Question about Kenmore 1348 Builtin Dishwasher
No water is coming in the dishwasher. I can hear the water running, but the water is not coming into the dishwasher
    Problem Solver:
  • 13 Answers
If you can hear the water running - but it's not filling, you most likely have a drain problem, which is being stuck open. Usually the motor kicks in and either pumps the water through the wash arms (during wash cycle) or through the drain (during drain cycle) the switch that/or flap could be stuck on the drain and it is pumping it out the drain all the time instead of the wash arms.
Posted on Apr 22, 2011
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 66 Answers
SOME DISHWASHERS FILL A TANK UNDER NEATH FIRST BEFORE U WILL SEE ANY WATER
Posted on Jan 21, 2013
  • 4,323 Answers
Hi
When the Dishwasher is not filling in, you'll need to check for the water inlet valve, the filter screen and the float switch/assembly. Also check for the float assembly inside the dishwasher. When water is filling your dishwasher, a float rises along with it. As the float reaches a certain threshold level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Sometimes it can happen due to float valve and on other occasions due to float switch. Inspect the water hose coming to the dishwasher for any blockages.
If these are fine then it's due to Water Inlet Valve. Use a multimeter and check for the continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly.
Hope this helps... Please post back for any further assistance.
Daniel
Posted on Apr 18, 2011
2 Suggested Answers
SOURCE:
  • 457 Answers
SOURCE: water will not come into the dishwasher
it may be stuckin drain mode. the float may be activated. remove any water that may have leaked in the machine. then check the water source make sure the water is going into unit. last check your water valve, ohms it out .that should it,if i helped please send me a 4 thumbs up post.Thanks!
Posted on Mar 01, 2010
Code F2
If you hear the drain pump running but water stays in the bottom then you have to check if the kitchen sink drain is clear. More particularly if you have a garbage disposal unit in kitchen sink then make sure it is working and has been cleared before running the dishwasher. In case you do not hear any drain pump or it is rough and not draining then it may need to be replaced. The drain pump is available from this site.
Jul 22, 2012 | Asko D1776 Stainless Steel Built-in...
Dishwasher not working.... when i close the dishwasher and turn it on i can not hear any water running and there is a pool of water at the bottom that will not drain
Hello, How long has your dishwasher been do this? Have you washed dish's in it? Also, these German made dishwasher run on less than 2 1/2 gallons of water. These German manufactured dishwasher machines run really quite. Because of the German water conservancies laws. They limit the amount of water dishwasher and washing machine can use. Also, there is no storage hot water system in there homes, it on demand hot water. You can't hear the motor running and about the only thing one can hear is maybe the water washing the dishes.
Now, the water at the bottom of the dishwasher, if the drain isn't connected up under is the sink drain and trap area or the garbage disposable in the sink. but some place lower on the drain pipe. You will not have a spiffing effect on the the bottom of the dishwasher, it the same with washing machines. One the discharge pump starts sucking air, it will not drain the dishwasher. The siffen effect works if the water is below the outlet for the drain. Example: Home owner have the new washing running and continue fill with water. Why, because the drain pipe end is below the the bottom of the washing machine tub. It fill up with water and siffen action continues emptying the tube will it still filling. One heck of a water bill.
GB...stewbison
Aug 25, 2011 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
Frigidaire dishwashers arms are not moving
Make sure the water inlet valve is fully opening.
Jul 10, 2017 | Frigidaire 24 in. FDB1050RE Built-in...
Water will not come into the dishwasher
Feb 21, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
Water does not drain
For the water to drain, the controller must send power to the water pump and the solenoid (drain) valve.
If you hear the pump running when it should be draining then the controller and pump are working and the solenoid is bad (usually the case).
If you don't hear the pump running during the drain mode, then either the pump is bad or the controller is bad (not sending power to the pump).
Also, check that you do not have debris inside the dishwasher where the water drains. This is around the spindle in the bottom of the dishwasher cabinet where the spray arm comes up.
If this helps you, please select YES to one of the first two ratings questions. Thank you, and Good Luck.
Oct 13, 2009 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Does not let water come through n I can hear the pump running .It is a frigidaire dw3200p*1
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
Sep 04, 2009 | Frigidaire Dishwashers
No water inside
your bottom spray arm has holes where the water shoots through , make sure they are not clogged.Check upper spray arm also, remove any matter that is blocking the openings and run rinse aid through your D/W at all times. Hint : Glass Magic is a D/W product out in Markets ,if you can run that through the D/W your going to save alot of headaches . Please rate this !
Jun 20, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Dish washer has no water.
Check the faucet first, turn off the faucet, disconnect the dishwasher copper hose, re-open the faucet and check you faucet see if there is water come out, sometimes there is a small stone or sand block the faucet. Good luck, hope this can help, if not we check the others.
Jun 16, 2008 | GE Nautilus 24" Built-in Dishwasher
18 in dishwasher drains water during cycles
find out how the dishwasher is set up to drain. Pour water into dishwasher 4 or 5 gallons, see if water disappears. if so, your drain is ran wrong
Jan 05, 2008 | Kenmore 15121 Built-in Dishwasher
Kenmore 1348 Builtin Dishwasher Logo
476 people viewed this question
Top Kenmore Dishwashers Experts
Fred Sops
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
