Question about AEG Lavamat 16810 Front Load Washer/Dryer
AEG 16830 - WASHER DRYER, ERROR CODE (E94)
Our washer dryer has started to flash E94 and is not working.
The code E94 is not referred to in the users manual, so any help would be appreciated.
The actual product is noted as and AEG electrolux 16830.
5 Suggested Answers
SOURCE: AEG Washer dryer will not complete cycle
I ended up trying the machine on a few different cycles all of which failed to complete. Finally tried a 'Drying' only cycle and it emptied out quite alot of water which was odd. It now seems fine. guessing it was a blockage and a certain amount of water was backed up in the machine??? any clarity welcome.
Posted on Mar 25, 2008
  • 1294 Answers
SOURCE: AEG Electrolux washer/dryer is not
Check your exit hose spigot, it may be clogged. This is if your filter is all clean (ref users' manual). There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it, six inches maximum. Snaking out your standpipe would be good too.
Rate me pl.....if helped. Click on 'thanks for trying' if not helped, your prob will be back for someone else to solve.
Posted on Jun 04, 2008
SOURCE: My AEG Lavamat 16830 Washer Dryer does not heat up
Had an identical problem with my 16830 washer dryer and noticed reading other posts that others have had this issue with 16810 units too. After reading posts about the 'condensor issue' causing clothes not to dry properly I got a socket set and took the back-half cover off the machine (11 screws/hex screws in all) to have a look. I then removed and cleaned out the accumulated fluff from the transparent plastic condensor unit. It didn't appear to have much fluff caught within it so I doubted that this would solve the issue.
Upon putting the unit back into situ I noticed that the temperature sensor in the large black flexible tube that connects the condensor to the drum had just one orange wire attached to it. I then noticed a second orange wire hanging loose nearby and putting two and two together figured that the loose wire had dropped off the sensor. Since the connector can't be rewired I resorted to carefully soldering the loose wire to the connector and ty-rapped both orange wires to the connector to prevent the wires working loose again. Once I had the connector back on the sensor both wires were pretty taut between the main wiring loom and the sensor and so I suspect that what had happened was that in normal use the wire had come adrift from the connector due to the drum rocking back and forth and pulling the wires against the loom - a design flaw I'd say.
To create more slack for the two wires in question I cut the ty-rap holding the main wiring loom to the side of the dryer and then re-fitted a new ty-rap in exactly the same place around all the wires in the main loom except for the two orange wires so that they remained free of the main loom to move as the drum rocks. With the wire back in place and everthing re-assembled the dryer heats up perfectly and counts down as it should.
I figured that with the sensor not operating the computer determined incorrectly that the air leaving the drum was too hot/dry as would be the case if the contents of the drum were completely dry and as a result the computer turned off and kept off the heater for the remainder of the drying cycle. I also concluded that as an energy saving feature - with the computer thinking the clothes are dry - the dryer speeds up the remaining drying time so that the drying cycle finishes sooner, hence why the counter completes sooner than it should and all with no error message.
Hope this is of help to others.
Posted on Apr 01, 2010
SOURCE: AEG Lavamat 16830 washer dryer
can anyone tell me how to remove the rear panel of a AEG lavamat dryer. regards Roy
Posted on Apr 08, 2010
SOURCE: the door handle of my AEG Lavamat turbo 16830 is
Hi there, we too have a similar problem. Our new door handle part has arrived but we are having huge problems fitting it as we cant prise the grey outer trim off the door and thus can't get in to put the new door handle in.
Please help! How can we get the trim off without resorting to serious damage with a screwdriver!!!?
Posted on Jan 23, 2011
How do i reset aeg washer dryer with an e 10 fault
You can try this and see what happens
Turn the dial to off.
Then press and hold the start button and the button to the left of it.
With them 2 held in turn the dial 1 click clockwise.
Keep the buttons pressed in till the lights flash then let go.
Know turn the dial clockwise 1 click at a time till you round to the off position.
Then TURN THE DIAL ON THEN OFF.
Read more: http://www.justanswer.com/uk-appliance/54e9d-reset-code-button-combinaton-aeg-16830-washer-dryer-getting.html#ixzz3QIkCz720
Jan 30, 2015 | AEG Washing Machines
Error E51 on AEG T59840 Condenser Tumble Dryer
Try referring this issue to AEG and/or an appliance parts supplier.
Nov 10, 2013 | AEG Dryers
Aeg lavamat turbo 16830
start at the beginning,, check your fuse
Jul 16, 2013 | Washing Machines
AEG Lavamat 76810 E70 7Beeps Does seem to still work but display shows E70 and 7beeps over and over. Many thanks gary
I Have AEG Lavamat 76810 E70 7 Beeps and Beeps never stops
The water was not hot
I took all the multi-plugs out and put them back in the whole machine ALL CONNECTORS
Now it works fine E70 is gone
Jul 14, 2011 | AEG Lavamat 16810 Front Load Washer/Dryer
I have an AEG Electrolux 16830 - I get an error code E10 - pressing the start switch recommences the program and it completes as normal. How do I reset the machine so this does not happen. An engineer...
E10 indicates that the water inlet hose is squashed or kinked.
First check the filter for coins or other junks.
Make sure the drain hose isn't blocked, restricted or kinked.
Hope this helps.. Good luck! ;)
Thanks for using
FixYa - a 4-thumbs up rating is greatly appreciated for answering your free question
Jun 06, 2011 | AEG Lavamat 16810 Front Load Washer/Dryer
AEG Lavamat Turbo 12830 - error code E20
Hi
E20 means there is a bolckage in there
remove filter and clear any debris in there and check impeller is turning ok.
regards
Mar 21, 2009 | AEG Lavamat 16810 Front Load Washer/Dryer
AEG 16810 UPGRADE WASHER DRYER E10 ERROR
This is worth posting in case anyone else has the problem. The mechanic was stumped and then around 3 days later a Zanussi gave the same problem - steam emitting from the drum. He changed the valve - the entire unit. Problem solved. Zanussi and AEG have identical internals. He changed our valve - problem solved.
Jul 22, 2008 | AEG Lavamat 16810 Front Load Washer/Dryer
Jul 20, 2008 | Washing Machines
Mar 24, 2008 | AEG Washing Machines
AEG Lavamat 16810 Front Load Washer/Dryer Logo
409 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Richard Roth
Richard Roth
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
