Question about Optus FACSys 4.x for PC
FACSYS 4.x Partial Pages
Currently utilizing version 4.8. Occasionally, we are informed that recipients are only receiving partial faxes? It does not happen consistently.
Any hints at where to begin to look for a solution?
Some faxes won't send. Recipient will recieve a partial page and then blank pages. Then my machine will tell me there is a "remote fax error". All other functions work great. I use the phone...
The problem could be to the transmission signal. Try to set your Fax Send Speed to 9600 bps. On your printer operator panel, press Setup > Fax Setup > Dialing and Sending > Max Send Speed > select 9600. Hit Ok to save the setting.
Try to send a fax again to verify that the problem is fixed.
Sep 13, 2011 | Lexmark Prospect Pro205 Wireless...
I can not receive fax
A partial reset of the product returns all fax settings to the default values. CAUTION: Performing a partial reset may remove all speed dials and other fax settings. It might be necessary to reset the language and country/region settings after the partial reset is complete. Perform a partial reset only as a last resort.
  1. Disconnect the power cord from the back of the product.
  2. Wait 20 seconds and then press and hold # and 3 on the product control panel.
  3. Continuing to press # and 3, reconnect the power cord to the back of the product.
  4. Release the buttons when the product turns on. The product resets to factory defaults.
  5. Try to send a fax again.
    • If the HP fax sends a fax, the issue is resolved.
Nov 24, 2010 | HP OfficeJet 6210 All-In-One InkJet...
I have a Brother MFC-7220 fax machine. When I fax I get "check readability of transmitted pages" errors. The receiver of the fax is only getting partial pages of the fax. I have had local and...
It is cheaper to use online fax service compared to the conventional fax machine. This way is more flexible as well because you can send and receive faxes anywhere as long as you are connected to the internet. I use Popfax.com fax email service, and it's reliable.
Aug 20, 2010 | Brother Office Equipment & Supplies
Error 441 seems to take all pages but receiver get aapx. 1 paragraph & the rest is blurred - same incoming
This means that an error occurred during transmission after one or more partial pages were sent. The sending machine was unable to restart the control channel connection(handshake) before sending more data. This error typically occurs when the receiving fax disconnects after receiving part of a page. It can also be caused if the receiving fax is using a fax format incompatible with the HP fax (usually during color faxing) or the line speed drops to an unacceptable level.
Solutions
Check that the phone cord is plugged in correctly and is not cut, creased or damaged.
Make sure that the phone connection terminal box is not damaged and that the cable connecting to it is not damaged.
Try the fax at a different time when telephone line conditions have improved.
Oct 08, 2009 | HP OfficeJet d145 InkJet Printer
Recipient is receiving blank pages when I send a fax
The back-light has gone in the CCD _vharge coupled device) - It would be cheaper to just replace it mate.
Jun 29, 2009 | HP LaserJet 3150 All-In-One Printer
How do I fix an "error 442" on the fax part of my hp 6110 all-in-one
Per HP:
Definition
An error occurred during transmission after one or more partial pages were sent. The sending machine was unable to restart the control channel connection(handshake) before sending more data. This error typically occurs when the receiving fax disconnects after receiving part of a page. It can also be caused if the receiving fax is using a fax format incompatible with the HP fax (usually during color faxing).
Solution
Apr 19, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Laserjet 3330 is resulting in fax Comm Errors 327, 232, 442, 356, 421 Comm Error 327 is always with fax # 780.467.6516. i can not fax to this number and when i receive from it, it always prints a Fax...
232-A communication failure has occurred between the two machines.
327-*Reattempt the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
356-The remote user has pressed the Stop key, causing the session to be aborted.
442-An error occurred during transmission after one or more partial pages had been sent. The transmitting machine was unable to restart the control channel (handshaking) before sending more data. This error typically occurs when the receiving fax disconnects after receiving part of a page but can also occur if the receiving fax is using a fax format that is incompatible with the HP fax machine (usually during color faxing).
Aug 15, 2008 | HP Computers & Internet
Faxes are incomplete or non-existent for Panasonic KX-FPC166
check the cover if it has been closed properly, if not check the cover lock and hinges.
Jul 16, 2008 | Panasonic KX-FPC95 Plain Paper Thermal...
7310 faxing problems
Try to reset the printer.
Take out the power cable without turning it off and then press # and 6 and while pressing # and 6 plug the power cabel and keep pressing the buttons.
The unit will turn on and then turn off...release the buttons and then press the pwer button and turn it on.
Try to fax now.
Also open the adf cover and clean the roller and seperator pad.
Apr 04, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Optus FACSys 4.x for PC Logo
79 people viewed this question
Top Optus Computers & Internet Experts
gaucherre
ray gallant
ray gallant
Bill Boyd
Are you an Optus Computer and Internet Expert? Answer questions, earn points and help others
