For usb i can attach a laser printer in usb and also i can print from it but i can work with this usb socket for to work with pendrive. i have install its driver but yet i cant do it. i m using windows 98 os
    Master:
  • 788 Answers
Try a generic USB mass storage device driver such as this one: http://www.technical-assistance.co.uk/kb/win98se-usb-mass-storage-drivers.php
Make sure you have the Second Edition of Windows 98 (Win98 SE). Pendrives will not work at all with the first edition of Windows 98 or with Windows 95.
Posted on Aug 08, 2008
Dell latitude d630 laptop - os xpp
You are a little confused. The ethernet cable will not fit into the USB socket. Do you mean that it is connected with a USB cable? Is the printer on, with paper loaded and the tray pushed right home? A bit unusual for an HP to jib. Make sure that all cables are well and truly home.
Dec 28, 2013 | HP OfficeJet 6310 All-in-One Printer...
Brother HL 5240 Laser Printer Hi I hope you can
Hello
You need to re-install drivers of the printer. also check the USB cable.
Good Luck
Jan 07, 2011 | Brother HL-5240 Laser Printer
How to insttroal print drivers
Insert the printer software to the cd drive and the software will detect your printer connecting to your pc and it will ask you to start installing the software. Just click the icon install and it will run the installation. Note that if you are using parallel port and directly attached to your computer, you can immediately print after the installation is finish. But if you are using USB port, sometimes it require USB driver before the printer is working (there will be a message saying printer not detected). For network printer set up. you need the same installtion plus need to configure the printer network setting before printing.
Nov 23, 2010 | Lexmark E250dn Laser Printer
Getting a online error and printer won't print.
Without knowing what online error, it's not easy to diagnose what happened and how to compensate.
Anyway, try checking the printer cables to ensure they're connected and properly seated. Verify that the paper tray is correctly loaded and the Toner light is OK.
Verify that all printer covers are flush and closed, and check that the printer is correctly connected at the software level (i.e., in Control Panel -> Printers -> (ML2010) -> Right Click -> Properties -> Ports, you have the proper USB socket selected).
Try plugging it in another USB port. Did it stop working, or did it never work? If the latter, then the driver could be incorrectly installed; try removing it and installing again.
Oct 27, 2009 | Samsung ML 2010 Laser Printer
Resetting Printer
Can you print internal pages? If yes then you know the printer is okay.
Is this a new setup or had it worked before? Will it print from a different program? If yes, then you know it is either the program you're using or the specific document.
How is it attached (e.g. USB, Network, etc)? If USB make sure it's directly attached (i.e. not going through a hub, keyboard, etc.) If it works directly attached then the problem lies with whatever you had it plugged into.
Jun 17, 2009 | Lexmark T640 Laser Printer
Canon ImageClass MF6550
Does it recognize the device being attached (usb being plugged in)? If not uninstall and reinstall printer software and drivers
Apr 25, 2009 | Canon imageCLASS MF6550 All-In-One Laser...
Printer doesn't work
it seems to me that you might gotten the wrong driver install in your system.
error page - Position: )x42b (1067) System: h6fwaim_mono/xl_image Line: 132 Version: QPDL 5.04 04-25-2005
do a check on your OS version. Operating system. right click mycomputer icon -> properties.
download the correct version of driver from Samsung website again. uninstall the currect version and unplug the usb cable to the printer.
restart your system, install the downloaded correct version and plug in the usb cable to the printer. do a custom install to serach for the printer. if it does search the printer. it will show you. USB001. after install you will be prompt to do a test page. test on it to see it works.
if it does not work after downloading and install the driver. You might have a mainboad firmware corruption.
to run a firmware update is not easy it might course other major issue. only install by an trained Samsung Engineer.
Hope this Help :)
SamsuTech
Sep 20, 2008 | Samsung ML-2510 Laser Printer
Laser Jet 4 plus can't print with USB?
1.check the cable compatibility
2.install the driver HP laser jetIII
Sep 05, 2008 | HP LaserJet 4 plus Printer
Computers & Internet Logo
311 people viewed this question
David Payne
David Payne
