Question about T-Mobile Sidekick® 3 Cellular Phone
My sidekick 3 doesn't turn on
I just got an used SD3 from my friend. However, the SD3 doesnt turn on. When i push the charger in it glows orange, but even if I do it for a minute it won't turn on....Sorry if I am not being clear...I bought a new battery and charger too thinking they were the problem but to no avail.
  • 1 more comment
  • jjjj09 Nov 30, 2008
    did anyone get the solution to that
  • Anonymous Jan 25, 2009
    mines doing that too. i got it 2 days ago and now it won't turn on. it's the Sidekick 2008 (aka gekko)
  • Anonymous Apr 02, 2009
    yeah me too i just turned it off so i could put the mini sd on n when i tried 2 turn it on it didnt  =(
Well i had the same problem but i solved it by taping the charger to the device in an upright fashion it will glow brighter orange and that means its charging duct tape works best
Posted on Apr 05, 2009
My sidekick 3 won't turn on and i just got it today
Oooh, bad news. You probably got a sidekick 3 that had a bad charging port. Return for a refund if you can.
the Sidekick 3 has a charging issue thatcrops up after awhile. It will just not charge the battery.A good way to tell is if the orange light comes on but the phone never charges.
You can get an external battery charger for the sidekick for about 25 dollars that will allow you to charge the sidekick 3 battery separate.
Check out the following link to see what I am talking about.
Sidekick 3 external battery charging cradle
Jul 13, 2009 | T-Mobile Sidekick® 3 Cellular Phone
The phone will not turn on
Sarah-
The previous poster has a good point, If you have a friend that has a sidekick 3 or sidkeick ID, swap batteries and see if they work.
THe sidekick 3 is notorious for the charging port going bad. It is tricky though, because the little orange light comes on but no power is actually getting to the battery.
In this situation, I recommend a external battery charger and a spare battery.
Check out the link below for those.
http://www.fixmysidekick.com/shop/repair-replacement-parts-for-sidekick-3/Sidekick-3-Spare-Battery-Charger
Mar 02, 2009 | T-Mobile Sidekick® 3 Cellular Phone
My sidekick 3 will not turn on
Your sidekick 3 will NOT charge anymore .
even if the orange light is on & it says charging
it WILL NOT charge . Try using an old sidekick
&just charge the battery on it & then when its
done charging switch the battery back to the other
sk3 .
Feb 28, 2009 | T-Mobile Sidekick® 3 Cellular Phone
Sidekick 3 Charging Question
I can tell you the sidekick 3 will not operate properly with out a back cover. In fact, if you remove the rear cover while powered on, it will post a warning message on the screen.
Because you tested and successfully operated the phone with out complication with a back installed I fell confident you should have have any problem with the phone when your back cover arrives.
Good Luck
sponsored by Cell Phone Technicians
Dec 20, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Battery
Nomad182-
So did you buy it new? If so take it back. If not, then you got a used one that has a bad charginfgport. The sidekick 3 is notorioius for it and the sidekick ID has an issue with it as well. The orange light comes on but the connection that charges the battery itself is broken. Check out www.cellulardr.com. They charge about 75 dollars for the repair or you can do a workaround that charges the battery seperate form the phone.
The following link shows it for the sidekick 3 but the sidekick 3 and sidekick ID batteries are the same.
http://www.repairmysidekick.org/SideKick-Repair-Parts/Sidekick-3-Spare-Battery-Charger
I would also recommend a second battey so you can have one charging at all times. They runa bout 5 dollars on ebay.
Nov 11, 2008 | T-Mobile Sidekick ID Cellular Phone
Phone wont charge
Stevey-
The sidekick ID charging port can go bad like the sidekick 3's. An easy workaround is to get an external cradle that has a spare battery charging slot.
The trick is that the sidekick 3 and sidekick ID batteries are the same so the sidekick ID battery can be charged by the external cradle. An extra battery is a good idea as well so you can have ine charging at all times.
Check the cradles out here.
Sidekick ID external Battery Charger
Sep 10, 2008 | T-Mobile Sidekick ID Cellular Phone
Sidekick wont charge
wakesk8er02
The sidekick 3 has a known issue with the charging port going bad. The orange light will usually come on but it doesn't charge the battery.
you can try www.cellulardr.com or you can do a work around that will cost less.
Most people will buy a cradle charge that has a built in spare battery charging slot. This allows you to charge the battery seprate form the phone. ?It is about 25 dollars on ebay. Its also a good idea to get a spare battery so you can have one charging at all times.
Sidekick 3 Spare Battery Charger
Sidekick 3 Batteries
Jul 14, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Sidekick ID.
try a friends battery if that doesnt work then dont buy a battery and sometimes reseting the phone may work like turn the screen to 90 degress and put an earing or pin inside the reset whole
Mar 26, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Sidekick 3 Charger.
The Sidekick 3 is notorious for having the charging port go bad. New battery or charger doesn't help when this is the issue.
YOu can get it fixed for around 100 dollars or ou can get a charging cradle that has a spare battery charger. Since you have an extra battery it will work well for you. They are about 30 dollars from ebay.
http://shop.sidekickskin.net/SideKick-Repair-Parts/Sidekick-3-Spare-Battery-Charger
Dec 29, 2007 | T-Mobile Sidekick® 3 Cellular Phone
My sidekick 3 doesnt turn on it have a black box in the middle of the screen and it satys there until i take the battery out
if anyone would like the answer to this problem, please leave comment and ill shall repost it in a few
Nov 20, 2007 | T-Mobile Sidekick® 3 Cellular Phone
T-Mobile Sidekick® 3 Cellular Phone Logo
208 people viewed this question
Top T-Mobile Cell Phones Experts
Starnley Johnwells
Starnley Johnwells
Computer Repairing
Computer Repairing
ismael castillo
Are you a T-Mobile Cell Phone Expert? Answer questions, earn points and help others
