Inspiron 8100 Won't turn on
Hi all,  I have a Dell inspiron 8100.  256 MB of Ram.  1ghz processor.  The problem is that it won't turn on AT ALL.  I have tried all of the other possible answers online.  Only one worked, but only for a day or two...  The problem is that when i press the power button, the light turns on for about 4 seconds then turns back off.  I have switched the ram in the slots.  (Put each one in the others spot) and it worked for about a day.  Then it started doing the light thing again.  I switched the ram again, and it didnt work this time.  Any help would be greatly appreciated.
  • jsc7911 Aug 08, 2008
    I tried your idea about pulling the battery.  I don't think its at all a memory factor anymore.  When i removed the battery and tried to boot on AC power, there was absolutely no light.  So i would think my power adapter is fried or something.  Possibly a dead motherboard...
    Genius:
  • 2,028 Answers
When switching the memory, did you try one chip at a time, or have you always had both in the machine? The reason I ask is that if one of the chips is bad or going bad, and you've always had both chips in, then by switching them you fooled the machine temporarily. Also, try removing the battery, and starting on AC only, Dell batteries are notorious for causing a no start when getting worn out. Let me know on these.
Posted on Aug 08, 2008
  • Ryan Rogers
    Ryan Rogers Aug 08, 2008
    O.k Since you've checked the battery and memory, and these aren't it. Then check the power supply with an ohm meter for the proper output. If you're getting the proper output, then it's going to be a problem with the power management system on the motherboard, and, unfortunately, the motherboard will need to be replaced in order to fix the prob.
Assassins creed 3 on dell inspiron 640m
CPU: 2.66 GHz Intel Core 2 Duo E8200 or 2.66 GHz AMD Athlon II X4 620 CPU Speed: Info RAM: 2 GB
Not enough RAM!
OS: Windows Vista (SP2) / Windows 7 (SP1) / Windows 8 Video Card: 512 MB DirectX 9.0c-compliant with Shader Model 4.0 or higher (GeForce 8800 GT or Radeon HD 4850) Sound Card: Yes Free Disk Space: 17 GB
Jan 11, 2014 | Dell Inspiron 640m Notebook
I get 7 short beeps when I turn it on, and the screen is black. It won't let me do anything to it.
It could be dangerous for your laptop or PC because if relates with your processor but this problem could handle normally if this problem seems with RAM. I hope that if you replace your RAM, the problem will be solved but if the problem persist then you will have to replace your processor.
Good Luck
Aug 14, 2012 | Dell Inspiron Mini 1012 Netbook...
How can I upgrade/improve the capabilities of my Inspiron 1200
The best and quickest improvement is to add more RAM. Add another 512 Mb of RAM. If you already have a 512 Mb of RAM module then add another 512 Mb RAM module. If your laptop has 2X256 Mb RAM modules then you need to remove these and insert 2X512 Mb RAM modules.
The reason why you have 504 Mb RAM is that the video card has grabbed 8Mb of RAM off the main memory.
May 21, 2010 | Dell Inspiron 1200 Notebook
I have dell inspiron 1545 intel media graphics accelerator 4 series chip set family. i cant play good games like crysis, mass effect, assasins creed etc. what should i do to play it. anyone please help me?
Minimum System Requirements
OS – Windows XP or Windows Vista
Processor – 2.8 GHz or faster (XP) or 3.2 GHz or faster* (Vista)
Memory – 1.0 GB RAM (XP) or 1.5 GB RAM (Vista)
Video Card –256 MB**
Hard Drive – 12GB
Sound Card – DirectX 9.0c compatible
* Supported Processors: Intel Pentium 4 2.8 GHz (3.2 GHz for Vista) or faster, Intel Core 2.0 GHz (2.2 GHz for Vista) or faster, AMD Athlon 2800+ (3200+ for Vista) or faster.
** Supported chipsets: NVIDIA GeForce 6800 GT or greater; ATI Radeon 9800 Pro (Radeon X800 Pro for Vista) or greater. Laptop versions of these chipsets may work but are not supported. Integrated chipsets are not supported. Updates to your video and sound card drivers may be required.
Recommended System Requirements
OS – Windows XP / Vista
Processor – Intel Core 2 DUO @ 2.2GHz or AMD Athlon 64 X2 4400+
Memory – 2.0 GB RAM
GPU – NVIDIA GeForce 8800 GTS/640 or similar
Apr 01, 2010 | Dell Inspiron 1545 Notebook
I want to upgrade my inspiron 1100 processor
To be honest, the Inspiron 1100 is probably not worth the effort and cost to upgrade
The fast is proc is a 2.4 GHz Pentium 4 CPU, max ram 1GB of RAM,
You can find several dell portables below $500
http://www.dell.com/us/en/business/notebooks/vostronb/ct.aspx?refid=vostronb&s=bsd&cs=04
http://www.dell.com/us/en/home/laptops_great_deals/fs.aspx?refid=laptops_great_deals&s=dhs&cs=19
Jan 30, 2010 | Dell Inspiron 1100 Notebook
Hi, I have a Dell Inspiron 6000 with 2 GB of RAM and 8 MB video m
The simple answer is you can't upgrade as the video and sound are on the same "card" which is built in to the mother board.
May 08, 2009 | Dell INSPIRON 6000 CENTRINO...
Inspiron 6400 notebook
There are two slots for memory on that laptop and it will take a maximum of 2GB of RAM. The memory type is 1.8-V SODIMM DDR-2.
The cover ont he bottom if the laptop is easy to access and add more memory.
Dec 31, 2008 | Dell Inspiron 6400 Notebook
Verify memory upgrade in a Inspiron 1200
Verify on the label of the the memory Dimm that you installed that it is PC2700 SDRAM.
Memory Upgrade for Dell Inspiron 1200 Laptop, the Dell Inspiron 1200 Laptop takes the PC2700 DDR SDRAM SODIMMs. Memory Type, and comes installed with 256 MB (non-removable) of Memory. You can upgrade your Dell Inspiron 1200 Laptop to up to a maximum of 1280 MB Memory, the system has 1 socket to install Memory, already with 256 MB (non-removable) standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
Standard Memory 256 MB (non-removable) Maximum Memory 1280 MB Memory Expansion 1 socket Memory Comments PC2700 DDR SDRAM SODIMMs. If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 27, 2008 | Dell Inspiron 1200 Notebook
Dell 5100 laptop memory upgrade
try removing it again power on then off. again put yr ram it should boot. less u want to may be remove the processor then put it back as well at times they could stop system from booting
May 23, 2008 | Dell Inspiron 5100 Notebook
Upgrade question...
the only way to up the processor speed is to replace it..
Mar 16, 2008 | Dell Inspiron 6000 Notebook
Computers & Internet Logo
327 people viewed this question
David Payne
David Payne
