Question about Samsung DLP HL-P5663W 56" TV
Tv shutting off auto
Our big screen tv we have had for 2 years keeps shutting off by it self, there is also a loud noise coming from the tv like a fan noise.
    Champion:
  • 230 Answers
Solution: Replaced color wheel ( inside engine light), ( broken or defected inside). I fixed a lot with this problem. partstore.com or tritronicsinc,com
I hope this help you Thank you
Posted on Aug 13, 2008
SOURCE:
VIORE DLP goes off 30 seconds after i switch it on
Listen closely at the rear of the set for any noise from a fan. Most projection sets have them to cool high temperature areas common in these and if the fan fails, the set will shut itself off before any heat damage results. If you hear nothing, use a portable fan directed at visible openings in the lower cabinet and see if this delays the shut-off of the set. If so, the fan is likely dead.
Jul 30, 2011 | GRY Viore RPT50V24DHD 50" HDTV DLP TV
TV makes very loud crackling noise
crackling in the speakers of 42"flat screen tv
Jul 20, 2010 | LG 42LC2D 42 in. LCD HDTV
I have a rubbling noise when the TV is on. The picutre and the the souind is clear although you hear this loud rubbling (bad bearing noise) fromtheback of the TV. When you turn the TV of, the noise is...
This DLP tv have a colors wheel.No,the colors wheel is dying,just not dead yet.It spinning off of it motor axis,when it total dead it will have black&white pics,very loud squiling motor noises.Ur tv need a new colors wheel.Call the tv repair tech for this job,require take out many machanicals parts,before even can take the colors wheel to replaced.Never done this before,don't atemp to replaced the colors wheels ur self.
Jun 14, 2010 | Samsung DLP HL-P5663W 56" TV
Hi I have a Sony Grand WEGA KDF-60XS955 TV
Ur right the cooling fan is defective,check it,clean it might work normal again.Not, than the cooling fan must be change.
May 04, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
No picture, siren type noise as restarting
My Toshiba dlp 62hm116 was used for 3 months then stored for 2 years, I turned it on yesterday and it makes a loud grinding noise which I think is probably from the exhaust fan area and the picture is black except white at both vertical sides. It worked fine the last time I used it 2 years ago. Any ideas?
Jan 13, 2010 | Toshiba 62HM95 62" DLP HDTV
Panasonic TV Turned it self off, humming speakers, loud bang & Burning Smell
hi there, you do have a big problem at your tv, the loud bang means a part is broken, maybe you will cost 50 % of the original price of your tv. ty
Dec 26, 2007 | Televison & Video
Very loud fan or vibration noise
Listen from the back of the TV and locate the source of the noise. There may be fan with a bad bearing. The noise will lead you to it.
Nov 06, 2007 | Soyo Dymond DYLT037A Television
Toshiba DLP fan noise (52hmx95)
i constantly hear complaints about fan noise in dlptvs if you sit in front of your computer you will hear the same noise even in the next room there is no solution to the fan noise problem this product has a huge cage fan and a second and third three inch fans in it.... more than the samsung product it can be noticeable if the tv is on hard surfaces ie wood floors ,inthe corner, glass top etc the vents on the back of the tv allow for proper cooling of the lamp at shutoff so it doesnt shatter the tube its kinda like annealing glass its designed to extend the life of the lamp .... which im sure youve priced call toshiba and tell them your lamp is bad right now and get a new one for an emergency ( warranty if you can do it ) they are also improved this product is known to have short bulb life sometimes the zinging noise you hear is indicative of a bad color wheel in the light engine which would require replacement ( not cheap) toshiba will not piece out the color wheel assembly individually
Nov 30, 2006 | Toshiba 62HM95 62" HDTV
Samsung DLP HL-P5663W 56" TV Logo
52 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
