Question about HP Photosmart MZ67 Digital Camera
Slider switch view to take pcture
Hello I have a problem on my HP Mz67.
The swith do not slide to take a picture.
It is a mecanic trouble.
The camera on and off work ok.
I hope your replay Fern.
  • Anonymous Oct 19, 2008
    The slider appears to be physically stuck on the take photo mode, but the screen is stuck on the review pictures mode. The last time I used it was to download pictures several days ago.
I had the same problem I just fixed today, is really easy to do it yourself the hardest thing is to disassembled you just have to take off the four screw at the bottom and there's another one in the battery compartment between Sd card slot and the 2 batteries to hold the silver plate on top is hard to see it, after you took off that little screw you can take off the top silver cover, after you took the silver cover off you'll see one more smaller screw on top of the camera under the silver plate you took off unscrew it and then separate both sides with a blade or some thing alse in mind (do it carefully it got a few small engagements around) after you did that you are ready to align the slider switch with its proper pin, youll see it. This helps to replace the lcd screen too, ones you are there. its easy hopefully it helps you
Posted on Oct 11, 2009
How to unlock memory card
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Jul 29, 2012 | HP Photosmart MZ67 Digital Camera
Sony handycam says ''reinsert the tape'' doesnt record or replays
Hi, that look like if the cassette in switch is not work
because the camera act like if she dont see the tape
in the cam or that could come from the mode swith in the mecanism ,the mode switch is act to tell to the servo control ic where is the position of the mecanism...that mean could need an aligment
for these type off camera you will need a good tech
hope that help you
have a nice day////AS
Mar 26, 2010 | Sony Handycam DCR-HC42 Mini DV Digital...
I lost the manual need new one
You can download one from the manufacturer's web site. Go to http://www.hp.com and search for "MZ67".
Feb 07, 2010 | HP Photosmart MZ67 Digital Camera
My memory card on my camera say it is protected
you look on the memory card, there will be a lock slider thing,it might be on lock , check it,
Aug 17, 2009 | Nikon Coolpix S210 Digital Camera
On my HP 537 camara my daughter dropped it now the switch that makes the camara go to view pictures or take movies will not work, it just slides back and forth? Is there a way I can open it and fix the...
If you can take things apart without damaging things...then it may be possible to fix. I have had mine apart several times, and the slider on the outside, switches a mini micro slider inside. It has to be lined up with the tabs...dropping it may have caused it to jump the slots.
Mar 09, 2009 | HP Photosmart M537 Digital Camera
No sound on my Mz67 camera
as far as i know those cameras do not have sound but they do have a mic. Try making a video,make some noise and put the video on your comp,from there it should be as clear as a bell.
May 26, 2008 | HP Photosmart MZ67 Digital Camera
Can I use the HP Photosmart Mz67 Digital Camera as a webcam? Thanks! - Robin
I've had mine for 1 day, and my answer so far is nope, at least I have not figured out a way yet.
Feb 01, 2008 | HP Photosmart MZ67 Digital Camera
My hp m22 won't turn on
Read 'nightdivers' earlier answer The problem is that there is a small, less than 1 cm rectangular magnet, embedded in the slide cover just to the right side of the "HP" logo and above the "M22" marking, the magnet activates a metallic reed switch on the circuit board when the slide is move to the right to "turn on" the camera and take pictures also exposing the lens. When the slide is moved to the left, the reed switch contacts are off. This would be an easy fix for a camera shop (as long as you tell them what the problem is) and they would not be able to overcharge you with the knowledge you now have... This is a great camera, and would be well worth the fix My addition is: I used a magnetic ended screwdriver and lightly tapped the magnet end over where the badge/logo covers when the slider is opened. hey presto, my camera sprang back into life!
Dec 25, 2006 | HP Photosmart M22 Digital Camera
HP Photosmart MZ67 Digital Camera Logo
49 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
