Question about Panasonic KX-T7630 Corded Phone
Can not pick up line on incoming calls from one extension only
The phone won't allow me to pick up incoming calls from one particular extension (the display says that the line is busy). Every other extension in the office works, and the phone was able to pick up calls when it was programed with a different extension. I'd like to be able to get incoming calls from this extension, since it's on all of my business cards :)
  • capkaraoke Sep 08, 2008
    Can not pick up line on incoming calls from any extension, i can only answer calls from the first phone plugged in?
  • Diane Murphy Sep 23, 2008
    All other lines on the phone work perfect on incoming calls just 1 line is crackly and cant hear anyone on the other end, ive rang the phone and the line just keeps ringing even when answered
  • Panasonic Master
  • 2,460 Answers
That's what happens when you plug in the system and don't program it. You need to review ICD groups.
By default, the phone connected to the first extension is the master phone and the only phone that rings.
Carl
Posted on Sep 12, 2008
  • Carl Navarro
    Carl Navarro Sep 12, 2008
    I don't know who rated the solution, but please tell us all how you fixed it.
When a call comes in and I transfer to my boss' extension, incoming calls do not come through, caller states phone keeps on ringing. Also on that same extension calls do not transfer to voice mail.
  • Begin the transfer. With the caller on the line, press the "Transfer" key. The caller will automatically be placed on hold and you will hear a dial tone.
  • Connect the caller to the other party. Dial the extension of the party you wish to reach. When you hear the extension ring or after you've announced the caller, complete the transfer by pressing "Transfer" a second time. If the person does not wish to receive the call, press "Release" to disconnect from the dialed extension. Press the key beside the flashing arrow on the LCD indicator where the various lines are displayed to return to the caller.
  • Cancel an incomplete transfer. If you make an error when dialing and need to retrieve the caller, simply press the key beside the flashing arrow on the LCD indicator.
  • Park an incoming call. Parking a call at a designated extension allows the recipient to answer the call from any phone in the facility. With the caller on the line, press the "Park" key twice. If your system designates a particular extension for parked calls, the caller will be held at that extension. Otherwise, the caller is held at your extension. To specify an extension for a parked call, press "Park," dial the desired extension and press "Park" a second time. Replace the handset.
  • Retrieve a parked call. On any system phone, press "Park" and dial the extension on which the call is parked. You will be connected to the caller.
Aug 18, 2016 | Nortel Norstar M7310 Telephone
My Norstar Phone Won't Let Me Pick Up Incoming Calls
Make sure they are Line Buttons, do FEATURE * 0 then press buttons to see what they are/do
Or maybe the key pad inside has failed.
Mar 04, 2013 | NorStar Lands Phones
Panasonic phone
This system will have to be programmed to allow line 1 to ring on that particular set. When you pick up line 1 now and it dials out it is dialing the last number you called from the phone.
May 28, 2009 | Panasonic KX-T7730 Corded Phone
During incoming call the line will go to others extension line.
Consult an expert he will fix it bcos normally they wont let go their codes.
Rate this
Apr 06, 2009 | Panasonic KX-T7730 Corded Phone
How to do check my missed call log
A Panasonic TDx system has 2 types of call logs, one personal for the set, and one for the ICD group.
Pick a spare button, press PROG, the button, and dial 54 STORE.
If you had incoming: 00x on your display, that button will light and you can now press it to see who called. Your Navigator UP/DONW key will step you forward or backward through the log. The LEFT/RIGHT key will display the 4 lines of the display if you're not using a 7636 phone.
If you want to see incoming calls to a particular ICD group, pick another button, and dial 54 plus the ICD group number. For example, I used 100 as my ICD group (now 600 by default). I have 2 buttons, one logs my extension calls, one displays the system calls.
Carl
Mar 09, 2009 | Panasonic KX-T7630 Corded Phone
Nortel M7310 Phone moved to another jack, now no incoming calls
you need to go to your previous location and get the jack number, than go to the new location and get the jack number. now go to the phone system closet and look for these cable numbers on the 66 blocks. Swap the cross connect of the jacks and wallah your phone will be your s again! ldtnsj.com
Jan 20, 2009 | NorStar M7310 Corded Phone
KX-T7730 Picking up Problem
You are on the right track but the extension number is not " 0 ". There is an extension number associated with the operator phone just as your phone may be " Extension 101". If you have a display phone have the operator call you and look at your display for her/his extension number then when their phone is ringing, pick up your handset, dial 4 plus the extension number of the operator. Let me know how it works out. .....Mitelmike
Nov 18, 2008 | Panasonic KX-TA308 Phone
I want to pick up incoming calls from another extension
Yours may be different if your TA-308 is not a U.S. version, but the family is generally 40 picks up all calls in your group and 4+the ringing extension will pick it up. Just in case they have call pickup deny set (721) you'd have to cancel it with 720.
Carl
Cant retrieve incoming calls from someone elses extension
Of course you picked the feature with conditions :-)
From the intercom 40 picks up any incoming call. 4* picks up trunk calls, and 41 plus ext number picks up a specific ringing phone.
The condition is that an extension can block call pickup by dialing 7201.. 7200 clears it.
Carl
Nov 14, 2008 | Panasonic Lands Phones
Panasonic KX-T7630 Corded Phone Logo
668 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
