I just had my computer repair and did not have a back up disc,I had a new hard drive installed, I don`t have a disc for my wireless router. please help!!!
    Problem Solver:
  • 18 Answers
Your best bet is to go to the manufacturer's website and download the drivers from there.
Posted on Aug 08, 2008
Refer Acer m3970 Can not Install windows 7 of new hard drive
Factory back-up discs and recovery discs are intended to repair defective installations or to kick-start an installation that refuses to start so it is unsurprising they will only go so far.
Your system disc might be defective. This is a problem I have had with XP in the past. It is possible your CD/DVD drive has a dusty lens and is unable to read the disc properly or perhaps the new hard drive has a problem.
I suggest you instal the new hard drive as a slave in another computer and format it and run the chkdsk utility. If all is well reinstal in your computer.
Take a close look at your system disc checking for flaws and perhaps put a lens cleaning disc in your CD/DVD reader before trying again.
Oct 27, 2016 | Seagate Computers & Internet
IBM thinkcenter says no os after installing DVD writer
Did you install a SATA or an PATA (IDE) drive?
First check that the data cables are connected to both the hard drive and the motherboard. (I know that I've frequently had the cables come loose from the motherboard on my ThinkCentre 8433 when I work in the case.) Also check that the power cables are firmly connected.
Next make sure that you have no disc in the DVD writer. (Or enter the BIOS by pressing F1 (IIRC) repeatedly on start up. Make sure that the hard drive is the boot disc.) While in the BIOS, you can check if the hard drive is recognized by the motherboard. If you don't see the disc listed, recheck the data and power cables.
If the hard drive was working before you replaced the dvd drive, you may have changed the master/slave assignment on the drives (if they are both IDE). Remove the drives from the computer and check the jumpers. (These will depend on the manufacturer. Use either cable select or master/slave as needed) The boot drive should have the jumper set to master or cable select. In the case of cable select, the boot hard drive should be connected to the black connector. The slave drive goes to the grey connector.
If you connected a SATA drive, try swapping the SATA ports (SATA 0 or SATA1) that has the optical drive connected to it.
The next thing to try requires either the Windows install or upgrade disc for your version of the OS (including the Service Pack) or a third party partition manager/repair utility disc. You'll need to reset the boot order to boot from the optical drive (or press F12 on starting the computer). Use the Recovery Console (for the Windows disc) to find any existing OS installs on your hard drive and attempt to repair the master boot record or boot sector if it still exists on the drive. Please add a comment with your OS for specifics on using the Recovery Console. (I replaced my WinXP with Win7 and the methods are different.)
You may have been unlucky and had the hard drive fail while you were working in the computer. See if the recovery partition (F10 on boot) still works or use your system image (Rescue and Recovery DVDs) will restore your computer to the last backup. Try doing the restore to a new hard drive if the recovery discs don't work.
I hope this helps. Please add a comment with any comments that will help me give more specific assistance for your missing OS.
Aug 09, 2012 | IBM Computers & Internet
I dont know how to instal the printer
If you have the installation disc that came with your printer, simply insert it into your computer's hard drive to install the driver. The application will also show a comprehensive guide on how to setup the printer itself. Please follow the instructions on your computer screen.
If you don't have the disc, you can download the Lexmark Interact S605 Driver from the Lexmark website.
Sep 10, 2011 | Lexmark Interact S605 All-in-One Color...
I just installed a new hard drive and now i cant connect to the internet. It says my computer does not have a wireless network adapter installed and configured. Nothing else has been changed except the...
Hi antayans...
Reinstall your wireless drivers...the files are corrupted.
The wireless files should be on one of the restore discs...
Please take time to rate me
Sep 06, 2011 | Dell Inspiron 1545 Notebook
How can I get my Belkin router to read my Seagate storage device so that all computers in the house can access said Seagate storage device?
1) Turn off your wireless router and unplug the external hard drive you want to make wireless.
2) Plug an Ethernet cable to the "Network-attached storage" device, and the other end of the cable to an available Ethernet port on your wireless router.
3) Connect one end of the USB cable to the wireless router's available USB port and the other end of the USB cable to your "External" hard drive.
4) Turn on the both the Wireless router and the External hard drive. Make sure that your Internet connection is still working.
5) Insert the installation CD and run it on your computer. Follow the installation instructions and install any utilities related to your external hard drive. There may be special utilities provided for flash drives that are not needed for hard drives.
6) Create a login name and security password for the "NAS" device during the setup process. When the installation process is completed, you will now be able to use your external hard drive.
Apr 10, 2011 | Computers & Internet
I just purchased your 1.5 TB External Hard Disc Drive, My Book Essential. I installed it on my Desktop and love it. The WD SmartWare software is great. I also purchased a New HP Pavillion laptop and an...
Man you need an english class lol
Ok thats a good one i like your thinking smart and planty of room. Ok this allmost reminds me of the raid tech savy system, Ok i want to say yes but i cant back it cause you made me all fuzzy dude lol
Hote sync type technology you might want to convert to 64bit OS it'll work faster and recovery will be easier may stress your processor
Answer yes but i would hunt down a jump drive type program so they can link instantly and save you the hastle of constant prompts and search's
Oct 20, 2009 | Computers & Internet
I have an Acer Aspire 8.9....and I need to know what type of router I need to go wireless. I purchased one from Netgear, but it has a disc that must be installed and adapter that has to be used {with...
Aspire one does not have a CD/DVDROM however you can use another computer to be able to setup your router. You can probably ask a friend to use his/her laptop that has a CD/DVD ROM. After setting up the router, you can connect your Acer Aspire by letting it detect the wireless signal and connecting to your router wirelessly.
**You can also try to insert the installer disc on another PC and copy all the contents of the CD/DVD installer of the Netgear into a USB flash Drive. Plug the USB flash Drive into your Acer then run the setup file inside and follow the instructions.
Oct 26, 2008 | Computers & Internet
START-UP DISC
I don't think you need any disk to reinstall your routet, you just write its adress into your browser. Useally the adress is like 192.168.1.1.or 192.168.1.2. could also be 0.0.
Try it
Laulund
Mar 06, 2008 | Linksys Wireless-G WRT54G Router
Change from default
I am going to make some assumptions here first is that the hard drive was added to or replaced in your computer by a store or by a friend. Is it possible that the installer altered your network card configuration eliminating the encryption settings required to be set in your computer for your wireless adapter card to connect with the router in your home? If so I would suggest reinstalling encryption in both your wireless router and to your computer for its adapter card as you did initially to get them working. I find it annoying too when service personnel change my computer's settings and do not set them back to their previous settings when they have completed their work.
I hope this helps.
Dec 01, 2007 | D-Link DI-624 Air Plus XtremeG Wireless...
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
