Question about Sony KV-35S45 35" TV
Sony KV-34s25 Blicking light
I have a sony 32" TV that has a blinking light no video no audio can you please help?
  • tortuga00022 Aug 08, 2008
    Thank you for you quick reply. The model is KV-35s40 sorry i have two of the sam kind. and the light is always blinking.
    Thanks you!
  • tortuga00022 Sep 17, 2008
    does anyone might know what my problem would be?
    my model number is KV-35540 thank you.
    New Friend:
  • 10 Answers
Sony Blinking Codes
Many of the later model Sony TV's have a built in Self- Diagnosis function. If
the timer/standby indicator is blinking, this could be an indication of the
problem with the unit. The diagnostic blinking will occur automatically with no
action required by you to engage it.
The timing of the blinking you see would be as follows: two to eight blinks
(depending on the fault) about a third of a second apart, then pauses for 3
seconds, then the two to eight blinks about a third of a second apart again.
Here is a list of the problems that might have occurred indicated by the
number of blinks. The words in parentheses are those which you will see for
each of these faults on a diagnosis screen described later in this article.
Unit is dead and there are no blinks---Problem in the standby power
section. Might check fuse, R607, Q601, IC601, R612 and VDR601 (should
show open)
Continuous Blink Once A Second, No Pausing As Discussed Above---
No reply from the jungle IC301 (data bus is busy, shorted to ground or held
high), IK video path is defective.
ONE Blink--- not used for the self-diagnosis
TWO Blinks---B+ over current protection (OCP) , unit goes to the standby
mode then displays the 2 blink fault. Could be a short in the power supply of
any of the circuits.
THREE Blinks---B+ over voltage protection (OVP), unit goes to the standby
mode then displays the 3 blink fault. This is also a problem in the power
supply circuit, check T603 and R672.
FOUR Blinks---No Vert. Deflection (V STOP), Screen goes to a single
horizontal line then the video signal muted. Check IC1509, Q1505
FIVE Blinks---AKB circuit (AKB), the timer/standby indicator blinks for about
30 seconds then goes to the self-diagnosis function. Something is wrong with
the video. Check video out, Q705, 732, 761 and other components on the C
board, also check Q218, 219, 220 on the A board. Also unit be in IK blanking,
try turning up screen slightly.
SIX Blinks---No Horizontal (H STOP), no raster, goes to the blinking selfdiagnosis
function immediately. Check C515 & 516 and the jungle IC, IC206.
SEVEN Blinks---High voltage shutdown. The high voltage has exceeded 33k
and the unit goes immediately into safety shutdown. Check power supply
regulation and horizontal circuits.
EIGHT Blinks---Problem with the audio (AUDIO), unit goes to standby and
blinks the self-diagnosis code. Check IC406 audio amp, PS401 and 402.
Intermittent problems ?? This is a great feature. You can also bring up
these fault codes ON-SCREEN to see a list of the problem numbers with the
abbreviation of the problem and the number of times this problem has
occurred. This is slightly different than entering the service mode. To see the
diagnostic screen, Press the following buttons:
Display, Channel, 5, Vol Minus, ( Not plus ) then Power. This brings up
a screen with a list of the problems and number of times they have occurred.
Each of the problem names is abbreviated as, "OCP", "OVP", "V STOP", ETC.
We have repeated them in parentheses in the text for the "Blinks" described
above so you can correlate between the diagnostic screen and the blink
codes.
So, now that you know about these self-diagnostics, how do you use them?
Say that you have a set with a black screen. You see that the LED is blinking
4 times....This would tell you that you have no vertical and that is why the
video is muted. If it was blinking 6 times, you would know that you have a
horizontal fault.
It's not a sure cure, but it's a little better than a poke in the eye with a sharp
stick.
IMPORTANT: after you repair the unit, PLEASE clear the values on this
diagnostic screen. These codes do not reset themselves after the fault is
corrected, so if you don't clear them, you'll be seeing "old" fault codes the
next time you enter this screen.
Clearing is done by going into the service mode ( display, channel, 5,
volume plus, then power ) then press 8 and Enter, which of course returns
everything to the factory preset condition.
Posted on Apr 25, 2010
  • 4,234 Answers
We can help, but I need to know the count of the blinks. That count will indicate the circuit that is defective. Also, please confirm that the model number is: KV-34S25.
Thanks,
Dan
Posted on Aug 08, 2008
  • ABRsvcs Sep 17, 2008
    Sorry to bother you with questions, but I'm trying to narrow down the possibilities.
    When this happens do you have sound?
    Thanks,
    Dan
SOURCE:
Sony trinitron 32 inch television model no. KV-32FS13 doesnt have any video nor audio and standby light just blinks about 4 times
Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check for any loose sodering points at the vertical output section.
Mar 27, 2012 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My Sony Bravia KLV32S400A goes off and red light blinks 8 times
Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board.
Dec 06, 2011 | Sony KV-32S12 32" TV
Sony wega trinitron(1999) KV-36FV15 Moved tv now audio no video
Seven blinks, pause, seven blinks, etc. means "Horizontal deflection stopped" and indicates a serious problem, probably on the D or DZ board (whichever is applicable).
If this is the case, the TV will have to be serviced by a professional.
I hope this helps :)
Best Regards,
James
Jul 29, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Code to enter service mode
Forget the service mode. The tv power supply regulator has probably failed.
Oct 07, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony wega 32 inch
Hi if light blinks on any sony tv it the fallowing
1 screen adjustment in expensive repair you need a tv center
2 power supply problem fix is 85.00 to 120.00
3 flybak problem high voltage est 225.00
this will at least help you so you will not be taken advantage of when you call a service center
thanks DOCTOR VIDEO LEADINGEDGEREPAIRCENTER SINCE1987
Apr 16, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Blinking STANDBY Light front of Television
Hii...
Refere to Sony Blinking Codes :
5 Blinks ===> cause AKB circuit (AKB). Something is wrong with the video. check components on the C board, also check the A board. Also unit be in IK blanking, try turning up screen slightly.
Hope can solved the problem....
[Vrya]
e-mail : [email protected]
Mar 01, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
No Video or Sound - Red Stand By Light Blinks 6 Times
My book that i have with my tv says it is time to have it servicedby adealer sorry thats all it says
Nov 06, 2007 | Sony FD Trinitron KV-32HV600 32" TV
Sony FD Trinition WEGA KV-32fs120 32" (no picture)
If the standby light is blinking 5 times then repeating, it is likely a problem in your picture tube or related circuitry. Other possibilities include the "Jungle" IC which takes care of the video, chroma and deflection processes and is a bear to replace. Either way, it could be an expensive repair.
Feb 11, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony KV-35S45 35" TV Logo
235 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
