Question about Linksys Wireless-G WRT54G Router
Connection I have a new internet service with comcast, the router says I am connected but it won't load any pages and says it's not connected. Are there any settings that I need to change? Also when I go to the router settings page I have to have a password and I forgot it, how do I do a complete setup with this router?
    Genius:
  • 1,269 Answers
Using the main computer, open your Internet Explorer and on the Address Bar type http://192.168.1.1
It will prompt your for username and password. By default leave it blank on username and type admin on the password
Under SETUP tab, click the sub-tab MAC ADDRESS CLONE
Click on ENABLE and click the button CLONE YOUR PC's MAC then click on SAVE SETTINGS at the bottom.
Nowpower cycle your devices. Turn off router first and then modem. Waitfor 30 sec. Turn on modem first, wait for lights to stop blinking thenturn on router.
That's it. You should be able to share internet on all your computers that are connected to the router.
Posted on Aug 08, 2008
Connecting MacBook or NetGear Router to Comcast
As a Comcast tech I assure you there are no special protocols used on a standard residential installation. There should have been nothing the tech downloaded to your pc most especially an executable file. I would assume he or she was making sure you were able to get to the customer installation page before they left. However if you have a router that the ports are not functioning on you are most welcome to have one shipped to your home for replacement. The wifi key provided on the bottom of the router is case sensitive most generally all in caps. If you dont have a spare cat5/6 cord to see if thats the issue ask them to send one with the new modem. Comcast does not charge you a fee for a truck roll when its faulty eqt. of their own. I have installed hundreds of apple products including the ones you are referring to as well as netgear routers they all work with the gateway Comcast provides the customer. Now if you want there is a tiny factory reset pin button at the very top of the gateway in the back you will need a paper clip to push it in. Hold it in there about 10-15 seconds and the gateway will reboot and return its setting to factory spec. try that first before calling customer service.
Jan 07, 2013 | Comcast XFINITY
Cannot contect to apache through wrt54g
Highly unlikely. That would block all HTTP sites that use Apache. Even then, how would they distinguish one web server from another type. Your error is based on a specific site, or all internet if Comcast does not show their splash page saying it can't reach a specific site.
Dec 04, 2012 | Linksys Wireless-G WRT54G Router
I need a simple set-up manual for model # WRT54GS router
Your Internet service provider is comcast cable company.
You need to open the setup page of the router and change the Internet connection settings manually.
Connect the computer to the router and modem to the router.
Open the setup page of the router using 192.168.1.1
Click on MAC address clone. Enable it and click save settings.
Power cycle the router and your main computer will be online.
Then you can change the wireless settings manually.
Click Linksys router setup steps
Jan 04, 2012 | Linksys Wireless-G Broadband Router
I own a regular MacBook and it's about a year and a half old. I recently moved into a new apartment and established a new wireless network through Comcast. They gave us a modem/router combo for our...
Hello Jodu,
Please check the internet settings of the Lan connection in the Mac Book. May be there is IP Address or DNS settings is installed in your Mac Book which are stopping the wireless network services. Please check the IPV4 settings in the Lan or wireless connection properties.
Jun 03, 2011 | Apple MacBook Mac Notebook
Moved router to connect directly to the Comcast modem that also provides VOIP. Comcast activated modem and internet works when computer is connected directly to Comcast modem. Router does not connect to...
Your ISP should have given you the following information...
Static IP, Internet IP Address, Subnet Mask, Gateway, Static DNS 1-3.
With that information at hand, follow tis link to the router user manual and go to Page 11 of the manual to go through the step by step process of setting the router up for an internet connection.
http://downloads.linksysbycisco.com/downloads/WRT54GX2v2_ug,1.pdf
Nov 26, 2009 | Linksys WRT54GX2 Wireless-G Broadband...
When router is connected to D-link modem, no internet service for Macs or PC through Comcast. Had router tested at Apple store, and it tested fine. Comcast says it is a "router problem" but this occured...
Try running this test... I got it from a Comcast technician who came out when I had same problem.
Look for any failures or anomolies. Look at the signal page and check to make sure the signal to noise ratio is in the 30's or low 40's. If higher, call Comcast and tell them.
http://192.168.100.1/index.htm
Nov 09, 2009 | Apple AirPort Extreme Router
Internet connection issue. Is it setup or internet service
The problem would be comcast. Your connections are setup correctly. The modems do not control the internet traffic flow, they are made to produce maximum flow.
If more people use the internet, the less flow it will have.
Check all internet options settings, and make sure EVERTHING is set to automatic
Jun 06, 2009 | Arris SURFboard SB5120 Modem
I cannot connect with linksys wireless router
From your description, you appear to be connected to the router fine.
Try powering down the modem from Comcast for about 2 minutes then power it back up. If it doesn't come back, call Comcast service as it is likely on their end.
Hope this helps.
Dec 12, 2008 | Linksys Wireless-G WRT54G Router
I am getting a connect to belkin54g mesg. when I have comcast service. Why?
This is a message from your router and not from comcast service.
Sep 25, 2008 | Computers & Internet
Became new customer to comcast-got the bundle package, internet,phone,cable. Voice overlay modem to accomodate internet and phone lines. Did not use their wireless router-using exsiting router D-Link model...
Hi jad123,
I am sorry to learn about the problems you are experiencing with your service.
I will be happy to reach out to my contacts to assist you in resolving this issue. Please feel free to contact me so that I can get more information from you.
Thanks in advance!
Mark C.
Comcast Executive Offices
We_Can_Help@cable.comcast.com
Apr 10, 2008 | Computers & Internet
Linksys Wireless-G WRT54G Router Logo
59 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
