Question about Frigidaire Heating & Cooling
We have a Frigidare S3BA-036KA split condenser with a badly rusted Compressor run capacitor. What is the correct capacitor for this unit?
I Had a similar problem with my Air Conditioning unit, the repair man said without the information their was nothing he could do, but that he would go look for it.
This is what i was able to find, This litterally all just took place within the past hour so i don't know if its workable information, but here is my two and a half cents.
http://www.transtaracsupply.com/pdf/s3ba.pdf
Posted on Aug 17, 2009
Replace compacitor on Carrier 5 ton 3 phase AC
Your 3 phase unit should not have a capacitor. I'm guessing it's single phase. If it's a single capacitor than the compressor should not be going to it also. To test the motor, common to start plus common to run should equal the ohms you get between start and run. For instance, 1.2 ohms+ 2.2 ohms= 3.4 ohms. Follow the wiring diagram on the inside of the door, send model number!!
Aug 29, 2017 | Carrier Heating & Cooling
My condenser fan runs and blows cool air but isnt cooling down the house. Any help.
Check the outdoor unit (condensing unit). Keep in mind, because the condenser fan is running it's not an indication that the compressor is working. On a split system,there's a dual capacitor that serves the fan and the compressor. The capacitor has three terminals.
1. common
2. fan = fan
3. Herm = compressor
This is a common problem; The outdoor fan (condenser fan) runs, but not the compressor (you have to know the sound of a running compressor or you'll mistake it for the sound of the fan) doesn't, because the compressor side of the capacitor is too weak to give it that needed phase angle that it requires to start. If you're referring to the outdoor fan spinning, but no cooling, I can bet the compressor isn't working and needs a new capacitor. Very common problem, I see it all the time. Before you change the capacitor, make sure that you cut the power to the unit, and then use an insulated tool such as a screwdriver and short the terminals together first. A capacitor holds a charge even after being de -energized.Buy the new one with the same exact rating written on it as the old one. Do not mix up the wires when replacing. Write it down or take a picture with your phone
Aug 20, 2013 | Heating & Cooling
I have a ( Goodman CKL-49 1 ) fan was not running, I used a small wooden stick to get it to run. fan is now running but cold air is not being produced what can I do can you please help?!
The split run capacitor in the condensing unit is bad. It needs to be replaced. The reason the system is not cooling is because the compressor it not running. The capacitor is needed for the fan and the compressor to run properly. That is why you had to give the fan a kickstart with a stickstart.
Hope this helps.
Sep 08, 2011 | Goodman CKL49AR49 Air Conditioner
Compresser on my 2 ton condenser unit not coming on condenser fan running but not the compresser. I already replaced the capacitor but did not fix the problem.
Check the wires going to the compressor terminals making sure there is no damage to them or to the compressor terminals..Install a hard startbobicehouse_2.jpg
Jul 03, 2011 | Ruud Matching Split Air Conditioner
I have an Intertherm S3BA-048KA Split AC system which has stopped blowing cold air. Indoor blower is working fine. Outdoor fan is not working. I have reset breakers (indoor/outdoor) without success. I...
First thing I would look at is to make sure you have power at the disconnect 110 coming
in on each leg to unit. Second, I would look at the capacitor for obvious bulging or leaking
Third I would check to see if the contactor has burnt points or bugs in it. Your disconnect
may have fuses in it which may have failed as well .
(All checks of the unit with power off to all breakers as there will be more than one
double breaker supplying power to the unit).
The hum you hear indicates that the contactor is pulled in on the outside unit but still may
be burnt or have ants or earwigs especially in between the contacts
. The capacitor can hold a charge even after equipment is off so discharge it to the chassis
before removal. Replace only with same Microfarad rating and equal voltage or higher
Remember to mark the wires as to which came off the HERM / C/ FAN terminals or take a
cell phone picture.
I have just replaced my intertherm condensing unit after it had it's 3rd compressor failure.
It was more cost effective than buying a compressor and hoping all the other components
were going to last.
Feb 26, 2011 | Heating & Cooling
Fan motor on condensor not starting. I have located the capacitor but unable to recognise any writing. it is a12000btu split unit.
There are two type capacitor. One for running capacitor for compressor and one for condenser fan motor by each separate capacitor. Some times two in one capacitor being used. Just check in your condenser unit, in your 2 in one capacitor, there are three parts and one has four pins and other two has each two pins where you can clip the wire.Remove existing wires and replace same with new capacitor.
Now, in this capacitor near each each part mention as "C" "H" " F". Cmeans compressor common and H means for compressor starting and F means fan starting. Be careful don't interchange any wire.
And also while replace capacitor don't add or reduce the mfd. Ex.. your existing capacitoris 35+3 mfd means 35mfd for compressor function and 3 mfd for fan motor function. Hope helpful.
Jan 09, 2011 | Heating & Cooling
Ac unit only blows out room temp air no matter the setting
This sounds like a split system and not a window unit ? First check the outside unit known as the condenser and make sure it is running correctly by --- Check that fan is running on outdoor unit and listen to see if the compressor is running. If neither of these are running then it can be a loss of control voltage to the contactor, bad contactor or even bad capacitor. If nothing is running then turn off the power by using diconnect next to unit....then remove the side or corner panel that has access to the control compartment . Visually check that the contactor is pulled in so that the center section is pulled in to make a complete contact across the terminals for power to flow... look at capacitor and see if it is swollen on the top and if it is swollen then it must be replaced with exact matching numbers from an electrical parts or motor dealer. If everything still looks ok then you will need to contact a local company to troubleshoot the unit further.
Sep 01, 2010 | Heating & Cooling
Ac unit fan does not turn unless i force it to turn. also not producing cold air
If the fan just hums and if you spin the fan and it runs, check out the capacitor, it is bad. Most condensing units have a split capacitor, for the hermedic unit and the fan. If the compressor runs the dual capacitor is bad on the fan side. Your choice buy the dual capacitor, or just buy a single capacitor for the fan part of it. Make sure the voltage rating and microfarad ratings are the same. They will be marked on the old capacitor, as will fan (for fan), and herm for compressor). THATS 220 VOLTAGE YOUR WORKING WITH, BE SURE THE POWER IS OFF!!
Jun 22, 2009 | Goodman Heating & Cooling
Heating & Cooling Logo
832 people viewed this question
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
