Question about OKI Pacemark 4410 Matrix Printer
Oki Pacemaker 4410
I am getting a message that reads "Offline Rear Paper End" and I don't know how to get it back on line to print. Can you help?
I assume you are trying to use the front path? If so simply press PARK and then press the PATH button to change it back to FRONT FEED.
When it runs out of paper it changes paper paths automatically looking for more loaded paper (AUTO-PATH feature).
Anyway, that's what happened to us.
Posted on Feb 16, 2010
Paper needs to be a little lower when it prints, it;s printing too high
hi,press the offline button , manually turn the paper feed knob back a few clicks then press the set button and remember to switch the printer mode to online
hope this helps
Apr 28, 2010 | OKI MICROLINE 390 Turbo Matrix Printer
PACEMARK 4410 - FRONT FEED LETTERS INCOMPLETE
run a diagnosis trest and a print alignment application to currect that. check the print roller for any particle that could be trapped inside.
Aug 18, 2009 | OKI Pacemark 4410 Matrix Printer
Printing too far to the left, the stops are set as far to the right as possible but the text is still printing too far left. rear feed.
I'm trying to print a letter and everytime I do it prints too far to the left and cuts off some of the print.
Jul 15, 2009 | OKI Pacemark 4410 Matrix Printer
OKI 24DX - Press ONLINE button to print each page
you have to open your printer icon in CONTROL PANEL
CONTROL PANEL
THEN
PRINTERS AND FAXES
RIGHT CLICK ON YOUR OKI PRINTER
select PREFERENCES
under SET UP and MEDIA size change it to A4
I think this might help you. I'm guessing that you have the wrong size paper selected. And each time the computer needs you to confirm you want to print with a different size paper
I wouldn't phone OKI help line..I was on hold for 15 minutes, then just gave up.
Jul 01, 2009 | OKIPAGE 24 Led Printer
Paper jam when there is no paper jam
R300 Epson stylus says paper not set correctly yet it is. Any recommendations
Jun 16, 2009 | OKI Pacemark 4410 Matrix Printer
Oki C9300
What is the status of your fuser unit and on what paper settings are printing on? When last have you cleaned tour machine?
May 23, 2008 | OKI C9300 Led Printer
Printing
Dear jamin4volks;
As per this excerpt from the Oki B4350 User manual:
"FACE UP AND FACE DOWN PRINTING
For face down printing, make sure the rear paper exit tray is closed (the paper exits from the top of the printer). The paper exit bin on the top of the printer stacks printed pages face down, capacity 150 sheets of 20 lb. paper. Pages printed in reading order (page 1 first) will be sorted in reading order (last page on top, facing down).
For face up printing, make sure the face up rear paper exit tray is open and the paper guide is extended if required. In this condition, paper will exit via this path, regardless of driver settings. Paper is stacked in reverse order, capacity 50 sheets of 20 lb. paper.
Always use this tray and the manual feed tray for heavyweight stocks to reduce the possibility of paper jams."
This manual is available at http://my.okidata.com/mandown.nsf/(MOC-B4350)/BE70FCAF93D577E285256E89005052F9?OpenDocument
Hope this helps;
Frank
Apr 18, 2008 | OKI B4350 Laser Printer
Printing with 190gsm paper
Max paper weight is 203gsm so you are near the upper end of specs, you must feed via manual pass and exit from face up tray (out of rear), paper type(heavy/card stock) must be set on print driver. User guide can more than likely be found www.oki.com.
Dec 31, 2007 | OKI C5200n Laser Printer
Abnormal printing with continuous tone
this sounds like it is doing something called a "hex dump" basicaly printing all ASCII characters. okis tend to do this from time to time if l;eft on for a significant period with no data sent to it. the only advice given by oki is to switch it off when not using it unfortunatly Hope this helps Cops Pete@wedotoners.com
Oct 08, 2007 | OKI Pacemark 4410 Matrix Printer
OKI Pacemark 4410 doesn't print it correct spots for some forms
I found the service manual for this, which should come in really handy for you when performing maintenance on your printer (which is most likely what you need to do to the printer) http://www.feedroller.com/Store/Service%20Manual/SER4410.PDF Funny thing is that there are a lot of people trying to sell these manuals, so I'd save this one for future use (it might not be on this link for long)
Mar 29, 2007 | OKI Pacemark 4410 Matrix Printer
OKI Pacemark 4410 Matrix Printer Logo
524 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
