Question about Refrigerators
I have a side by side Admiral refrigerator. There is ice building up in the bottom of the freezer. There is also water leaking out from the freezer side of the appliance.
Check to see if the doors are aligned correctlly and closing properly .
Posted on Aug 08, 2008
My admiral model hmg-64184 is leaking water from the bottom of freezer
It sounds like you have a broken place in the door gasket that is allowing warm air to enter the freezer.
May 29, 2015 | Admiral 26 cu. ft. Side-By-Side...
I have an admiral fridge freezer model number GS2126CEDW.water keeps leaking from the front of the freezer and a build up of frozen water has accumalated at the bottom of the freezer.A person has advised...
hello again,
Sorry to hear that the drain is clear and not the problem, some of the other things that cause that water are;
Freezer door it curled up in the corners espicially on the hinged side so air is leaking in and condensating resulting in water
The tube that send water into the icemaker is partially frozen so when water enters the icemaker it's being sprayed and dripping to the bottom(if thats the case ice would probably be built up all over the freezer)
The door for the ice dispenser isn't fully closing and will cause condesation just like the door gasket would
Good luck,
Oct 12, 2011 | Admiral 26 cu. ft. Side-By-Side...
Hello i have an admiral fridge freezer model number GS2126CEDW.water keeps leaking from the freezer at the front left hand side.there is also a build of of frozen water at the bottom of the freezer.I have...
The most likely source of that water is a frozen/blocked drain for the defrost drain at the bottom of the freezer behind the back wall of the freezer.Its a fairly common problem so i have written this tip explaining how to clean that drain for the defrost.
Ice/Water dispenser not working correctly
it is a thermostat problem,,because of it heating is not done properly ..u should replace or fix it,,it is not a big amount....
thank u,,,
Jul 01, 2009 | Admiral 26 cu. ft. Side-By-Side...
Ice repeatedly forms at the bottom of the freezer compartment. Eventually it reaches the door and water leaks out. Signature Series Frostfree Model HMG51108
Your defrost drain line is frozen up.
Turn off fridge, remove bottom freezer drawers.
Remove visible ice.
Take a hair dryer and melt ice at the back of the freezer at the drain pan.
Pour a water and bleach mixture through drain hole.
This procedure could take a hour or more.
Feb 21, 2009 | Admiral 26 cu. ft. Side-By-Side...
What causes ice build up on the bottom of a freezer?
your drain is probably plugged so when the fridge goes on defrost the water has nowhere to go.After the defrost cycle when the frige starts to freeze again the water freezes up causing ice build up
Dec 18, 2008 | Admiral 26 cu. ft. Side-By-Side...
Admiral HMG 62163 water leaking internally & freezing in lower basket
good attempt, its actually a clogged drain thats backing up and your drain water is not able to leave refrig so it falls to bottom of freezer floor and eventually out the door. romve the items from the freezer and take the lower back wall off form inside, directly under the evaporator under all that ice there is a drain hole, youll need to clear that hole of iec( pouring boiling water down until you get a free flow of water then you can reassemble uint problem solved
Oct 25, 2008 | Admiral 26 cu. ft. Side-By-Side...
Ice build up on bottom of freezer
remove back panel inside freezer. you will see drain tray at bottom with a drain hole in the middle - this is blocked usually with ice. melt off with a hairdryer and follow up with hot water till water flows away freely
Sep 25, 2008 | Maytag MSD2732GR Side by Side Refrigerator
Is there ice build up under the bottom basket in the freezer??
sounds like the defrost drain is frozen up. especially since your cleaning up once or twice a day. simply defrost the drain and flush the drain line with warm water. you will likely have to remove the freezer cover inside the freezer compartment to do this.
if there is no ice build up under the baskets then its likely there is a leak in the water line for your water dispenser line that runs in the door. if thats teh case you will most likely need a service company to fix it for you..
Dec 19, 2007 | Admiral 26 cu. ft. Side-By-Side...
Refrigerators Logo
135 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
