Question about Xerox WorkCentre Pro 123/128 Printer
Card Stock will not print
Whenever we insert card stock into any one of the trays and change the internal settings, it will not print on card stock. Any suggestions?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Xerox Master
  • 1,362 Answers
1-try both sides of the card stock
2-try the manual by-pass and see it that works
if it works then there could be a problem witht the main board
when you change the setting it changes :the temperature, the pressure on the rollers, and a few other thins, because of the wieght of the paper.
Posted on Aug 08, 2008
6ya staff
SOURCE:
I am trying to print a card on 110# card stock and it gives me a paper jam. Is there a way to adjust the printer for heavy paper? my printer is a brother MFC-J5910DW. Any suggestions?
Your machine should be able to handle a 110gsm card stock. In your computer printer settings you should be able to change the paper type to either card or heavy/ thicker paper. If the card stock is quite stiff your machine will not be able to bend it around the paper feed roller regardless of your print settings.
Sep 11, 2018 | Brother Office Equipment & Supplies
Duplex printing with card stock paper jams in back on Brother MFC-9840CDW
I would try manually inserting the paper for the back side. Most of the time it's best to wait a few minutes before trying the back side to give it time to cool so it will lie flat.
Sep 08, 2017 | Brother MFC-9840CDW Laser Printer
I have an HP Photosmart A646 printer that I bought in the hopes of printing to 5x7 card stock. We have pre-printed card stock that we use for gift certificates and we need to be able to feed the card stock...
Thanks for visiting FixYa!
Depending on the program you are using to print your gift certificates, try this-
1) Open the program and open the file you use for your gift certificate.
2) Click on 'Layout' then 'Page Set Up' (probably found in the top menu bar by the right side of, FILE.)
3) Select 'Landscape' and then select, 'Custom'.
4) Enter 5x7 for height and width.
5) Enter the information you need in the data field, (ie, name address, etc.)
6) Select, Print.
7) When the 'Print Manager' box opens, click on, 'Properties'.
8) Click on, 'Type' and choose, "Envelope'.
9) Click on, 'Size' and choose 5x7. - and click, OK.
Your printer should have a slide where the paper is inserted. Place one of the 5x7 cards in the slot just as you would an envelope and slide the slider until it is 'close' to the card but not directly against the card.
Click, 'Print'. The printer should recognize the card (due to its thickness) as an envelope and print it.
Mar 19, 2011 | Office Equipment & Supplies
Paper jams with thicker stock paper
Your pickup tires on the printer may be worn, how many prints have you made on this printer. it may be time for a maint. kit.
May 31, 2009 | Brother MFC 210C All-In-One InkJet Printer
Information on how to use rear feed
1. Prepare your doc/file for printing.
2. Insert card stock with narrow side of stock in slot in back of printer until it hits rollers and stops. Don't force in any card stock thicker than max. rated.
3. Change printer setup to feed from rear.
4. Print.
Depending on what software you print from, you may need to change this each time you print if you intend to keep printing from that "tray."
Mar 09, 2009 | HP Deskjet 1120c InkJet Printer
I have a Dell 946 printer and Im trying to print Avery 8871 business card sheets. When I press print the printer will not feed the sheet through and it says there is no paper. I tried to adjust the...
I looked up the user guide at Dell's website and looked up printing cards.
  • The print side of the cards faces down.
  • The cards are centered on the paper exit tray.
  • You select Automatic, Normal, or Photo print quality.
  • Apparently you need to feed the card stock one page at a time into the printer on TOP of the paper exit try (The card stock will feed in from above the normal paper load try [remove paper from the paper tray] and once printed come back to the same spot.
    Jan 26, 2009 | Computers & Internet
    Blinking yellow light
    I m not sure what the specification of the paper type you are using however if you are using card stock than you should use manual feed Tray and in the printer driver properties you should select paper type as Card-Stock to make sure there is no print quality issue.
    Nov 30, 2008 | HP Color LaserJet 2550n printer + HP Color...
    Wont print on card stock, legal paper- keeps jamming
    Menu> scroll to Paperhandling> MP Tray type>>(plain) try changing this to cardstock  <enter>
    instead of MP Tray type do the same for Cassette if you desire....
    Best, danakadan
    Oct 11, 2008 | Kyocera FS-1030D Laser Printer
    Printing on Card Stock
    Hi Harold,
    Most laser printers automatically adjust not the temperature so much as the speed at which the media travels through the fuser when thicker stock is used.
    The important thing here is to make sure that when you are using card stock that you insure that the printer is set for the correct "PAPER TYPE" from the tray you are using.
    When the paper type is set to card stock, you should notice that the media will print somewhat slower, thus giving the fuser the ability to achieve the correct fusing temperature through the thicker stock.
    Good luck
    Oct 09, 2008 | Konica Minolta PagePro 1350W Laser Printer
    Xerox WorkCentre Pro 123/128 Printer Logo
    275 people viewed this question
    Top Xerox Office Equipment & Supplies Experts
    Clive
    Clive
    Tareq Bin Mostaq...
    Tareq Bin Mostaq...
    Philip Hughes
    Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
