Question about Bose Lifestyle 28 System
Non bose dvd player for bose system
I was told that i had to replace the dvd player in my bose system with only that one, it is the "brain" that makes it run and other dvd players would not work. Can i just buy a new blue ray player and use it instead of the bose and all the sound would work fine?
  • bwarren1 Aug 25, 2008
    I have a similar problem, is there any other dvd or bluray player that will work with bose 321 system?
  • labenson56 Oct 30, 2008
    I have a Bose Lifestyle 28 system that was purchased in 2002. It doesn't play home recorded DVD's and an upgrade for just the DVD player is $1,600. Can I buy a different brand of DVD player and hook it up to the Bose system?
In short, you can. I did it last night. My Bose 321 DVD player is junk and it's always been junk, but I love the sound sytem. Last night, after the thing gobbled it's last DVD, I went through the whole, unplug, wait 5 minutes, plug back in, etc. and it still wouldn't eject so I ripped the DVD tray out of the thing with a pair of pliers, recovered my DVD, and slammed the tray back in, stripping all the gears and screwing up the motor in the process.
BUT, I disconnected the video cable from my Bose and plugged it into the video out on my el-cheapo Tru-Tech $99 DVD recorder. Then I ran the audio out cables from the Tru-Tech to the Aux 1 inputs on my Bose 321.
When I want to watch a DVD now, I put the DVD in my Tru-Tech, turn on the Bose, switch it to Aux 1, and I get a great picture and the Bose sound. Best of all, I don't have to plug and unplug that sorry Bose system everytime the wind blows.
They used the absolute cheapest DVD player they could get their hands on--a Toshiba model--for all the Bose 321 older models. Every single person who bought one has had these same troubles and they've made no offer to fix them.
This was my first and last Bose because of that and I hope more people stay away from Bose until they get their act together and protect their customers. $1000 for a system that eats DVDs like M&M's is ridiculous.
Posted on Dec 12, 2008
Bose 321 not recognizing cds
Contact Bose and send your unit back. Most likely the CD/DVD drive needs to be replaced
Dec 06, 2013 | Bose 3 2 1 GSX System
DVD not working "format unsupported". Was told I had to send it to South Carolina by UPS. I need an address. JMC
Make sure it plays in another DVD player. There might be a "Region" setting in the playback menu. Makke sure it's on Region1
Sep 01, 2010 | Bose 3 2 1 GSX System
Can i use a non-bose amp to drive the speaker system from my Bose AV48 system. The original Bose amp and dvd player is too glitchy
Yes you would be able to use a non bose amp. All the speakers should have crossovers in them, If you do start at a low volume first, you can blow your speakers if your amp is too big and volume is too high.
Apr 05, 2010 | Audio Players & Recorders
Bose lifestyle 48 dvd black and white only
Go to the "Bose" menu screen viewing on your TV (make sure no dvd is in the player) Go to your Video controls and check your output, chances are, if your using the component output your player is set to "S-Video". Should fix the problem. Hope this helps. If it's still not viewing correctly, post a comment and I will help you some more
Jul 26, 2009 | Bose Lifestyle 48 System
Had my head unit from a Kenwood kvt-717dvd system stolen
i have a 717 no brain for sale ought at garage sale and was told all i neded were the wires. i had no clue it needs a brain .
May 10, 2009 | Kenwood KVT-717DVD Car DVD Player
Burned dvds wont play on home player
i have begun having a problem with my  4-5 year old bose 321 system.  sometimes dvd's burned on my computer will not  play on my bose 321 system.  sometimes they will.  what's up with this?  it's not a bad media problem.  i've narrowed it to the player.  sometimes i'll play a computer burned dvd on the bose and it will play fine.   next time i try to  play it it won't any ideas? thank you in advance mike
Dec 04, 2008 | Televison & Video
CD stuck in disk tray of (original) BOSE 321
NO NEED TO TEAR APART OR REPLACE THE UNIT! JUST TURN OFF THE UNIT, LEAN IT FORWARD AND A LITTLE DOWNWARD AND HIT THE LOAD BUTTON AND IT WILL OPEN. THAT'S THE TRICK!
Nov 23, 2008 | Bose 3·2·1 II System
Bose 321
yes as long as IDE cables and DVD player fits it shouldn't be a problem
Apr 24, 2008 | Bose (321GS) System
No sound from my TV!! HELP!!
assume its a bose system 12 (non digital or digital ?)
if you clarify the model of both tv and bose system i will tell you precisely how to connect tv to bose system,
but i must assume first that your cable box is connected to your tv via a scart cable , you must remove sound function from the cable and plug directly into cd5 unit on either auxillary or video input , then turn cd5 unit to that channel to play sound and use bose reomte to control volume (ok)
i would doubt thatthe TV has a audio output, many dont.... also it may be necessary to buy a scart to RCA cable at your local electronics shop or supermarket to completet he task at hand.
if however you are digital.....
make sure you are connectiong bose digital input to a digital (dolby 5.1 compatible) sound source.
sorry if you think i have over simplified the problem !
respect
Dec 02, 2007 | Bose Lifestyle 12 System
Problem with sound skiping on Bose Lifestyle 8
would not exactly agree with bose proposed solution, however easy to test......
borrow a dvd palyer of a different model and type , ensure that the output from the dvd player is set correctly ie. 5.1
you need to verify that the co ax you are useing is not damaged, faulty and is connected both ends correctly,
if bose give you some hassle get a spare set of cable to be sure the connect or to the co- ax is not damaged in any way.
lastly :
i suggest there is a problem with the on board decode for dolby 5.1, known as SPDIF = "S P diff " ( a system designed in conjunction with SONY and PHILIPS and used on nearly every 5.1 decoder sold in the world) easy to fix its usually a firmware upgarde or reset usually done in the factory, simple problem, could have been caused by electrical interference or unusual magnetisim problem post manufacturing or possible on site problem, however from your point of view impossible to prove either way.
must point out that analog cables don't carry a 5.1 signal. and also should point out that co -ax is not 100% necessary nor the only way to push a 5.1 signal into that bassbox.
check your cables first , then borrow a dvd player, then bring it back to bose and tell them to fix it. if its still wrong.
Oct 10, 2006 | Bose Lifestyle 8 series II System
Bose Lifestyle 28 System Logo
1,573 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
