Question about RCA F36645 TV
RCA 32" tv. #f32665
Hi, I no longer can get TV. guide on this T V. Is the satilite out or do I have a problem?
  • sdeonarine Sep 19, 2008
    I have a RCA 32" tv#f32450 I an not getting sound or sattalite a tv guide pops up on yhe screen
    Scholar:
  • 92 Answers
What is your signal source? If it's satellite, which brand? Need more info. to go on.
Posted on Oct 06, 2008
Discharging a RCA tv model #F32665 I cut the red wire and forgot to discharge the tv (got a shock) is there a way to still discharge the tv so it can be scraped?
You've done a mistake that might me fatal indeed. There will be charge hold in the CRT even though the set is switched off, and will retain for a long time. You must have to discharge the final anode before remove the anode cap. To do this, connect one end of the multimeter probe to the tuner cover or at any ground chassis. Slowly insert the other end of the probe, by the side of the rubber boot at the final anode. The charge hold will discharge through the wire to ground. Hold it for at least 10 seconds. Now it will be safe to handle.
Aug 27, 2012 | RCA F32665 32" TV
My old 32 inch rca f32665 stopped working as we were watching it. no picture or sound and there is a sound coming from the back where the power cord goes in that sounds exactly like a cricket only its a...
The usual cause is a shorted horizontal output transistor. The way this chassis is designed, the supply makes 140 volts which is always on and applied to the transistor. The heavy load on the power supply causes it to make that chirping sound as it keeps trying to start, then shuts down right away.
The h-out is Q14401, RCA part number 237470. A 2SC5148 can replace it.
Jul 31, 2011 | RCA F32665 32" TV
Color lost on TV after hooking up Zenith DTT901 converter box
Try unplugging it if color regains its the box and not the TV!! if it dont regain then the flyback needs to be looked at. I am sure its the box and not the TV and yes had problems with zenth boxes Thank you
Apr 23, 2009 | RCA F32665 32" TV
No sound to TV when MUTE button is turned off.
eeprom ic after you replace it you will have to have service menu to reset hori sink .
Dec 12, 2008 | RCA F32665 32" TV
Rca tv F32665
Try other inputs such as rca and svideo.
Aug 18, 2008 | RCA F32665 32" TV
Rca g26261tn colortrak television
If the TV is HD then yes it is ATSC if it is HD ready Then it is NTSC if it is noe of the above then it is NTSC. The Advanced television standards committiee was developed in 1982 .
Mar 08, 2008 | RCA F32665 32" TV
BROKE PART OFF TV-RCA F32665
Hi, some of those units have whats called a "RF cable" running from the back of the set to the tuner, and some are directly spot welded to the tuner, you need to remove the back from your set and see if yours is a short cable to the tuner, otherwise you have to replace the whole tuner, check the back of your set and you`ll see on a sticker the complete model number, (few numbers or letters after F32665) this is referred to as the service model number and I can look up exactly what you need to change
Nov 28, 2007 | RCA F32665 32" TV
TV will not turn on
The F25261TX3 is a 25 inch set that uses the CTC185 series chassis. The 2 most common causes for the set not turning on are a corrupt EPROM and a bad regulator or resistor in the main power supply. This is also the chassis notorious for cracks on the shields around the tuner and microprocessor which causses the EPROM to go corrupt. These are relatively easy and simple things to correct, but the set should be serviced and modified by a qualified tech familiar with that RCA chassis.
Aug 21, 2007 | RCA F32665 32" TV
RCA F32665 Shows only gray screen, sound works.
You have a problem in the video circuit. Any video that comes into the set is not getting to the picture tube. The menus come from the system control microprocessor. This shows that the input at the picture tube itself is working. Also you system control is working. The signal would have to be traced through the set to find out where the loss is originating. Stargazer
Jun 14, 2007 | RCA F32665 32" TV
RCA F36645 TV Logo
49 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
