Question about Canon Office Equipment & Supplies
Have changed cartridges now it keeps saying check ink the cartridges are new and have been installed correctly
  • 446 Answers
You might want to reset the whole unit, if you correctly install the right ink this should work perfectly
Posted on Aug 08, 2008
The printer saying the new ink cartridge need to be changed it want print
Verify you have installed the ink cartridge correctly and that the cartridge you have is the correct one for your printer.
Feb 16, 2015 | Office Equipment & Supplies
Keeps saying install c
When the printer says "install C" it is referring to the Cyan (blue) ink cartridge. If this is not a new cartridge, you might have to replace it. If this is a new cartridge, try following these steps.
1. Unplug the power cable.
2. Remove all 4 ink cartridges.
3. Close the ink cover
4. Plug the power back in.
5. Wait for the machine to warm up and tell you that the ink is empty.
6. Reinsert all 4 ink cartridges.
If you keep getting the same message you should try another cartridge. You can put the yellow cartridge in the blue spot to see if you get the same message. If you get the same message then the machine is broken. If you get a new message then the cyan cartridge needs to be changed.
Thanks,
Pat
Nov 09, 2010 | Brother DCP 130C All-In-One InkJet Printer
Keeps saying insert colour cartridge when we have just bought a new cartridge of correct spec. Says incorrect colour cartridge installed.Impossible to get past!!!
Hi,The most common reason for missing or incorrect colors is a print cartridge with one of the following problems:
  • One or more of the ink colors is empty. The black ink and all three colors of ink in the tri-color cartridge must be available or colors will be incorrect or missing. Under normal usage, the print cartridge will run low on one color of ink shortly before all ink colors are emptied.
  • The protective tape is not removed from a new cartridge.
  • Contacts on the cartridge are not making proper contact with the print carriage.
  • The cartridge is remanufactured or refilled.
  • The cartridge is defective.
Feb 14, 2010 | HP PSC 950 All-In-One InkJet Printer
Office jet 5510 keeps saying wrong black cartridge.
Look on the right side where the cartridge goes, if the spring on the right is hanging loose it might have poked a hole in the ribbon cable at the rear near the contacts. If so it's time for a new printer, if OK, check the exp. date on the ink cartridge and if it's been refilled or a generic ink you may just need another one.
Jan 30, 2010 | Office Equipment & Supplies
I don't know how to change the ink bought this printer from a guy at work no manual
Lift the scanner cover from the right-hand side of the MFC until
it locks securely into the open position.
If one or more ink cartridges are empty, for example Black, the
LCD shows Ink Empty Black and Cover is Open.
Pull the ink cartridge hook toward you and remove the ink
cartridge for the color shown on the LCD.
Open the new ink cartridge bag for the color shown on the LCD,
and then take out the ink cartridge.
Remove the cartridge covers.
Each color has its own correct position. Keep the ink cartridge
in an upright position when you insert it into slot. Press down on
the ink cartridge until the hook snaps over it.
Lift the scanner cover to release the lock. Gently push the
scanner cover support down and close the scanner cover.
If you replaced an ink cartridge while Near Empty was
displayed on the LCD, the LCD may ask you to verify that it was
a brand new one. Example: Did You Change Blck? 1.Yes
2.No. For each new cartridge you installed, press 1 on the dial
pad to automatically reset the ink dot counter for that color. If the
ink cartridge you installed is not a brand new one, please be
sure to select 2.
If you wait until Ink Empty message is displayed on the LCD,
the MFC will automatically reset the ink dot counter.
If the Install message is on the display after you have
installed ink cartridges, check that the ink cartridges are
installed properly.
Hope that helps you!
Aug 12, 2009 | Brother MFC 420CN All-In-One InkJet...
Changed black ink cartridge and now the carriage won't slide-just keeps hitting something that stops it right where the carriage goes to change ink cartridges. mrsgrdng8
It sound like you may not have gotten the cartridge installed correctly. Remove and re-install the cartridge and see of the problem persists. If it does remove that cartrigde and install the old one and check again. This will determine whether the problem is with the printer or the new cartridge
Apr 25, 2009 | HP Officejet 5610 All-In-One InkJet...
Changed the ink cartridge but it still says put in cartridge
If you are using a generic cartridge it very well could be the problem. Because some manufacturers have a chip in the cartridge that feeds information to the printer.
With a generic cartridge this chip will sometimes malfunction or have not been reset correctly (if it is a refill). If you can try returning the cartridge or exchange it. Give it another go and see if a new cartridge will work for you.
Mar 31, 2009 | Canon MultiPASS MP370 All-In-One InkJet...
I just installed a new black ink. The error message keeps on saying wrong color cartridge installed. I replaced with the correct one for my officejet v40. Black 15.
did you try changing the color cartridge too? I had problems with ink cartridges that were not HP cartridges.( not made by HP but some other co.)
Dec 05, 2008 | HP OfficeJet V40 All-In-One InkJet Printer
DCP-130C COLOR INKJET
When inserting a new cartridge, you may receive a prompt
"The installed ink cartridge differs from the original ink cartridge for the printer. Your printouts may be different from those printed using original ink cartridges. Do you want to continue using the currently installed ink cartridge?"
If you click Yes, printing will continue. If you select No, you will be prompted to change the cartridge. Manufacturer prompts may vary.
Nov 21, 2008 | Brother MFC 420CN All-In-One InkJet...
Re install ink
I know this is a dumb question but did you remove the tape off he bottom of the ink cartridge? Also sometimes if you are using a generic ink cartridge the machine may not recognize it. Make sure the cartridge is seated in properly and that it is in the correct location. (not color spot). Hope this helps. John
Sep 07, 2007 | Brother IntelliFAX 1940CN Plain Paper...
46 people viewed this question
old marine
old marine
