When I come to load new hardware to my computer it says I dont have sufficient usb access (or in so many words). I have the 'root hub' and 'host controller' so i dont know what the problem is!! please help!
  • clairelou402 Aug 08, 2008
    how do I solve the problem? when i go to my computers 'properties' and click on 'device manager' it shows 5 universal host controllers (to different numbers) and 5 root hubs, do i need all of them?
    Problem Solver:
  • 18 Answers
Some usb hubs don't handle enough power to maintain all the items. I'm not possitive if this is your problem but it sounds like a similiar problem I had in my office and that was the problem.
Posted on Aug 08, 2008
SOURCE:
How to enable usb port LG 22LD330
On the desktop, right click on MY COMPUTER, and then select MANAGE option. a new window will appear, in that select SYSTEM TOOLS, in that click on DEVICE MANAGER, on the right side of the window pane, a list wil appear,
If USB is enabled in BIOS or EFI but the USB host controller does not appear in Device Manager (under Universal Serial Bus controllers), or a yellow warning icon appears next to the host controller name, then the version of BIOS or EFI may be outdated. Contact the maker or vendor for your computer and obtain the current version of BIOS or EFI.
If the controller appears in Device Manager, right-click the controller name and then click Properties. Problems and suggested actions are displayed under Device status.
USB ports have a separate entry in Device Manager. To check the device status, click Universal Serial Bus controllers, right-click USB Root Hub, and then click Properties. If you do not see USB Root Hub, you might not have a USB port installed on your computer
On the USB Root hub Properties page, it may tell you this device is working properly, or there is a Troubleshoot button. At the bottom you have an option to Enable or Disable the USB hub.
Jan 22, 2014 | LG Computers & Internet
Why the windows7 cannot recognize the usb cable device of psvita
w7
First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically.
Oct 07, 2012 | Microsoft Windows 7 Home Premium 64BIT...
COMPAL EAL51 barebone
Here you go:
1394
VIA OHCI Compliant IEEE 1394 Host Controller
BATTERY
Microsoft AC Adapter
Microsoft ACPI-Compliant Control Method Battery
COMPUTER
ACPI Uniprocessor PC
Diskdrive
Universal HDD
DISPLAY
Mobile Intel (R) 915GM/GMS, 910GML Express Chipset Family
HDC
Primary IDE Channel
Secondary IDE Channel
Intel (R) 82801FB/FBM Ultra ATA Storage Controllers - 266F
INFRARED
SMC IRCC - Fast Infrared Port
KEYBOARD
Keyboard 101/102 keys Microsoft Natural PS / 2 Keyboard
MEDIA
Audio codecs
Video Codecs
Midi Control devices
Legacy Video Capture Devices
Legacy audio drivers
Microsoft Kernel System Audio Device
WDM Audio Compatibility Driver Microsoft WinMM
Realtek AC'97 Audio
MOUSE
PS / 2 mouse
NET
1394 Adapter
Remote network engine Miniport (IP)
WAN Miniport (PPPOE)
Parallel Direct
IR
Realtek RTL8139 Family PCI Fast Ethernet NIC
WAN Miniport (L2TP)
WAN Miniport (PPTP)
OTHER DEVICES
PCI Modem
PCMCIA
Generic CardBus Controller
PROCESSOR
Intel Processor
SDHOST
SDA Standard Compliant SD Host Controller
SYSTEM
Generic Bus
Button ACPI resource sixed
Button tie / Untie ACPI
The system CMOS / real-time clock
Direct access memory controller
Programmable Interrupt Controller
Microcode update device
Microsoft System Management BIOS Driver
Software Device Enumerator Plug and Play
Logical Disk Manager
Manager volumes
Intel (R) 82801FB/FBM SMBus Controller - 266A
Intel (R) 82801FBM LPC Interface Controller - 2641
Intel (R) 82801 PCI Bridge - 2448
Microsoft ACPI-Compliant Embedded Controller
Microsoft ACPI-Compliant System
Microsoft Composite Battery
PCI bus
PCI standard host CPU bridge
ISAPNP port
Terminal Server Device Redirector
ACPI
Terminal Server Keyboard Driver
Terminal Server Mouse Driver
System Timer
UNKNOWN
PCI FLASH memory
USB
Intel (R) 82801FB/FBM USB2 Enhanced Host Controller - 265C
Intel (R) 82801FB/FBM USB Universal Host Controller - 2658
Intel (R) 82801FB/FBM USB Universal Host Controller - 2659
Intel (R) 82801FB/FBM USB Universal Host Controller - 265A
Intel (R) 82801FB/FBM USB Universal Host Controller - 265B
USB Root Hub
USB Root Hub
USB Root Hub
USB Root Hub
USB Root Hub
VOLUME
Generic volume
Jun 19, 2012 | Computers & Internet
I an not have driver usb for hdd2193 for fix problem
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports(com&lpt)right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
if you dont have a motherboard disk you will need to download the drivers
http://download.cnet.com/usb2-0-driver-zip/3000-18493_4-163914.html
Intel PCI to USB Enhanced Host Controller NEC PCI to USB Enhanced Host Controller B0 NEC PCI to USB Enhanced Host Controller B1 USB 2.0 Root Hub Generic USB Hub VIA PCI to USB Enhanced Host Controller
http://download.cnet.com/usb-2-0-root/3000-18493_4-55793.html
http://download.cnet.com/usb-mass-storage-controller/3000-18493_4-161651.html USB Mass Storage Controller
hope this helps you
Sep 11, 2011 | Toshiba MK4026GAX (hdd2193) 40 GB Hard...
My Panasonic CF-74 doesn't seem to be detecting anything I am plugging into the USB ports or the COM port.
Some motherboard BIOS's allow you to specify how many USB ports you want enabled
go to your Control Panel, System, Device Manager.
go down to where it says Universal Serial Bus Controllers, click the + sign,
you will see a list of devices, probably something like this
via rev5 usb host controller
usb printing support
usb mass storage controller
usb root hub
usb root hub
right click on the ones that say via or intel or SIS, or ALI, or Standard open host controller, and choose uninstall.
you will be asked if your sure, and you will see some of the USB root hubs disappear.
If you are asked to restart, choose no, and remove the other via/sis/intel/etc open host controller (s) from your system, when they have all been removed restart your computer.
when the computer restarts, it will detect the USB controller and connected devices, reinstall the drivers/software
Jun 24, 2009 | Panasonic Toughbook 74 PC Notebook
7950 gx2 cant enable sli mood (single card)
Disable plug & play from BIOS. Now re-install the game and the required driver. From Control Panel--systems--Device Manager, check the properties of the Graphics card drivers and check if there is any clash of resources, if so then allot it manually. Hope this works....sodeep
Mar 30, 2009 | Gigabyte GV-3D1-7950-RH GeForce® 7950 GX2,...
Usb ports not working
  1. Checking USB device status in Device Manager
  1. Right-click My Computer on the Windows desktop and then click Properties.
  2. Click the Device Manager tab to display the Device Manager window as shown at the right. (For Windows 2000 systems, click the Hardware tab and then the Device Manager button.
  3. In the Device Manager list, click the + sign next to Universal serial bus controller.
  4. Verify that a USB host controller and a USB root hub are listed below Universal serial bus. image002.jpg
  5. If Universal serial bus controller, USB host controller or USB root hub are not listed, close the Device Manager and go to USB port incorrectly configured in BIOS
  6. If Universal serial bus controller, USB host controller and USB root hub are listed but one or more display a yellow exclamation point, go to USB controller IRQ conflict
  7. If you have Windows XP, right-click the Host Controller and select Properties from the drop-down menu. If you see this status message in the Properties window: The drivers for this device are not installed (code 28), go to Windows XP USB 2.0 driver not installed .
  8. If Universal serial bus controller, USB host controller and USB root hub are listed but one or more display a red X, go to USB controller or root hub disabled in Windows Device Manager.
USB port incorrectly configured in BIOS NOTE: The procedure in this section is intended for advanced users only. Incorrect BIOS settings could prevent your computer from starting or operating normally. If you are not experienced in making changes to your computer BIOS, consult your computer instructions or contact your computer manufacturer for assistance before attempting the steps below.
  1. Follow the instructions of your computer to view the BIOS settings. These settings are sometimes called CMOS settings or system setup.
  2. To view the BIOS settings, press a key, such as F2 or Delete, just after you turn on the computer. Instructions often appear on the screen briefly when you turn on the computer. Also check the instructions and manuals provided with your computer.
  3. Look for USB Interface or a similar setting in the Advanced Setup, Peripheral Configuration or another section of your computer BIOS settings.
  4. Follow the onscreen instructions or read the computer documentation to enable the USB port.
  5. Follow the onscreen instructions to save the new settings and restart the computer.
  1. USB controller or root hub disabled in Windows Device Manager
  2. Click the Device Manager tab. (On Windows 2000 and XP systems, click the Hardware tab and then the Device Manager button.)
  4. Click the line in the Device Manager containing the red X.
  5. Click the Properties button. (On Windows 2000 and XP systems, click Properties on the Action menu.)
  6. In the Communications Port Properties box, click the Resources tab.
  7. Re-enable the USB device by clicking the Enable Device button and follow the onscreen instructions.
Dec 28, 2008 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
Mercury MOTHERBOARD KOB P4M266 NDFSMX
I AM NOT HAVING MOTHER BOARD CD TO INSTALL HIS DREVERS AND HOW TO DOWNLOAD HIS DRVIERS BY INTERNET
Mar 04, 2008 | Mercury KVM266PM-U (KVM266PMUD1600)...
USB Ports
one way would be to download and install latest device drivers from the net. it should help.. if you are using win XP, there is likely a BIOS or Windows configuration problem. On some computers there is a configuration option in the BIOS that asks whether an IRQ should be assigned to USB. Although the option's actual wording varies among BIOS manufacturers, you must enable this option by setting it to either On or Yes (depending on your BIOS manufacturer and BIOS version). Otherwise no USB devices will work on XP. A problem with Windows XP’s USB Controller configuration can also prevent any USB devices from working. To determine whether the USB controllers are working properly, open Device Manager and expand the Universal Serial Bus Controllers node. Beneath this node, you should see a USB Universal Host Controller and a USB Root Hub. Depending on your PC, there will either be a USB Universal Host Controller and a USB Root Hub listed for each of your computer’s USB ports or a USB Universal Host Controller and USB Root Hub for multiple ports
Jan 20, 2008 | Gateway GT5432 Refurbished AMD Desktop...
Critical error 678
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?lc=en&cc=us&docname=bpia2302
http://support.microsoft.com/default.aspx?scid=289706
1) make sure you have the latest active sync installed
C:\Program Files\Microsoft ActiveSync\drivers
or
c:\windows\system32\drivers....with activesync 3.7 anyways.
2) go to contro panel -> system -> device manager -> view device b
connection -> plug and play bios -> pci bus -> usb host controller -usb root hub
3)delete everything uner usb root hub.
4)from control panel run add new hardware
5)now everything under your computer's usb hub including the cradl
will be installed properly.
6)once this installation is performed, you will make sure to see "H
USB Sync 1620" under USB root hub
Jan 17, 2008 | NEC MobilePro 900 Handheld
Open Questions:
Computers & Internet Logo
20 people viewed this question
Ekse
Alun Cox
