SOURCE: ford transit t350 06 reg how do you wind the spare
USING THE TIREJACK CRANK UNDER THE HOOD, INSERT IT THROUGH THE TUBE ON THE BACK OF THE VEHICLE (HOLE IN BUMBER OR CLOSE BY) TURN TO THE LEFT AND THE CABLE HOLDING THE SPARE IN PLACE SHOULD BEGIN TO DROP DOWN. CONTINUE TURNING UNTIL THE SPARE TOUCHES THE GROUND. TURN THE END OF THE CABLE SIDEWAYS SO IT CAN GO THROUGH THE HUB OF THE WHEEL.HOPE THIS HELPS. LET ME KNOW. THANKS FOR AN HONEST RATING AND FOR USING FIX-YA
SOURCE: type of brake fluid for ford transit
Brake and clutch fluid use the same DOT 3 synthetic brake fluid.
SOURCE: how can i remove the rear bearing(hub) from ford
buy a chiltons manual from autozone or oreillys it has directions in detail just follow steps
SOURCE: hi , I'm driving ford transit
When the light comes on, you will have to take it have it scanned. Parts stores do it for free. Get the code and description and go from there.
