Question about Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum
Hoover steam vac
How do you attach the hose to use the furniture attachment
  1. Remove your cleaning solution tank and set aside.
  2. Remove the lid to your recovery tank.
  3. Remove the front panel of the recovery tank by sliding it straight up.
  4. Slide the convertor half way down into the same slot. (Curved side down). The opening should be facing upward.
  5. Replace the recovery tank lid.
  6. Open the door marked stair/upholstery cleaning connection.
  7. Press the tube connector with the black tabs onto the projection inside the door.
  8. Replace you cleaning solution tank and you are ready to go.
Note: It's a good idea to turn your brushes off. Also, you may need to prime your hose by turning on your cleaner and holding the hand tool onto a flat surface for a few moments before use.
Posted on Aug 09, 2008
Attach furniture/stair cleaner ?
Please look at the user manual at the following link:
http://www.hoover.com/pdfs/manuals/F5871900.pdf
It is for a similar Hoover Steam Vac model.
Oct 30, 2009 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
How to attach the upholstry cleaners
Easliy download the manual at Hoover.com.
The hose attached in the front of the unit on the clear front panel. Lift up the center cap and attached the hose. Then attache the supply hose to the side of steam vac for your solution.
May 25, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
How do i attach the upolstery attachment?
Go to www.Hoover.com Click on carpet cleaners. Click on steam vac all terrain. Click on Learn more. Click on Download Instruction manual in pdf. It explains all. The hose is attached on the front of the recovery tank. under the hoover symbol.
Jan 30, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Attach upholstery hose
Go to www.Hoover.com. Click on Carpet Cleaners. Click on Steam Vac All Terrain. Click on Learn more. Then click on Download the manual in pdf. The manual explains all.
Jan 22, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Hoover Steam Vac leaks like a sieve
I have the same problem with my hoover steam vac, different model but same problem. So I have had it for 2 years and never used the attachments because the thing leaked out the bottom when i tried. So today I tried to find a solution online and found nothing. So I started toying with the thing and found a solution for my model and I hope it will work for everyone else. I don't have a stair attachment so this goes for the upholstery cleaning attachment. I noticed right where my upholstery attachment connects to get soap, there is a second hole that is covered by a white rubber seal when the cover for the connection area is closed. I put a plastic bag, or anything to seal it, into this hole to make a tight seal. Tried the machine and worked like a champ. So Would be nice if hoover supplied a plug for that, but oh well worked for me hope it works for others with a hoover steam vac.
Jan 04, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Cleaning hose
http://geeksquad.fixya.com/ThreadView.aspx?prdid=41018&thid=428640
Cleaning hose
Posted by NNate on Mar 06, 2008
I can't get solution to come through my hose attachement to clean furniture
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover F5881-900 Vacuum. It sound to me that you may have a defective pump or switch, the sprayer or solution should not spray out unless you use the trigger. Question? How old is the machine – if it is less than one year this would be covered under the Hoover factory warranty and if it is more than one year than you may want to check the trouble shooting part of the owner’s manual or to call the Hoover tech support line @ the factory. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Mar 06, 2008 | Hoover F5881-900 Vacuum
Hoover Steam Vac - water leaks
May be an "o" ring missing. Being brand new, it is under warranty, you have a 1 year warranty, so you may want to take it for repair.
Dec 31, 2007 | Hoover F7425-900 SteamVac V2 Widepath...
F5888 900
Doesn't attach at the bottom. If your hose has a block on the one end, take the lid off of the dirty water tank, pull out the block on the front on it and install the block on the end of the hose. Don't forget to put that other block back in when you are done or you won't have any suction.
Nov 11, 2007 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum Logo
415 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
