Standard Televisions
Problem for Standard Televisions
Generic problem for all Standard Televisions
TV won't turn on, red light flashes twice
By jelosta on Aug 08, 2008
Tried to turn on my TV this morning. Red stand by light flashes twice and TV makes clicking sound like it's about to power up, but nothing happens. Tried unplugging, did not fix.
Thanks for your help!!!
My sons are desperate to play Guitar Hero! I have same problem with my tv model Sony WEGA trinitron color tv # kv-32fs17 . when I turn power on tv it chirps/beeps and nothing else almost like a car trying to turn over. It flashes four times. Tried unplugging with no luck.
Please help me
Same Problem
May 20, 2009
-   i have the same problem with the big screen i even took it apart to find whats beeping -   Guest
Feb 23, 2009
-   I have the same problem with my Sony triniton. It takes hours before it comes on. The standby light blinks and it clicks as though it is getting ready to turn on, but doesn't. Can anyone help? -   jroc100
Jan 08, 2009
-   i press the button and it starts and it beeps but then if just turns back off and the light keeps flashing -   ramajewel
Jan 06, 2009
-   I've Sony KV32FQ86U. Few days ago, I tried to turn on my TV and red standby light flashes twice and TV makes clicking sound like it's about to power up, but nothing happens. Tried unplugging, did not fix.
Sometimes it powers up after 2-3 hours but once you turn it off, it goes back to the same status as above.
Can anybody help in finding out what's wrong? How it can be fixed?
-   aalibutt
Jan 01, 2009
-   my samsung lcd tv won't turn on either
after 1 year + how can I fix it? please help -   asim_nasim
Best Solution
posted on Jun 28, 2009
Helpful)
paul-hawkins
Rank: Apprentice
Rating: 94%, 4 votes
Fortunately, Sony, of all manufacturers, has built in a diagnostic tool to help you decide what the problem is.
Below is a text on these codes. This is not your model, but the basic diagnosis remains the same. You can count the number of blinks and then look up the problem and solution below:
Sony Blinking Codes
Many of the later model Sony TV's have a built in Self- Diagnosis function. If the timer/standby indicator is blinking, this could be an indication of the problem with the unit. The diagnostic blinking will occur automatically with no action required by you to engage it.
The timing of the blinking you see would be as follows: two to eight blinks (depending on the fault) about a third of a second apart, then pauses for 3 seconds, then the two to eight blinks about a third of a second apart again.
Here is a list of the problems that might have occurred indicated by the number of blinks. The words in parentheses are those which you will see for each of these faults on a diagnosis screen described later in this article.
Unit is dead and there are no blinks---Problem in the standby power section. Might check fuse, R607, Q601, IC601, R612 and VDR601 (should show open)
Continuous Blink Once A Second, No Pausing As Discussed Above---
No reply from the jungle IC301 (data bus is busy, shorted to ground or held high), IK video path is defective.
ONE Blink--- not used for the self-diagnosis
TWO Blinks---B+ over current protection (OCP) , unit goes to the standby
mode then displays the 2 blink fault. Could be a short in the power supply of
any of the circuits.
THREE Blinks---B+ over voltage protection (OVP), unit goes to the standby
mode then displays the 3 blink fault. This is also a problem in the power
supply circuit, check T603 and R672.
FOUR Blinks---No Vert. Deflection (V STOP), Screen goes to a single
horizontal line then the video signal muted. Check IC1509, Q1505
FIVE Blinks---AKB circuit (AKB), the timer/standby indicator blinks for about
30 seconds then goes to the self-diagnosis function. Something is wrong with
the video. Check video out, Q705, 732, 761 and other components on the C
board, also check Q218, 219, 220 on the A board. Also unit be in IK blanking,
try turning up screen slightly.
SIX Blinks---No Horizontal (H STOP), no raster, goes to the blinking selfdiagnosis
function immediately. Check C515 & 516 and the jungle IC, IC206.
SEVEN Blinks---High voltage shutdown. The high voltage has exceeded 33k
and the unit goes immediately into safety shutdown. Check power supply
regulation and horizontal circuits.
EIGHT Blinks---Problem with the audio (AUDIO), unit goes to standby and
blinks the self-diagnosis code. Check IC406 audio amp, PS401 and 402.
Intermittent problems ?? This is a great feature. You can also bring up
these fault codes ON-SCREEN to see a list of the problem numbers with the
abbreviation of the problem and the number of times this problem has
occurred. This is slightly different than entering the service mode. To see the
diagnostic screen, Press the following buttons:
Display, Channel, 5, Vol Minus, ( Not plus ) then Power. This brings up
a screen with a list of the problems and number of times they have occurred.
Each of the problem names is abbreviated as, "OCP", "OVP", "V STOP", ETC.
We have repeated them in parentheses in the text for the "Blinks" described
above so you can correlate between the diagnostic screen and the blink
codes.
So, now that you know about these self-diagnostics, how do you use them?
Say that you have a set with a black screen. You see that the LED is blinking
4 times....This would tell you that you have no vertical and that is why the
video is muted. If it was blinking 6 times, you would know that you have a
horizontal fault.
It's not a sure cure, but it's a little better than a poke in the eye with a sharp
stick.
IMPORTANT: after you repair the unit, PLEASE clear the values on this diagnostic screen. These codes do not reset themselves after the fault is 0 corrected, so if you don't clear them, you'll be seeing "old" fault codes the
next time you enter this screen. Clearing is done by going into the service mode ( display, channel, 5, volume plus, then power ) then press 8 and Enter, which of course returns
everything to the factory preset condition.
As a general rule, the blinking standby light means serious problems and you would be better off getting a technician involved.
This set is a very expensive one and it has some life left in it. Further it is a Sony, so you will be wise to get it fixed.
After studying the blinking codes, let me know if you have any further questions.
Have a great Holiday Season,
Cleggsan
Was this helpful?
Yes
No
3 people thought this was helpful
Popular Solutions for Standard Televisions
Questions and Unsolved Problems for Standard Televisions
Answer
How to find AV Channel on Bush portable tv/dvd player
Answer
schamatic digram crown tv model 21k99 has problem cut off suddualy without reason
Answer
Toshiba TV 14N21B2N (not sure of last character). It worked perfectly, but now I cant turn it on -... (More)
Answer
Can I have the Panasonic TC 21 service mode
6 Other Users Have The Same Problem - Continued
Comment by bryanjennyle, posted on Dec 05, 2008
my samsung lcd tv won't turn on after 1 year + how can I fix it? please help
Describe your Standard Televisions problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Standard... Experts
Top TV Repairmen
in Newbury, OH
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
close
Add to My Products
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
Step 1: Select a category & subcategory
Appliances Cameras Cars Computers Electronics Home Audio TV & Videos Tools
Appliances Cameras Cars Computers Electronics Home Audio TV & Video Tools
Step 2: Select a product and click on add
I can't find my product
select
Cancel
close
Success!
Add another product
Close
close
Save This Product
Enter your email address
We will not share your email. Privacy Policy
I agree to the FixYa Terms of Use
Send to friends
Send to: (e.g. Julie@email.com)
(Separate email adresses with commas)
Your name:
Your email address:
Message:
