Question about HP PSC 1610 All-In-One InkJet Printer
Printer does not boot
When psc 1610 starts the light comes on and goes thru a checkand stops in between with no noise
    Novelist:
    Scholar:
  • 111 Answers
I searched through HP.com but didn't find any information that addressed your problem. You might want to try unplugging all of the cables, then plugging everything back in, making sure each cable connection is securely and firmly pressed in. Your problem could be caused by a loose power cable or even a loose connection between the computer and printer.
If that doesn't work, you probably have a hardware related problem somewhere in the printer and it will require professional service to resolve.
Sorry...that's the best I can do under the circumstances. Good luck.
Posted on Oct 14, 2008
WHY DOES MY HP PSC 1610 MAKES A CLICKING/CLANKING SOUND WHEN STARTING TO PRINT STILL PRINTS
I think your printer required maintenance, because printer time all parts working then your printer print. I gas you some points link printer belt, printer header, printer roller..so any one damage or this types of issue create, so i suggest you contact HP printer technician and check it.
Thanks,
HP Printer Support
May 18, 2014 | HP PSC 1610 All-In-One InkJet Printer
The hp psc 1610 will not turn on the status bar goes about two thrids of the way and stops,The green loght will not come on
Nov 09, 2010 | HP PSC 1610 All-In-One Printer, Scanner...
Paper starts half way thru printer & stops. have tried different types ofpaper to no avail
Shut down and remove the motor from drive , then manually thread a paper to see the movement. if the paper moves OK then reset and check the paper in detect of the printer.
Now connect and check if thepaper stops after loading, remove printer and uninstall, teh reinstall, connecct printer back and run.
make a test , if not there is error in the main board.
Sep 24, 2010 | HP PSC 1610 All-In-One InkJet Printer
My printer started making loud clanking noises immediately before printing the document. The document prints fine, but that loud noise sounds like a machine gun. After manually moving the carridge to the...
jim@bigdork.net
Thanks fixya.com
You helped me CLEAN the HP PSC 1610
it had MASIVE amounts of waisted ink
in the area that it WANTS to waste ink
to keep the cartridges FLOWING...
BUT... NOW ... HERE IS A SOLUTION TO
THE CLICKING NOISE
THE RATCHIT NOISE
HP PSC 1610 NOISE
It seems that HP (as with most all manufacturers)
has DESIGNED-IN A PART THAT WILL BREAK ! ! !
PICTURE ATTACHED
explanation...
opened the mid section of the printer
moved the ink holder module to the far left
pushed the cleaning tray
(it moves to you and away from you)
away towards the rear of the machine
used masive amounts of isopropyl alcohol
and an old toothbrush
to clean most of the gunk ink buld-up
(started with q-tips but it was not enough)
After cleaning ... the machine worked again...
BUT
that noise was still there
after carefull inspection
I saw the problem
there was a hairline crack in a small plastic part
above a rotating gear
when the carriage came to the right
it was suposed to move that part
off or away from the gear
but because it was cracked
it did not move properly
SOLUTION
crazy glue or super glue
and shim to hold in place while drying
(maby heat with a light bulb while drying)
SEE ATTACHED PHOTO WITH NOTES....
May 19, 2010 | HP PSC 1610 All-In-One InkJet Printer
Help hp psc 1610 all in one printer carraige jam
Try this website:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00107909&cc=us&lc=en&dlc=en&product=79477
Nov 26, 2009 | HP PSC 1610 All-In-One InkJet Printer
HP 1610 All In One noise
since your printer is 3 yrs old ..just give it for a service and ensure its catridges and other part are dust free
Jun 30, 2009 | HP PSC 1610 All-In-One InkJet Printer
Hp psc 1610 all in one printer wont print
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 26, 2009 | HP PSC 1610 All-In-One InkJet Printer
Making a loud noise when the paper is feeding.
This is what the HP website says about noises in the 1610..
Issue Unexpected noise (clicking, thumping, grinding, squealing, and so forth) from an HP all-in-one can be caused by a problem with the ink carriage or the scanner. Solution Follow the steps below in the order presented to determine the source and resolution for the noise. Step one: Checking the scanner This step applies only to products equipped with a flatbed scanner.
  1. Open the scanner cover.
  2. With the lid open, press the Start Copy button to make a copy. The scanner mechanism should move down the glass.
  3. If the scanner mechanism does not move and noise is present, contact HP. If the scanner mechanism moves without noise, continue with Step two below.
Step two: Checking for paper feed problems and carriage blocks Click here (buu03110) (in English) for more information on paper or carriage jams. Step three: Service the product If you have completed all the steps listed above and are still experiencing a problem, service the product. So it sounds like it needs to be serviced which could get expensive. I've looked all over the web for you & Keep finding the same answer. Sorry I can't come up with a better solution for you.
Nov 29, 2008 | HP PSC 1610 All-In-One InkJet Printer
HP PSC 1610 "clunks when starting print job"
There are a number of potential causes and solutions to this sort of issue. They all seem to be hardware related, but HP.com has a web page with links to solutions that may apply to your situation:
Unexpected Noises when Printing
Hope this helps. Good luck.
Aug 06, 2008 | HP PSC 1610 All-In-One InkJet Printer
HP PSC 1610 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
