Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Had blue screen, now no picture and red light
I had the blue screen, then my lamp indicator went solid red. i am now in posession of 2 new lamps and both of them are giving me no picture what so ever and I also get a solid red indicator for the lamp. Can this be some other issue besides a lamp?
  • cpeters171 Aug 09, 2008
    i get no picture what so ever on my tv, so no code shos up. i also had the buttons on the tv locked, dont know if this would also have an effect. but i tried your idea using the remote and the tv and i get absolutely nothing as far as any type of code. as soon as i try to turn on the tv i get a solid red lamp indicator.
  • Mitsubishi Master
  • 8,617 Answers
Press the menu and the device/input buttond on the det both in together and hold in for 5 seconds to see if the led will blink a two digit code such as 3 blinks slight pause then 4 blinks. I would almost bet that you have a 34 code come up. But respond to this same post and let me know which two digit blink code came up, and I will assist you with whats wrong with your DLP.
Posted on Aug 08, 2008
  • Sonny Berry
    Sonny Berry Aug 09, 2008
    you have to use the buttons on the set itself to activate the code the remote wont work for that feature. However if the buttons are locked there is no way to retreve the code. Its almost got to be the 34 code which indicates that the capacitors on the power PWB need replacing. You can get the kit with instructions at the following link under the repair kit category. Its called the V26 DLP power PWB repair kit. Here is the link.
    http://servicemanuals.vstore.ca/
Toshiba 56hm66, lamp replaced but lights still blink
Check the circuit boards to see if any have failed. They are small cylindrical objects. If the tops of any of these are bulged instead of flat then they are bad and board will have to be replaced. Hope this helps.
Jan 03, 2014 | Televison & Video
No sound or picture. red timer light on. wd60735
This model as 3 LED indicator lights:
1) Power/Timer 2) Status 3) Lamp
If "STATUS" LED is blinking RED:
1) Internal Fan has stopped. These tv's require fans, to prevent overheating and causing damage.
If "STATUS" LED is solid RED:
1) Circuit failure (short)
2) Disconnected DVI cable, chassis to engine
3) No LAMP-EN signal from Engine to turn the lamp On.
4) Ballast UART communication problem.
If "LAMP" LED is solid RED:
1) Lamp Failure - Lamp failed to turn On.
2) Lamp is broken (e.g. burst or blown)
3) Lamp turns Off during P-ON
There is no data relating to TIMER LED being solid RED.
Hope this helps.
Cheers,
Scott
Feb 01, 2013 | Mitsubishi Televison & Video
Picture went out - red light now on. Do I need a
Do ur LED light indication on the front screen panel "LAMP"Flashing?Yes,the lamp require changing.
Jun 06, 2010 | Mitsubishi WD-52627 52" Television
My Mitsu 52525 lamp indicator went solid red. I
sounds like the caps on the power board have failed. You can get the V26 DM/Power repair kit from www.tvrepairworld.com which also contains the instructions.
May 12, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Thats usually caused by failed capacitors on the power board. The V26 power repair kit from www.tvrepairworld.com should repair that issue. The kit comes with the instructions on Cd.
Mar 20, 2010 | Mitsubishi WD-52525 52" Rear Projection...
No Picture - Lamp Indicator Blinking
This may be the main power supply, or the lamp supply. This is providing that the new lamp is okay.
The service tech will swap out the modules to service the set.
Jerry G.
May 15, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Ghost images!
I had the same problem, reset the lamp hours by pressing 'menu, 619 , menu" and browsing until I found the setting, but then I also saw an option to test the lamp.  The TV shut off when I tried this and 2 red lights indicating a new lamp is needed came on instead.  It's probably the ballast and not the lamp, but I don't know that I want to put any more money into this set.  I have only had it 2 years.
Apr 26, 2008 | Optoma RD50 50" Rear Projection HDTV-Ready...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
116 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
