Question about Boating
Wiring diagram for Die Hard 28 lbs thrust trolling motor
I was given a Die Hard trolling motor. The cover was taped on and when I opened it I found all the wires were unconnected. I connected it to a battery and the motor runs. There is a 3 way switch on the cover (Rev-Off- Forward). With the power connected, the motor does not run in Off. It does run in Forward and Reverse in the appropriate directions. There is a variable speed switch with a tiller handle with Off-High-Med-Low positions. The motor runs in what appears to be High even with the switch in the Off position. I have tried every wire combination but I can't get it to operate like it is supposed to. Any one have a copy of the wiring schematic for this motor? Again, it is a Die Hard 28 lbs thrust trolling motor. There is no label with a model or serial number. Any help would be greatly appreciated.
Thanks,
Dave Haralson
  • vast8fm Apr 17, 2009
    I have the same issue. I do not have a label with the serial number or model number
I have the same propblem, however the motor is the same serial number is 4885815 for mine, it is a 5 spead 1.5 horsepower foot contoller if you find the information please share with me,
[email protected]
Thank you
PS, on a sears craftsman almun I can take photos and aend to you if needed of motor,,
Thank you
Curtis
Posted on Apr 25, 2009
    New Friend:
Model #217592860
Posted on Nov 09, 2009
    Problem Solver:
  • 8 Answers
It's probably a Minn kota with a die hard label. Call Minn kota and ask them.
Posted on Nov 28, 2008
SOURCE:
Motorguide Trolling motor has low thrust in all five speeds
I have a 4 speed with 48 lbs of thrust. On mine, 1 through 3 will move me out pretty well, however, 4th is similar to an overdrive gear in a car or truck and is meant more for maintaining a speed with less draw on the amps.
I certainly wouldn't want to take off with it. I suspect it is the same with your 5 speed. The boat needs to be up to speed and then those two gears will maintain it, with 5th being optimal as far as low draw in amperage.
May 22, 2009 | MotorGuide STANDARD MOTOR REPLACEMENT...
Motor guilde lll trolling motor
I have a motorguide trolling motor model 2600 #s/n 19409 can't find out what thrust it is
Feb 15, 2009 | MotorGuide STANDARD MOTOR REPLACEMENT...
Replaced Motorguide Trolling motor switch ... same problem
Trolling motor runs on it's own when plugged in,speed adjuster won't control speed and 3 position switch doesn't perform either..please help. motorguide 74lb thrust.
Jan 14, 2009 | MotorGuide STANDARD MOTOR REPLACEMENT...
Need wiring diagram for a Minn Kota 50lb thrust "All Terrain" trolling motor
Call Minn kota, the number should be on the bottom of the head. They will e-mail it to you.
Oct 16, 2008 | Boating
Boating Logo
2,505 people viewed this question
Top Boating Experts
ray gallant
ray gallant
Andrew Taylor
Andrew Taylor
Tom Chichester
Are you a Boating Expert? Answer questions, earn points and help others
