab
Mar 14, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
No picture no sound opc light and power light
This is very common in sharp tvs.U turn it on.U get power on light stable right?U hear a click,one or twice,sometime tv is good right?Sometime POWER light and OPC light flashes?Push the power button on/off couples times will work, picture will come on.If keep trying off/on couples time after POWER and OPC flashes,don't ever stop and never get backlight and picture.Ur Video backlight board is dead must replaced.
Dec 28, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Green light keeps flashing but no picture appears.
Check Signal cable, and refresh rate, resolution in safe mode
Nov 09, 2009 | ViewSonic VA703B LCD Monitor
55" TV keeps shutting off automatically
Green light flashes 5 and then red light flashes 6
Sep 14, 2009 | Sony KDF-E55A20 55 in. LCD Television
No picture
(i) Disconnect all the cables from the TV including the power cable then reconnect them after a few minutes.
(ii) Make sure that the power cord from the TV is directly connected to a functional wall outlet.
If the standby light keeps flashing then service will be required.
Aug 24, 2009 | Sony KP-53V75 53" Rear Projection...
No Picture
the number of times the light flashes tells you which circuit has the problem. the self diagnoses codes are only in the tech service manual
Jul 02, 2007 | Panasonic TH-42PD25U/P 42 in. Plasma EDTV
Televison & Video Logo
42 people viewed this question
Top Televison & Video Experts
