Question about Roland Spd-S Sampling Percussion Pad System
Roland Spd-s pad #1 change to different patches when hit
I received my used roland spds and whenever you strike pad #1 it changes the patch to a different patch every time u strike it, How can i fix this problem? PLEASE HELP!!
  • jonotis_blub Aug 23, 2008
    patch changes when certain pads are hit.
    how to enable/disable.
I'm an experienced SPD-S user and there is no option that allows the SPD-S to produce random sounds from the same PAD.
I can think of 3 reasons why this may be:
  1. In patch mode, a PAD can be assigned with 2 different sounds (wave A & wave B). Wave A will be produced on soft hits while wave B will be produced on hard strokes. To ensure only 1 sound is produced by a specific PAD, make sure no sound is selected in wave B (only wave A will be produced regardless on the force of the stroke).
  2. Your PAD has a very strong and moving effect turned on (such as a phaser or a filter) that makes your wave to sound different between hits. Turn off the effect (press on the Effect button until the light is off) then hit the pad again to see if it fixes your problem.
  3. If none of the previous 2 solution fixes your prublem then your SPD-S is probably malfunctionning.
Posted on Mar 23, 2009
    Problem Solver:
  • 8 Answers
Look here:
He wanted it to do this, but of course you can set it up to NOT doing it!
http://www.fixya.com/support/t1498739-boss_fs_5u_pedal_get_change_patches
Best regards,
Posted on Jan 16, 2009
I think there is an option in the setup menu that makes the pad do this.... i remember reading it in the manual. sorry cant help more than that...
Posted on Jan 04, 2009
How to recover files from a crashed Compact Flash on my Roland SPD-S?
It's possible your CF card is full.
1. Connect the card to your computer as you have done. 2. Copy the files off it and save same them to a folder on your desktop.3. Right click only the Flash drive and navigate to "Properties" or "Get Info" if your a mac user.4. Take not of the file system it is currently using.5. Re-format the card with the same file system using your computer.6. Replace the card into your Roland SPD-S and Re-format using these steps: a. Select patch mode or wave mode. b. Press {SHIFT} and {SETUP} (CARD UTIL) c. Press the PAGE buttons to select "CARD FORMAT" then press {ENTER} d. A"[>] to format." indication appears. Press [>] e. A "format, sure?" indication is displayed. Press {ENTER} to start formatting.
7. Once formatted you can replace the card in your computers card reader and copy the files you backed up earlier onto it.8. Re-place the CF card in your Roland and it should work. If not then you may have a irreparable CF Card.
Oct 26, 2012 | Roland Spd-S Sampling Percussion Pad...
Editing Problems
You have Pad Chase turned off. Turn it back on.
Mar 11, 2012 | Roland Spd-S Sampling Percussion Pad...
The display just showing(welcome to spds) nothing else. please help
I had the same problem after trying to do the update for the flash card (v1.20). I'm taking it back to the store now. I tell you what they tell me...
Aug 09, 2010 | Roland Spd-S Sampling Percussion Pad...
How to remove wave protect in spds
Use the following procedure to turn off wave protect:
1. Power on while holding SETUP and WAVE ("Welcome to SPD-S", followed by "wave protect off" will show momentarily in the display).
Note: Repeat the procedure to turn wave protect back on.
Apr 17, 2010 | Roland Spd-S Sampling Percussion Pad...
Roland Spd-s pads not working
Check for a cracked PCB internally from the two defective pads, or if the wires have detached from the trigger. You may not need parts, but if you do, it really depends on how helpful the Roland distributor in your area is as to whether you will have any luck getting them, or you may have to go trough a local authorized repair shop.
Good luck.
Dec 01, 2009 | Roland Spd-S Sampling Percussion Pad...
Boss FS-5U Pedal - How can I get it to change patches?
Try the follwing:
press <SYSTEM>
press <PAGE+> until CONTROL SW is shown.
press <ENTER>
Parameter: CtrlSW
press your FootSwitch (FS-5U) so the indicator-LED on your SPD-S for the footswitch is lit (or hold down <SHIFT> while pressing <PAGE> until footSW is lit)
Change the value of CtrlSW by pressing <+> / <-> until PATCH+ is shown on the display.
.. this should solve your problem.
By the way:
if you go to: ftp://ftp.roland.co.uk/productsupport/Manuals/
you will find the manual of the SPD-S for download.
On page 79 is the description for your request.
Best regards,
Jan 06, 2009 | Roland Spd-S Sampling Percussion Pad...
Roland SPD-S Flash card error
The card I have always been using is now also suddenly giving this message. I found an old SanDisk 16MB and a 1GB SanDisk that works perfectly in my Boss 864 and they also give the same message. Trying to go into formatting brings the message "no card!"
May 13, 2008 | Roland Spd-S Sampling Percussion Pad...
Roland Spd-S Sampling Percussion Pad System Logo
783 people viewed this question
Top Roland Audio Players & Recorders Experts
Electric Dime
Electric Dime
Greg Cann
Greg Cann
Vito Vacirca Jr.
Are you a Roland Audio Player and Recorder Expert? Answer questions, earn points and help others
