Question about Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
My washer keeps flashing f-21 and water coming out, I took some clothes out than started a new load a smaller one and now it will not even run. HELP!!
    Problem Solver:
  • 8 Answers
If you take the screws off of the foot plate and remove the foot plate on the back is a plastic bag where the codes can be found..... both washer and dryer are located there. good luck.
f21 long drain.
Posted on Aug 14, 2008
IWL16 leaks from the top during spin cycle, black specs on clothes
Try running running it MT on smaller load setting a few time,s then do a smaller then you had been doing load of close. I belive yr getting or have got.water.past the.shaft seal,s. So maybe wth smaller load.inclueding.water setting you may see some change i.e. no more black speacks. Sorry.about my spelling. Am.still new
Nov 10, 2013 | Fisher Paykel Eco IWL16
Clothes come out dirty in front loaded washer
Check the level sensor at the rear of the drum.
May 16, 2017 | Whirlpool Washing Machines
Washer does not spin water out of clothes
Does the water all pump out? If it does and not spinning could be your belt slipping or two many clothes it it. If it doesn't spin out even a smaller load then it is more than likely the belt.
Nov 26, 2011 | Kenmore 24032\24036 Top Load Washer
F28 error / water starts to fill then quits in 15 sec's
F28 is a communication error which usually means there is a connection that has come loose.Check the wires on the control board.
Nov 22, 2010 | Maytag EPIC MFW9700S Front Load Washer
Washer will not spin clothes dry...full of water and wont work. f-21 keeps flashing.
your drain pump is clogged,So the first thing you need to do is,Push the start button again you well hear the machine come on you well hear the pump its trying to drain after about 30 seconds,It well shut off,so push button again watch the machine when the water goes down a certain level.The clothes well start to spin. Now after they get done spinning,push the cancel button.you should be able to hear the door unlock,remove the clothes.Now put Draino Max gel or Rooto-Routor gel in tub of machine and let it set for about 1-2hrs.Now star cycle on heavy-duty wash hot water,it may take a couple of times but it well clean your machine don't mix any othe soaps or bleach during this time. then rinse machine out again to get rid of gel.see if this work for you,are machine does the same thing,its because of dog or cat hair,or something was in a pocket like tissue,or strings from clothes.thanks
Jul 29, 2010 | Kenmore HE2 Plus Front Load Washer
Washing machine lint trap
There is no trap per say. The lint catcher is self cleaning when the water is pumped out. It sounds like you are overloading it and the clothes are hitting the agitator. Operation should be agitation by water movement not beat by the plastic fins, run a wash cycle hot water no clothes to flush things out and try smaller loads.
Eric
Mar 14, 2010 | Kenmore 22622 Top Load Washer
Regarding the kenmore he2 plus front loader washer.f-21 keeps coming on.actually worked for a couple loads today but f-21 started coming on again after i started washing a 3rd load of colored clothes.seems...
There is a strainer on the drain pump that is clogged. The manual does not mention this at all, it merely states the drain hose is kinked or clogged.
Under the front door there is a panel that is the width of the machine and is held in place by two screws, one on either side.
When you remove that you will see the pump and the the strainer attached to it. Unscrew the strainer (put a small pan under it to catch excess water) and remove to remove the junk accumulated.
Also, attached to the panel is another manual that refers to the error codes you are seeing.
Dec 20, 2009 | Kenmore HE2 Plus Front Load Washer
Code error problem
THIS IS TEMPORARY FIX, NOT A TOTAL SOLUTION. jUST TO GET WATER TO DRAIN AND RESET WASHER. , WITH WASHER POWERED OFF, PUSH AND HOLD START BUTTON FOR 4 SECONDS, RELEASE FOR 4, PUSH FOR 4 RELEASE FOR 4 UNTIL THE FRONT ALL LIGHTS UP AND DISPLAYS 88. sOON YOU WILL SEE YOUR CODES FLASHING, PRESS START BUTTON AS MANY TIMES NEEDED TIL NO MORE CODES FLASHING. tHEN WASHER WILL GO INTO DIAGNOSTIC TEST. aFTER THAT I DO NOT KNOW, BUT YOU CAN WASH 1 LOAD OF CLOTHES AND THEN PERFORM DIAGNOSTIC TEST AGAIN. THAT IS WHAT I AM DOING JUST TO HAVE A WORKING WASHER TOO MUCH TO FIX FROM WHAT I AM READING, SO GOING TO BU A NEW ONE ANYTHING BUT KENMORE. gOOD LUCK, HOPE THIS HELPS FOR IMMEDIATE RESCUE.
Jul 24, 2009 | Kenmore HE2 Plus Front Load Washer
LG WM2077CW (UE error code)
For "ue" an unbalanced load is sensed three times; re-adjust your load in the machine. What is the capacity of your machine, you could weigh your dry clothes........refer manual.
For e1, it could be a water sensor problem. Check to see if the inlet valve is okay and not clogged, water shd be in good pressure. If this is okay, open up behind after taking the plug off the wall. There is a thin tube coming from the switch area to the outlet pump area; disconnect this from the top carefully and blow into it, it should be free; if it is clogged you will hav a water level problem. Unblock and refit carefully.
.....& rate me if helped.
Jan 09, 2008 | LG WM2077CW XL Front Load Stackable Washer...
Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer Logo
80 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
