Question about Samsung 4 Channel Dvr
Shr-1040, password fail
How can I get into the system if the password is failing?
Thank you
  • cmcinvegas Sep 06, 2008
    I have tried to reset pass code and it will not. Mode + ch2 for ten seconds. Any sugestions
  • Anonymous Feb 17, 2009
    I have a samsung 16 channel dvr and it will not accept my password. How do I reset password. No "mode" button.
Mode key + ch2 hold down 10 seconds factory reset password to 4321
Posted on Aug 15, 2008
I had the very same problem and after sitting there going through various combination of 4 digits. All I did was just moved the cursor down to the 'OK' button and pressed enter and got me right in.
Mike
Posted on Feb 08, 2009
3 Suggested Answers
marked
  • 6487 Answers
SOURCE: shr-1040 password fail
Did you try typing the default password 4321?
Hope that helps.....
Posted on Jul 20, 2008
password fail
Shr-1040 password fail
Jul 20, 2008 | Samsung 4 Channel Dvr
I forgot my password and I cannot do anything. What is the solution? SHR-1040 DVR security system.
Factory Reset Hidden Key :Mode Key + CH 2
The Password and all setting value will return to the initial default value.
Default Password is ‘4321’., Refer to 6-10p, 6-12p of User manual
I hope this helps.
Jul 09, 2009 | Samsung SHR-2042 4 Channel Stand Alone Dvr...
Samsung shr-1040
most likely you have a bad board. try resetting the unit if this works great if not then you will have to send it in to be repaired.
•Factory Reset Hidden Key :
Mode Key + CH 2
•The Password and all setting
default value.
•Default Password is ‘4321’ .
mj
Apr 28, 2009 | Samsung 4 Channel Dvr
I changed the passwors of samsung shr-1040
Mode Key + CH 2
default value.
mj
Apr 08, 2009 | Samsung 4 Channel Dvr
Samsung shr 1040 4 channel dvr
You have to hook it up to a tv monitor and change the settings through the menu. It will originally include a password just to get you on, then you will immediately have to change it. After you do that you can access the menu where you can change the output settings
Apr 05, 2009 | Samsung Home Security
I have a samsung home security shr-1040 and i tried to change my password and i must have put a different 4 digit code than i meant, i am now locked out and cannot access my settings.....please help
The manual says:
You cannot enter MENU by forgotten password.
- If you forget the password, you shall reset SHR-2160/2162/2080/2082 DVR to
the values set at the factory. Keep pressing both the "MODE" button and the
"PTZ" button on the left for 5 seconds, Keep pressing both the "MODE" button
and the "PTZ" button on the left for 5 seconds. The password default is "4321".
You can download the user manual here:
http://samsungsecurity.com/product/p_detail.asp?seq=94&sel_seq=64
Dec 25, 2008 | Samsung SHR-2082 8 Channel Stand Alone Dvr...
Samsung shr 1040
try resetting the system and reprogramming.
if that does not work you may need to have it repaired.
Mode Key + CH 2
default value.
mj
Sep 18, 2008 | Samsung SHR-2042 4 Channel Stand Alone Dvr...
Connecting the recorder to the security system
If you are hooking your cameras into the SMO-151qn then you can use the pigtail cable to connect to the Shr-1040. Make sure the video out from the SMO-151qn goes into the video in of the Shr-1040. If there is a choice use CH1. On the Shr-1040 hold down the mode button and press CH2 for about 10 seconds. The Shr-1040 should reboot. Once it comes up press the record button. After recording for a feww minutes stop the recording. On the SMO-151qn press the button on the front Live/Vcr. You should see the screen from your Shr-1040. IF you hit play you should see what you recorded. Good Luck!
Jun 11, 2007 | Samsung SHR-2082 8 Channel Stand Alone Dvr...
Samsung 4 Channel Dvr Logo
672 people viewed this question
Top Samsung Home Security Experts
Gary Banta
Level 1 Expert
Cesar Quant
Cesar Quant
Are you a Samsung Home Security Expert? Answer questions, earn points and help others
