Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
Transmission/clutch clutch is stiff and when i put it in gear it wont roll when i accelerate. but i can push it
    Genius:
  • 2,028 Answers
It would be extremely helpful if I had the year and model, the clutches differ through the years and models, but I'll give it a go. There are going to be a couple of thing that can cause this. You will need to yank the primary to get to the clutch.
1- the ramp that works the push-rod clutch release is bad or the push-rod has punched through it. On the Sportsters this is a different type of mechanism and is located all on the primary side with the clutch. It will be easy to see if there is a problem with it. On the big twins the ramp is located on the tranny side, so you will have to remove the tranny cover to inspect the ramp and bearings. You can remove the push-rod through the center of the clutch hub, by removing the c-clip that hold the center adjustment for the clutch release. Inspect the push-rod for discoloration due to overheating on the ramp end or bad wear on either end due to being overtightened.
2- the clutch is gone, frictions are the main thing that go, but don't rule out having to replace the steels until you get it apart.To remove the clutch assembly, you will need to remove the primary chain. To do this you will need to slide the crank hub and the clutch assembly off at the same time, the chain will not allow you to slide one off with out the other, if it does then your primary chain has stretched and needs replaced. *IMPORTANT NOTE* The nut holding the clutch assembly is reverse thread, so do remember this when removing, otherwise you can damage or break the tranny shaft. Once you get the clutch assembly off, there is a special depression tool for getting the clutch plates out of the clutch hub. The hub is aluminum, so if you don't use the tool you can break an ear off and will have to get a new hub.
I know this sounds difficult, and it will be if it's you're first time, but don't let it scare you off of doing it yourself. I'm a firm believer in working on your own bike, I also believe HD is over priced (used to work for a dealership), along with most other shops. Working on your own bike is a tradition that most riders today have gotten away from. If you haven't worked on your own bikes before, start, you'll find that it gets easier with time, it's not that hard, and you'll enjoy having that sense of accomplishment. If you need anything else feel free to ask, and let me know what you find.
Posted on Aug 08, 2008
1998 Honda Civic manual trans will not shift into gears. Car starts, push in clutch and it goes to the floor, release clutch and comes back up. Unable to put into gears. Brake fluid and clutch fluid seem...
Eric, how are you confirming whether or not the car goes into gear if you shift gears without the engine running? One way would be to put it in 1st and see if you can push the car. If you can't, it is in gear.
Another option is to roll the car slightly forward or backward (engine off) while trying to put the car in gear. Once it is in gear, then the car shouldn't move any further. However, if it goes into gear, DO NOT start the car without taking it back out of gear.
The clutch is much more likely to be the problem than the transmission.
If the clutch fluid ever ran dry, then the clutch hydraulics will need to be bled of air. Otherwise, the problem could be the clutch master cylinder, slave cylinder or throwout bearing. Since you didn't report the clutch slipping (e.g. engine revving without accelerating when in gear) it is likely not the clutch disks themselves.
Jun 11, 2014 | Cars & Trucks
94 ford ranger manual transmission goes into first gear and reverse just fine let off the clutch and the truck wont move.
part of a clutch job is removing the gearlever make sure the lever is secured properly and selects the gear correctly.
Orherwise your symptoms sound like a collapsed pressure plate or broken release bearing either defective part or something done wrong during installation of clutch
Apr 13, 2017 | Cars & Trucks
My gear selector is really loose
iF YOUR CLUTCH IS WORN IT WILL NOT GO IN TO GEAR CAUSE THE TRANSMISSION IS STILL SPINNING SIDE. ALL-WAIST MAKE SURE CLUTCH IS WORKING . ENGINE OFF 1ST GEAR CLUTCH PRESS IN TRUCK SHOULD ROLL.(HELPING HAND WITH A LIGHT PUSH) IF IT DOES NOT ROLL OR HARD TO ROLL COMPARE TO NUTRAL DO THE CLUTCH. IF IT ROLLS OK INTERNAL PROBLEM WITH TRANS
Jan 19, 2013 | Chevrolet Cars & Trucks
1995 eagle talon manual transmission i'm able to put my clutch down and shift gears, but car wont accelerate
Something is broken, that is for sure, pull the transmission out and first look at the clutch plate.
Jul 08, 2012 | 1995 Eagle Talon
Bike surges at all speeds, not sure if its a fuel issus or a clutch issue
Surging is usually a fuel problem. To prove it, put the bike in one gear lower than the top gear. You didn't say what year or model bike you have. If it's a five speed, put the transmission in fourth gear. Do a full throttle roll-on acceleration with the transmission in that gear on a long uphill grade. If the engine RPM's climbs suddenly and drastically without the speed of the bike doing the same, it's a clutch slipping problem. More than likely, you are feeling the surge due to a lean fuel air mixture. This makes it very difficult to maintain a steady cruising speed in all gears.
Good Luck
Steve
Sep 13, 2011 | Harley Davidson FLHR-FLHRI Road king...
My wifes 2.4L PT Cruiser broke down today on the way up a large incline. She says as she drove in 5th gear with the gas consistlently down the clutch seemed to go out as it felt like she had dropped into...
Unfortunately, and I don't like saying this in the least, the problem is going to be the transmission leading to other issues. Your going to have to have the transmission repaired.
Sep 05, 2011 | 2002 Chrysler PT Cruiser
My1989 fordf150 runs but it wont go into gear
If your F150 is standard shift, don't try to put first gear with the motor running, you might brake some gears in the transmission. Probably you have a worn out clutch disk. To diagnose this you could try to put your truck in first gear with your motor off, push the clutch and start it, CAUTION, if the cluthc is not working your truck will go foward. Don't be afraid, try doing this on an open space or road with little traffic. Then you you feel you got to change to second gear, get your foot off the gas and inmediatelly shift to second gear having in mind not to force the stick if it sound, feel the stick until it goes easily to second gear. If you accelerate and the truck does not slips and has power accelerating, the disk is working fine, but if you feel it slipping and your revolutions go up but the truck stays more or less in the same place, you have a default clutch disk.
No if yoou feel no pressure on the pedal, this is the pressure plate has no strength, this is a default pressure plate. If you feel the clutch strong but when you push it it sounds like a broken bearing, this is the pressure plate bearing that is bad.
Ok, to change this you must lower your transmission, then take the clutch assembly from the motor. It is good to have a center shaft to re-install the clutch. After you remove the transmission, you take out the clutch case. Here it is recommended to check the rear clutch seal to avoid future ooil leaks. Then remove the pressure plate with the bearing and the disk is inside next to the flywheel.
By what you told us, your truck must be a standard shift. Because if this happens in an automatic transmission, probably the planetariums are damaged inside the transmission.
Dec 31, 2010 | 1989 Ford F 150
Rolls in park
If you shift to PARK position, the auto transmission (if you have one) shift to a blocked mode. The blocker is located inside the auto trans. This is a very hard piece of metal the hooks into a gear and blocks the transmission. If that part is broken, the car rolls and it takes only some drive cycles that this little item will wreck your transmission completely. If you have a manual transmission, maybe the clutch need to be replaced. You can check the clutch: accelerate fast in first or sec. gear. If the engine turns up without speed acceleration, replace the clutch.
Oct 22, 2009 | 1993 Jeep Grand Cherokee
Car wont roll forward or back even in neutral
I assume it's a manual transmission.
If the car will not roll backward or forward in neutral (with or without the clutch engaged) the transmission is most likely locked in two gears at the same time.
This may happen if gear selectors are excessively worn. If you are able to examine the gear selection levers external to the gearbox, ensure they are in the 'neutral' (no gear selected) position when the gear lever is in Neutral. If not in correct position, you may be able to manually reset the levers to correct neutral position and thereby unlock the gearbox.
In any case, if it's happened once, it will happen again, so get the gearbox and gear selection mechanism checked for wear or breakage.
Jul 31, 2009 | 1997 Subaru Legacy
Lands Phones Logo
172 people viewed this question
Top Harley Davidson Lands Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ted dux
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
