Question about Sony Handycam DCR-HC90 Mini DV Digital Camcorder
Sony Handycam DCR-PC1E
When I open and close the tape compartiment with no tape there is no problem but as soon I put a tape in, the tape compartiment do not take the tape in. MY problem is as follow: two days ago when i took my camera to shoot the massage appeared " the tape is lock" which was not locked actually, so i tried to changed the tape n opened the tape n putted the new one. but now the tape dos not go back inside!. i tried allot but it dosnot gose back!!. i thought the battery was down so i plugged the adapter but the problem still exist . can any body help me? to solve the problem
  • evrest May 12, 2009
    no no u dont understand, without tape as well it dosnt closes well !!
    but its ok now i need to replace whole tape compartment, which was not cheap !!! lol
    n i am not that fool not to understad such problem if that was the case as u thought miss rekha !!!
    me my self is electrician.....
    Problem Solver:
  • 8 Answers
Yeah ! Your problem is very simple. u can solve it on your own.
If you dont put the tape the comparment closes well and as soon as you pot the tape the compartment does not close , Right ?
The solution is there within ur hands itself.
If you want the compartment to be closed, then simply dont put the tape inside. let it be outside itself. U see, its so easy !
Posted on Mar 20, 2009
I have a Sony Handycam DCR-HC-48 and the tape door won't close along with a 32.11 error code.....HELP
Try these steps:
1. Open the tape cover fully until it clicks open.
2. Turn the camcorder on to "VCR Mode."
3. With the cover still open and the camera in "VCR mode," take out the battery.
4. Put the battery back in--out should pop your tape.
Keep us updated.
Jun 06, 2011 | Sony Handycam DCR-TRV140E Digital...
When I put my tape in the camcorder and close the metal door, the tape does not go down. but when empty, the tape holder do go down.
Hi, My Sony DCR-HC32 handycam's tape mechanism is giving me some problem. It ejects and the tape deck opens up properly but after putting a tape and closing it, the tape deck does not go in. I tried with or without tape but it doesn't go in. It is still open.
Can you please suggest how it could be fixed?
Thanks,
Pramod
Nov 26, 2010 | Sony Handycam DCR-HC32 Mini DV Digital...
Cannot find way to eject tapecassette
Check eject lever near battery, press it downward to open tape compartment, take out old tape and put new tape, close tape door and let it go inside by itself. Close tape compartment.
Below image will help you to locate eject button/ lever in DCR-HC18E camcorder.
Thanks.
Sep 20, 2009 | Sony Handycam DCR-HC40 Mini DV Digital...
Tape compartment will not close
This happened to my sony DCR-IP7E, I had to have this repaired by a camera shop of £129.00 with 12months gtee, work like a new one
Dec 30, 2008 | Sony Handycam DCR-IP7E Micro Digital...
Cassette Compartiment Problem
We have this service manual. Pl. email me.
Sharmila.
Aug 24, 2008 | Sony Handycam DCR-TRV480 Digital Camcorder
My camcorder tape door won't close
Try removing the battery for a few seconds, and then re-inserting. This seems to reset something on my DCR-TRV20, and it starts closing properly.
Jun 15, 2008 | Sony Handycam DCR-HC48 Mini DV Digital...
DCR-PC1E
there can be many reasons. rusted contacts, or blown up fuses, or a short circuit in the power board, and may be some thing else. No one can help unless he examines the camera.
Sep 11, 2006 | Sony DCR-PC55E Mini DV Digital Camcorder
I'm not from the UK so can't help you find a lab. but regarding your problem - The fact that it works well without a tape tells us that the load motor and possibly even the capstan motor and associated mechanisms are working. It doesn't tell us much about anything else though. Could be that the head drum is not spinning - This can be the result of a siezed drum motor, or power supply fault(if seized it will draw excess current, thus giving a battery warning indication). A faulty, or possibly even a correcly working dew sensor - This will allow the heads to spin, but prevent the tape from actually lacing up. This is a 'hard' one really, because if the dew sensor is faulty you will get this problem, but you will get the same problem when the sensor is working and actually doing its job in that it has really detected moisture. There are many other possible causes too. The first thing to look for is to see if the heads are spinning - or at least see if they *try* to spin, because unless they *are* spinning the tape will never load. Also, the heads *shouldn't* be spinning with no tape inserted - if they are then this suggests that the dew sensor has been activated (the heads are made to spin under this condition in an attempt to dry things out). If this gives no clues, the next step would probably be to dismantle the thing and attempt to load a tape by hand (looking for signs of jamming mechanism, etc. Anything more serious than this is one for the workshop. Platano guatemalteco? Good luck!
May 26, 2006 | Sony Handycam DCR-PC1 Mini DV Digital...
Sony Handycam DCR-HC90 Mini DV Digital Camcorder Logo
175 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
