Question about Sony Alpha DSLR-A100 Digital Camera
Error 0X5b the alpha 100 error when shooting , pleasee advise
    Novelist:
  • 178 Answers
Такая же фигня. Фотал нормально. Отключил автофокус, потому что фотал летящих птиц. Две фотки сделал и на третьей выскочила ошибка Camera errop code 0x58 . Выключение и вытаскивание аккумулятора не помогло. Вкл/выкл. автофокуса тоже. Не знаю, что делать. Завтра понесу в сервисный центр сдавать. :( Грустно.
Posted on Aug 12, 2008
Camera error code =0x5b
Usually error codes (maybe not 0x5b) are lens comunication problems and can be fixed by removing the lens and reattaching and make a power reset.
If the problem still persists a service may be required.
Good luck
Jul 01, 2011 | Sony Alpha DSLR-A100 Digital Camera
Mi camara da herror de las Naciones Unidas Herror code = 0x59
On my Sony Alpha 100 I keep getting this error 0x59 when I press the shutter button. It takes the picture but I have to turn the camera off and then back on to use it again
Oct 23, 2010 | Sony Alpha DSLR-A100 Digital Camera
QUANTARAY QBX-8000xi Flash for SONY ALPHA - 350 digital SLR
Unfortunately not.
This flash is a superb budget alternative to the Minolta alternatives but is only suitable for their film cameras. Sony's SLR's are based on the later Minolta Digital SLR's and they're all incompatible with this flash.
The technical differences between the film and digital Minolta cameras explains why a Minolta 5600HS (for example) had to be redesigned and redesignated as a 5600HS(D). The former will not work on Sony Alpha models, but the latter is fully compatible.
May 13, 2009 | Quantaray QBX-8000XI Wireless Remote Flash
Aperture Error
This blog will clear up what is going on with the camera and you can send it to them to fix also. www.teleplancamerarepair.com
Their blog steps you through explaining each step.
http://www.teleplancamerarepair.com/camera-repair-blog/post/0x5b-Error-Code-in-a-DSLR-Sony-A100.aspx
This blog also clearly lays out the F-stop definition.
Sep 26, 2008 | Sony Alpha DSLR-A100 Digital Camera
Error 0x57
The 0x5b error code indicates that the amount of light passing through the aperture lens is not being controlled by the F-Stop selected. error can be fixed. check out quote at www.teleplancamerarepair.com
Another thing that happens when this error is present.
When you raise the camera up to horizontal position and try to take a picture and you get the error code and again it shuts down.Tthe system is being saturated with high light levels indicating the AV drive unit which is not doing its job and controlling the aperture of the lens. This can be fixed.
Jul 11, 2008 | Sony Alpha DSLR-A100 Digital Camera
LCD - Focus
DSLR camera was not made to be used as a point and shoot camera and you cant preview the shot before taking a picture. You are to use the eye piece to focus right. Also before taking a picture, push the exposure button just a little to let the camera focus right.
Jul 04, 2008 | Sony Alpha DSLR-A100 Digital Camera
Sony Digital SLR
You should have no problem, if they are maxuum af. The others should work too- I have an Alpha 100. The alpha 100 works great. I used to run my own photography business, and searched around for quite a while before I found the alpha. There is an adapter ring that i bought, that makes it possible for me to use my favorite old pentax screw mount 135mm f1.6, or any other screw mount, on my alpha 100.
The only drawback I found was you cannot use any other flash(at this time) than the onboard one-or the sony only flashes-which are a little pricey. Different size hot shoe is the reason. I haven't found an adapter yet-but I'm sure someone will make one. The alpha doen't have a real time display- or asa of 3200. I'm hopeing for a firmware update/upgrade to correct this. BUT the newer models with a higher than a100 number do have realtime lcd, and do go to asa3200. And they use either sony mem.stick or CF cards happy shooting
Jun 23, 2008 | Cameras
Sony DSLR-A100, error code 0x5b
Same here. My camera gives me the same error code unless I shoot with the largest aperture/smallest F-number.
Mar 28, 2008 | Sony Alpha DSLR-A100 Digital Camera
ERROR CODE 0x5b
This error message is an indication that a problem may have occurred with the aperture assembly in the camera. To resolve this issue, service will be required.
Feb 03, 2008 | Sony Alpha DSLR-A100 Digital Camera
Sony Alpha DSLR-A100 Digital Camera Logo
592 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
