Question about Canon ImageClass D880 Copier
Error E000 How do you get rid of the Error E000 code?
  • 148 Answers
This is a reprint from another tech, he was right on with this...
okay lets shed some light on the E000 error code on the D680, D880, IR1300 family ( including the 1310,1330,1370,1630,1670)
The error code E00 is a memory threshold error what it means is your machine has logged 4 of the following errors, E001,E002, or E003. It is a lockout error and the machine cannot be used until the problem has been repaired or the errors cleared. First lets look at the errors:
E001 fuser over temp means the fixing assy has exceeded the manufactures maximum temp limits
E002 fuser temp dropout means the fixing assy has cooled below a set point during a copy session
E003 fuser no response means the fixing assy didn't even attempt to warm up at power on
How to fix, most common problem is bad power setting 4 E002's either brown outs of brief power failures.
To clear the error, Enter service mode by pressing additional functions then the # button, use the left or right arrow buttons to scroll to #7 printer press set. again use the arrow buttons to scroll to #4 printer reset press set. press the appropriate arrow key under the YES to clear the error. unplug the copier and reboot. At this time normal function should return if not and it resets a E00 the you can assume either the fixing assy is bad or either the power supply PCB or DC controller is bad and it is getting E001,E003 errors. At that point id call a qualified tech to research the problem to avoid spending money on excess parts
Hope that helps...
Lbcoaster
Posted on Aug 09, 2008
FIXYA was right on the money. Canon Image Class D880 is operational again.
Thank you very much
Posted on Aug 14, 2008
3 Suggested Answers
  • 4 Answers
SOURCE: Error code E000
can u please check the fixing
Posted on Aug 13, 2009
andi_bunkka
  • 102 Answers
SOURCE: canon lbp3010b Error Code: E000 0000
You have problems with the temperature in your fuser unit, check the thermistors
Posted on Apr 30, 2012
Error code e000
If it is a Canon please try this URL
http://testprinter.net/fix-error-code-e000-on-canon-printer-system-error-e000.html
Jul 28, 2016 | Office Equipment & Supplies
Canon D340 Copier System Error E000
Your printer show Error code E000 suggests the problem history has recognized all of these of the following error codes four moments: Error code E001;Code E002;Error E003. Printer Canon E000 error will be removed in the service mode.
Please try reset factory your canon printer..but if it still show error code E000 again ,you can try with a genuine fuser unit (reseting fuser unit). Good luck
Solution 3: Try this, atempt will clear canon E000 code in Service mode:
1.Press ADDITIONAL FUNCTIONS, #
2.Go to #7 Printer and Press OK
3.Go to #4 Printer Reset and Press OK
4.Yes = ( * )
Sep 09, 2010 | Canon PC-D340 All-In-One Laser Printer
System error E000
A E000 coeds means the error history has detected any one of the following error codes 4 times :E001;E002;E003.
The error can be cleared in the service mode.
Contact Canon Consumer Products 800-828-4040
Mar 24, 2010 | Canon imageRUNNER 2010F Copier
What is error code E000 mean
Solution:
Press "Additional Functions",
Press "#", then press the "Right Arrow" button till it says, "Printer",
Then press "Set" then press the "Right Arrow" button again until it says "Printer Reset"
Then press "Set" again, the display will ask you "Yes" or "No".
Press the "Left" arrow for "Yes", then press "Set".
Now, unplug the power cord and wait 5 seconds and plug back in.
If this don't work, get a new fuser.
Feb 04, 2010 | Canon imageCLASS D880 All-In-One Laser...
CANON NP 6220 ERROR "E000"
replace the fuser lamp or the thermofuse.
E000 fuser problem.
Dec 12, 2008 | Canon NP 6050 Copier
Canon IR 2016
Additional Functions>2 key>8 key>Additional Functions (each key is pressed seperately, unlike regular iR copiers) Go to Copier>Functions>Clear> Err_ or Err_Clr. An E000 is a fuser code.
Aug 29, 2008 | Office Equipment & Supplies
How to reset error code E000 on IR2000
E000: Fuser did not heat up. check Fuser lamp, check thermistor, check thermostat, if this parts ok try to reset the trouble code. to reset fuser errors, first shut power off and turn on again. Then, go to service mode. Select "User mode" by pressing additional function ( * ) key then Press "ID" key ( # ) on user mode screen. Select menu 7 using cursor key. Press "OK" key. Select 4 item with cursor key. Press "OK" key. Printer reset. YES=( * ) to clear fuser error code E000.
Jul 11, 2008 | Canon Office Equipment & Supplies
ERROR CODE E000-0320
A E000-0320 code is a fixing unit error code. It is either not warming up or it is getting to hot. It is a thermister is shortting out or a thermal fuse or one of the heating lamps are blown.
Apr 14, 2008 | Canon CLC 4000 Copier
How do i get rid of e000 system error?
is the fuser unit getting hot as it should be?
Jun 06, 2007 | Canon imageRUNNER 1210 Copier
Canon ImageClass D880 Copier Logo
379 people viewed this question
old marine
old marine
