Question about Dacor Preference SGM365SS Gas Cooktop
Converting LP to NG
I appreciate your comments but the problem is Dacor will not sell a conversion kit. Any way to ovtain the sizes the orfice needs to be for NG ?
Tks Jffoy@aol.com
  • jffoy Aug 09, 2008
    I've signed on for Premium Assistance but I haven't rec'd any.
    I've had well meaning replies say that a prof needs to do the job etc. which I agree. THe problem remain: that Dacor; 1. will not sell a conv. kit, nor will they tell you the orfice size required for NG. If we had that we could proceed. And no - the pdf install instructions online at Dacor do not give any detail on the orfice dia. sizes. HELP
    JFFOY@AOL.COM
  • 550 Answers
The install manual on the dacor web site insists that Natural Gas requires the nozzles be removed, that low pressure NG works with the large 'default size nozzles'. Have done the conversion, in Australia, for my own barbecue, worked ok
Gas is too dangerous to make mistakes with. All I can suggest if Dacor is difficult is take the pdf of the installation instructions, link in the first replies, and the barbecue to a local gasfitter/plumber and ask them to work on it. they will be able to do the calculations from the existing nozzle size, lpg pressure, ng pressure, and required BTU output, to put in correctr nozzles
Dacor Australia are much easier to deal with.
(Now res in Canada,)
Bob
Posted on Aug 08, 2008
  • AlmostBob
    AlmostBob Aug 09, 2008
    I did not suggest the pdf instruction sheet specifies sizes,
    rephrased for clarity,
    a gasfitter/plumber will be able to calculate the orifice size for NG,
    from the existing orifice, supply pressure, output btu, for lpg;
    and the NG supply pressure.
    using the install instructions as a guide
    Whether you signed up for premium assistance or not, I provide what help I can, from experience, without recompense, as do a large proportion of respondents.
    Guru -just means I get it right most of the time
  • AlmostBob
    AlmostBob Aug 10, 2008
    Inapproprtiate, thank you
    fix it yourself,
Switch from lp gas to natural
Some ranges have the conversion orfices right on board and for others you will need to order a conversion kit. Your manual will have the directions if the kit is on board. If there is no directions then look at most any of the appliance parts websites under your model number for the conversion kit.
heatman101
Apr 21, 2011 | GE 30 in. JGP337 Gas Cooktop
Hi I am trying to convert my Dacor stove/oven from NG to Propane. We can't find the conversion kit anywhere. Any ideas?
Hi, to convert from NG to LP is easier in some ways but harder in others. The pressure part is easy because LP runs at the same pressure that comes into the house so the regulator is normally locked wide open to allow a direct by-pass. You could just as easily remove the regulator and plumb straight in from the houseline. You don't say what model but usually the sealed cooktop burners will need smaller orifices and the oven and broiler orifices are adjustable. If that is the case, the oven and broiler orifices can be tightened until they bottom out which be the correct output for LP. You would need to remove the cooktop orifices and find replacements which are correct for LP, these are non-brand specific. Honestly, if you go to repairclinic.com and enter the brand and model number, I'd be surprised if you couldn't find the conversion kit. Even the Dacor site should be helpful. I found many different kits available at the repairclinic.com site even without a model number. Best of luck.
Jan 29, 2010 | Dacor Preference SGM365SS Gas Cooktop
Converting cooktop regulator from NG to LP
LP is higher in pressure than NG, so regulator spring pressure has to be greater.
Aug 06, 2009 | GE Cooktops
Can a dacor range be converted from natural gas to LP liquid propane ??
I will trade you parts. I have the NG version and need to switch to LP.
Email me at adjuster@me.com.
Thanks
Jul 10, 2009 | Dacor Preference SGM365SS Gas Cooktop
I have a Dacor 48" ERD dual fuel range set for LP and need to convert it to NG. Dacor says "NO can do" I know it is not rocket science. Parts people such as appliancepartspros.com first say I need about 5...
If Dacor does not supply a conversion kit you may have big trouble changing it to natural. In addition to the burner valves you must change the orifices, the regulator, and venturi tubes. This would be quite a challenge. Good luck!
Jan 07, 2009 | Dacor Preference SGM365SS Gas Cooktop
Converting Dacor ERD30S06CH/LP/H to Natural Gas
I know they won't convert gas water heaters but I didn't know they were afraid of stoves. See if your gas company will help. Sometimes they can drill out the orfices. Some of the older repair people still remember how to do this. The orfice for natural gas is larger as the pressure is a lot less. The gas pressure regulator will also need to be replaced. This can be done with a generic part.
Jul 12, 2008 | Dacor Preference SGM365SS Gas Cooktop
Dacor SGM365
call a qualified technician
Feb 14, 2008 | Dacor Preference SGM365SS Gas Cooktop
Propane to Natural Gas Conversion
on the regulator there is a 1/2" nut, made of aluminum. loosen the nut, thur it around and screw it back in, there is a "NAT" on one side, and a "LP" on the other side, make sure the "LP" is facing out if you are using propane, and "NAT", if you are using Natural Gas. Very simple, all you need is a 1/2" wrench, or a small adjustable wrench,
Jan 06, 2008 | Dacor Preference SGM365SS Gas Cooktop
Dacor Cooktop gas conversion
Where did you purchase the kit? Can you name the store with number or list the website? Also the part number information. Thanks
Sep 19, 2007 | Dacor Preference SGM365SS Gas Cooktop
Dacor Preference SGM365SS Gas Cooktop Logo
570 people viewed this question
Top Dacor Cooktops Experts
jdthefixer
Mike
Mike
Are you a Dacor Cooktop Expert? Answer questions, earn points and help others
