Question about Minolta bizhub 200 Copier
Error when turning on machine.
We recently moved our copier and needed to unplug it to do so. It sat unplugged for a couple of days and hasn't worked since.
When turning on the copier, the screen shows "Please wait..." and then gives an error screen that reads:
!*! ABORT !*!
code = 0x00dc0652
tskname = tRT22601
tskid = 0x00005849
sp = 0x89f311e8
ra = 0x81224698
build_2591b. 060719
This screen shows for a few seconds, then the copier tries to start again by going to the "Please wait..." screen and then back to the error screen.
Any advice?
  • Minolta Master
  • 2,794 Answers
I have a feeling that this has something to do with software on the hard drive. Either the software needs to be restored on it or it could have crashed. A Konica/Minolta dealer in your area should be contacted to send a technician out to look at the situation.
Posted on Aug 13, 2008
Printer reads Error/Printhead cartridge jam. There is nothing jammed in the mechanism. Carriage does not move central when chamber opened.
It's certainly possible that the rails that the printhead runs on needs fresh lubrication or the position sensor has become dirty.
Lubricate the rails with very light oil, such as sewing-machine oil. Clean the positioning "tape" carefully, use glass cleaner, not solvents, as solvents can remove the positioning marks; careful, it's fragile.
Best way to lubricate the rails is to open the printer so the head travels to the center, and unplug from the wall while the head is centered. Now you can move the head by hand, and see how hard it is to move it.
Sep 24, 2014 | Kodak ESP Office 6150 All-in-One Printer
Hi, I have a Samsung WDJ1255C Washer Dryer. I recently moved and had the machine unplugged for about a week. I turned it back on today and it's giving me an E13 error message. Can you please help?! Ghana...
unplug for 5 minutes or switch off the breaker switch for five minutes. if the five minute reset doesn't restore the machine your MCB could be stuffed
Nov 11, 2013 | Washing Machines
For a couple a weeks my mp3 hasn't been turning
Hi!
Sometimes system reset helps.
Please check the "Troubleshooting" part of the manual.
Hope it will help!
https://manualsbrain.com/en/manuals/1023629/?page=51
Sep 04, 2017 | Samsung YP-U2JZW MP3 Player
Just got a new HP Designjet T770 hard disk printer, keep getting error code 21.1:03, turned power off and unplugged, still receiving same error code
Issue with the service station. Turn off and turn on your printer couple of times. Try moving the carriage assy., manually.
Still if it don't work then the service station would have gone bad. Needs to be replaced.
May 24, 2011 | HP Designjet T610 InkJet Printer
I have recently changed the cyan printhead/cleaner on inkjet 1050C but after a couple of weeks the message change printhead appears. I have to manually override by choosing to continue printing for each...
Hello sir; Let's try to do a resetting . turn on the power, open the cover let carrier move to the center.then UNPLUG the power cord, teun power switch off, remove all the cartridge out and reinstall cartridge back, plug in the power cord,close the cover and then turn on the machine.
Nov 06, 2009 | Office Equipment & Supplies
We recently moved from one part of the city to the other so the dryer was unplugged for a few days and sat in a garage today we set the dryer up and turned it on again and now it gives off a really foul...
Ok, this can be alot of things. What I would do is take the rear vent off and check inside to make sure an animal did not get in it and die. This would be the most likely cause as you said it sat in a garage for a few days. I would re-wash any clothes that were dried in it to be safe. Hope this helps.
Sep 30, 2009 | Dryers
I got a E1 appears on my york 60100 and it's not working at all
the E1 error with yorks typically means that the speed sensor isnt communication correctly with the computer. Here is the series to try and get things communicating again. Turn off and on a couple times. No luck... Turn off and use your feet to rotate the running mat once around. Turn back on. No luck... Turn off and unplug. Check all wires to make sure nothing is unplugged inside or on the machine other than the main power plug. I would also just for good measure unplug and plug all wires I can easily reach and do so with. Once everything is buttoned safely back up plug the machine back in and turn on.
Jun 01, 2009 | York Yankees Bedding MLB Comforter
PRINTER ERROR-CHECK CARTRIDGE
Unplug the power cord. Try to move the cartridge to the right by hand.
Oct 03, 2008 | Sharp INKJET FAX UX-A1000
How to correct error message sram error missing E?
Hate to say this but most likely the Print Engine Control Board has failed.
May 09, 2007 | Xerox Phaser 7300DN Laser Printer
Minolta bizhub 200 Copier Logo
515 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
