Question about Evesham Voyager 5800 Notebook
Flat Battery Thanks for info. I have tried disconnecting and reconnecting and I have tried refitting battery but no good. When computer is switched off with power connected amber light is on but not flickering. When computer is switched on, as it is now amber light is off. Battery area is cold but underneath of laptop feels warm.
    Sergeant:
  • 395 Answers
Can you run the notebook on the battery at all ?
try this software if you can
http://www.passmark.com/products/batmon.htm
Posted on Aug 08, 2008
I owen holden cruze 2lt turbo ive replace the battery it runs for about a minute then shuts off wont start again
Hi Did you by any chance have ignition swithed on when you refitted new battery? If so disconnect negative terminal at battery for about 5 minutes all modules will go to sleep and reset (ign off) reconnect battery and try again. If that does not work you will need a fault code reader. It is advisable to connect a fault code reader 1st however as you have already disconnected the battery it has probabley lost any fault codes anyway,Good luck
May 29, 2016 | Holden Cars & Trucks
Why is the abs and awd lights on
Most likely ABS/AWD SENSOR ON ONE OF WHEELS IS BAD OR DISCONNECTED. DID YOU RECENTLY HAVE a flat and put the doughnut tire on this is a different diameter and changes speed reading on that sensor try reset disconnect ground on battery wait 15 sec. Reconnect May bogus reading in computer,good luck
Aug 16, 2014 | Buick Rendezvous Cars & Trucks
Audi A6 MMI not working after disconnecting battery
TRY DISCONNECTING THE BATTERY FOR AT LEAST 5 MINUTES . LET ALL REST . RECONNECT THE BATTERY AGAIN AND CHECK . IF U STILL HAVE NOTHING LET ME KNOW!!!
Apr 05, 2014 | 2009 Audi A6 2.0
I just had a new altinator and a battery put on it it will run while the battery has charge but as soon as the batterys juice is gone it wont run unless u have jumpers on it. Took it 2 advance and they...
Sounds like a later model with computer controlling the output and this is faulty ,now one of the wires on the back is for the warning light in the dash so disconnect one of these thin wires at a time to locate the warning light control ,then refit the warning light wire and disconnect the other other one ,now what you do is to run another wire from this terminal to a 12v ignition switched feed in teh fuse box wrap wire around leg refit fuse and with engine running disconnect battery and it should keep running if its working ok as the alternator is now battery sensed and not computer controlled ,easy just like an older car without all this fancy electronics which can and does go wrong
Mar 18, 2011 | Ford Escort Cars & Trucks
Battery was flat, removed it to charge and since refitting the alarm keeps going off and i am unable to stop this. please help
Disconnect the battery again... Have someone hold the VALET switch under the dash on the LH side depressed with the car door open and then have a 2nd person reconnect the battery. You should be able to start the vehicle after that.
Kelly
Jan 11, 2011 | Peugeot 405 Cars & Trucks
What is stability control? light came on
Hi
Sounds like usual gremlins kicked in to your computer, with the flat battery.
Disconnect both terminals of the battery, switch on the ignition to start position 6 times, to clear the computer memory.
Reconnect Positive terminal + then Negative --- and start engine, and check it out.
I am pretty sure it will not come back on.
Also I suggest you get the battery tested soon as possible.
( Is it the original battery ?) If so, its shot !
Good Luck !
Please give me a FixYa rating please !
Let me know how you get on .
John.
Feb 03, 2009 | 1997 Jaguar XK8
04 pontiac grand am battery light
Try disconnecting battery for about 10 mins. or have vehicle scanned and codes cleared
Jan 25, 2009 | 2004 Pontiac Grand Am
2001 mits montero ltd, rechrgd battery & reconnect-alarm goes off
by a cheap amp meter from your local electrical shop should not cost any more than $20, disconnect negative terminal from battery and put the amp meter in between the negative post and the disconnected terminal you will find that there is a number apering on the amp meter eg. 2 amps start pulling fuses one at a time and see if the nomber drops ( always refit the fuse after you pull each one our you may have problems later working out what fuse gos were) when the nomeber dose drop you have found the circut that is at ault and you can make the choise of operating without this cercut or fixing it
good luck
Nov 29, 2008 | 2001 Mitsubishi Montero
Engine immobiliser fault light on after battery flat
There might be an immobiliser fault or a problem with the key transponder but try the following before you call the dealer or local auto locksmith.
Disconnect the battery and leave overnight. Next morning open the car, put the ignition key in and switch on the ignition - then connect the battery.
Sep 17, 2017 | Vehicle Parts & Accessories
No power, car won't turn on just had it on accessory a few minutes ago and it was fine, now it won't do ANYTHING. Could it be the fuse box? Battery shouldn't be dead... Thanks!
If Battery checks out ok,try resetting the body computer,with key out of car,disconnect battery wait 3 mins,then reconnect and wait 30 secs, then switch lights on then put key in and turn ignition on.
Jul 28, 2008 | 2003 Pontiac Vibe
Evesham Voyager 5800 Notebook Logo
57 people viewed this question
Top Evesham Computers & Internet Experts
Lakshman P
Anwarul Haque
Anwarul Haque
Are you an Evesham Computer and Internet Expert? Answer questions, earn points and help others
