Question about Frigidaire Affinity ATF7000E Front Load Washer
14 Cycle Front Load Washer Frigidaire
I just noticed your response to "no spin" I did just wash a medium size bath rug. I cleaned out all the hoses under the machine.
But you had mentioned something about the pump. How would I know if that is working. I can hear the machine make sound like its trying to spin even though its at a dead stop.
thank you
    Novelist:
  • 166 Answers
COLGGED PUMP! CALL SERVICE BEFORE IT COST YOU MORE TO REMEDY THE PROBLEM. do not try to use this!
Posted on Sep 08, 2008
Frigidaire fws747rfs1
The washer tub bearing may be defective, but that is the only thing that I can think of. Are you noticing this on all loads or just heavy items like bath towels and jeans? Are you redistributing the clothes before the final spin, try that. Also do not overload the washer, wash to medium loads instead of one full to the top load. Wastes water but saves on repairs.
Apr 12, 2017 | Washing Machines
How to Troubleshoot a Frigidaire Front Load Washer That Doesn't Spin Read more: How to Troubleshoot a Frigidaire Front Load Washer That Doesn't Spin | eHow.com http://www.ehow.com/how_6496482
Hello - Does the unit make a humming noise? If so, either the drainage hose/pump is clogged and needs to be cleaned, or you have another issue with the door lock assembly or the timer and control board not communicating correctly. Contact a professional to move forward accurately.
Oct 21, 2012 | Frigidaire Affinity ATF7000E Front Load...
Washed some rugs with rubber backing that tore up during the final spin cycle and now the water will not drain or spin
Clean the filter in the accordion hose just before the pump. It is clogged and or materials have reached the pump. You will get an error E 21
PanamaGuy
May 14, 2011 | Frigidaire GLTF2940F Front Load Washer
Frigidaire front load washer. water is not draining out during spin cycle leaving the clothes clean but sopping wet.
It sounds like either your drain hose is clogged or the water pump is inop. If you have washed any rugs or material the may come off and clog the pump that could be the problem.
You can remove the lower front cover ( 2 screws I think) and follow the black rubber hose to where the pump is located on the lower right side when facing the washer. The hose has a spring clamp you can remove if necessary to clean the hose.
Remember to unplug the washer when working on it.
Aug 09, 2010 | Frigidaire ATF6000ES Front Load Washer
Clothes are still very wet after the spin cycle.
sounds like not pumping very well, try cleaning the filter/ pump
Apr 20, 2010 | Kenmore HE2 Plus Front Load Washer
Washer won't spin. Washed bath mats (small) and
Read a post from someone else on this - turned out it works fine, just wouldn't work with the small wet load. I added towels to the bath mat load, washed them, it spins fine. Washed clothes & that worked fine too. Yay!! Not broken. Just not found of small loads of bath mats!
Jan 22, 2010 | Frigidaire ATF6000ES Front Load Washer
After a wash cycle, the letters UE appeared in the timer window..
UE = Unbalance error.
try to use a low spin speed with loads like rugs, and try to get as even a load as possible. (ie: not just one rug) Don't wash rubber backed rugs, as the backing can break up and clog your machine.
Now, if you are successful washing with the lowest spin speed, you can hold the " Spin Speed " button in while pressing on the power button. Release power button. Now release the spin speed button. Now, press the spin speed button until the next higher spin speed from your last successful spin. Press start. Your washer should now pump out and attempt to reach the new spin speed, without adding any water. (usually about a 14 minute pump and spin cycle) Don't expect to be able to spin out rugs at a high spin speed.
Jul 05, 2009 | LG WM2487H Front Load Washer
How to diagnose
Sounds like your motor is blown. That's going to require a repairman.
Mar 31, 2009 | Frigidaire Affinity ATF7000ES Front Load...
Frigidaire GLTR16704 Front Load Washer 417.39012891
Time for a new one.
Sound like you have done the main shaft bearing.
Nov 18, 2017 | Frigidaire GLTR1670A Front Load Washer
GE Washer won't drain or spin
this is something that you can fix even if your not a technical person . first you have to open the washing machine front panel or back panel , second , follow the DRAIN HOSE to where its connected to a little motor, disconnect the DRAIN HOSE , take the LITTLE MOTOR out and clean it out , it could be clogged.
it happen once and find out the person put the BATH RUG SET
to wash , the rug was so old that pieces of a rubber underneath the rugs clogged the drain , so there was no rinse and no spin.
try it , I hope it helps.
Apr 16, 2008 | GE WBSR3140DW Top Load Washer
Frigidaire Affinity ATF7000E Front Load Washer Logo
100 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
