When I insert the slide
The problem is with a VuPoint Slide scanner.
When I insert the slide try into the scanner, I used to see the image, then click "snapshot" and transfer to Photoshop. I could be sure the slide was centered.Now I don't see an image until I click "snapshot" and then I can't align the image like I could before.Is the machine broken?
  • Paul Harris
    Paul Harris Aug 09, 2008
    Thanks for your help. This gives me the information that I need to contact the store where I purchased the item. I will ask for a replacement.
  • 6,487 Answers
What is the brand and model of this unit? so we can help you better...
Posted on Aug 08, 2008
  • Mark Gil
    Mark Gil Aug 09, 2008
    The film holder and alignment mechanism can be already damage because as I check this device it has a lot of negative feed back about that alignment mechanism that can easily be damage so if you can contact the manufacturer for any fix or you can have it repair or replace from them it will be better..
    Good luck...........
Does google docs have insert from online capabilities
Add an image
  1. Open a document, spreadsheet, or presentation in Google Docs, Sheets, or Slides.
  2. Click Insert Image.
  3. Select from the following options:
    • Upload: Choose an image from your computer and click Open.
    • Take a snapshot: Use your webcam and click Take a snapshot.
    • By URL: Paste the URL of an image from the web and click Select.
    • Your albums: Choose an image from one of your photos albums stored on the web and click Select.
    • Google Drive: Choose an image stored in Google Drive and click Select.
    • Search: Choose an image from the stock photography archive, or the Google and Life archives, and click Select.
  4. Your image will be added to your file.
Image size and format requirements
images must be less than 50 MB and be one of the following file types:
Delete an image
  2. Select an image.
  3. Press the Delete or Backspace key on your keyboard.
Aug 19, 2017 | Google Computers & Internet
How do I get a Blow up (say 150%) PDF snapshot view of an image to print from A3 not A4 print tray
Hi Paul,
I would try and insert the PDF as an image to Powerpoint, crop the image to your desired proportions, scale it up to your preference, then print the Powerpoint slide on A3. Alternately, print the slide to PDF, then print.
Good luck
Feb 22, 2015 | Office Equipment & Supplies
Scanner doesn't recognise their is a slide loaded in the slide holder
The first thing I'd try is to run the scanner with the Nikon software. When you power on the scanner it goes through a variety of checks, and finally you should have a silent scanner with a solid green light at the front. Start the Nikon software and wait until it finds the scanner, if it doesn't you have a hardware problem with the scanner.
If it goes well to this point insert a card or plastic mounted slide and hit Preview. The scanner should then create and image you see on screen. Next step would be to make a scan. If the slide you're trying to scan isn't card or plastic mounted you'll need the Nikon made carrier.
Hope this helps.
Mar 22, 2014 | Nikon CoolScan V ED Film Scanner
HP scanner is missing. Unable to scan slide.
The ArcSoft PhotoImaging suite is just to process and scan images, but the printer hardware itself needs hardware drivers, which contain coded instructions to communicate with your CPU.
This is the HP scanning software.
Printer/Scanner hardware should have a driver setup disk that came with it.
If you have this disk:
shut down PC
unplug printer
boot PC
uninstall the current version, if in start>control panel>programs
restart PC
install driver from disk or downloaded driver file for your model.
Regards, Clive.
Nov 21, 2017 | VuPoint Office Equipment & Supplies
Where is the battery compartment on the vupoint magic wand scanner
this link should take you to a user manual............
http://www.manualsdir.com/manuals/221213/vupoint-solutions-pds-st410a-vp.html?download
but you should be able to slide the battery door down towards the bottom and then replace the two AA batteries.
Jan 02, 2014 | VuPoint PDSST410VP
Installed the JB5323 Jobar Slide & Negative Scanner into a Window's 7 Professional contained in my Dell and it will not give me all the different things it has. It won't convert the negative...
You don't need any special software or hardware to do this, and it's really easy too! Open one of the saved image files of the negative scan using Microsoft Paint. It's under Start -> Accessories.
Now click select in at the top, and then right click anywhere on the image. At the very bottom of the menu, there should be an 'invert colors' option. Click it. Your negative should now be a normal picture =).
Sep 10, 2011 | VuPoint FSC1VP
I need a manual for an fc-c520 VuPoint digital film and slide converter. Any suggestions where I may locate one?
You can download the manual from the manufacturer's web site at
http://127.0.0.1/Manuals/VPS09-0202%20FC-C520-VP%20Eng%20manual.pdf
Feb 28, 2011 | VuPoint FSC1VP
Can't open battery door
To open the battery door, simply slide the silver bar behind the scan button back (away from the scan button). Apply a little force, and it will click open.
Hope that helps.
Marcus
Nov 02, 2010 | VuPoint PDSST410VP
How do you remove the top of the Magic Wand Portable Scanner to install the batteries for Vupoints model # ST415 magic wand?
The battery cover is the silver-colored "hump" on the right side of the scanner. Just slide it to the right, and it'll unhook from the scanner, giving you access to the battery compartment.
Oct 05, 2010 | VuPoint PDSST410VP
Just installed a VuPoint Solutions Fs-C1-Vp Converter. When a slide or negative is inserted, a black screen shows up on the ''live view'' screen. When we transfer, a totally black image is saved on the...
how do you put a SD card into the vupoint slide converter
it has a white plastic thing preventing the SD card from going in and i cant pull it out
Jun 15, 2009 | Office Equipment & Supplies
jasbo
jasbo
