1990 Porsche 911 Carrera Logo
Posted on Apr 18, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
1990 Porsche 911 Carerra 2 Targa (964)...car was shifing fine...now is stuck in second gear. Clutch will engage...but no other gear is selectable. ...no strange noises...just will not shift. ...possible linkage problem? How difficult of a fix is this?
Jonah Oneal
Level 3:
  • Porsche Master 14,092 Answers
  • Posted on Apr 18, 2011
Jonah Oneal
Porsche Master
Level 3:
Answers
14092
Questions
0
Helped
7241824
Points
44533
YEP SHIFT LINKAGE LOOSE OR WORN NEED ADJUSTMENT.ADJUST THE SHIFT LINKAGE BY POSITION THE SHIFT LEVER IN NEUTRAL .REMOVE THE REAR TUNNEL COVER IN FRONT OF THE REAR SEAT.PULL THE RUBBER DUST COVER FORWARD ON THE SHIFT ROD.LOOSEN THE CLAMP BOLT ON THE SHIFT ROD.MOVE THE TRANSMISSION SELECTOR SHAFT ALL THE ITS LEFT STOP,KEEPING IT IN NEUTRAL.WITH THE TRANSMISSION STILL IN NEUTRAL . MOVE THE GEARSHIFT ROD TO THE RIGHT TO ITS STOP.TIGHTEN THE CLAMP BOLT TO 18 FT LBS.TEST THE SHIFT LEVER PLAY SHOULD BE THE SAME IN ALL GEARS IN ALL DIRECTIONS.
Porsche 911 targa at idle it would spit and drop off but not stall .it drives and revs fine
It could be something simple like bad spark plugs, clogged air filter, or bad gas. Start troubleshooting there first and see if the problem gets any better.
Car was shifing fine...now is stuck in second gear. Clutch will engage...but no other gear is selectable. ...no strange noises...just will not shift. ...possible linkage problem? How difficult of...
check the gear oil in the transmission Porsche is notorious for trans problems, and it wouldn't surprise me if it was leaking. too low a fluid and it will not go into any gear but the one that was last selected.
95 911 wing is stuck in the up position
Hello there
Your problem could be the rear gear is broken.It is located on the left inside your tail under the plastic cover.To remove use phillips screwdriver and try to diconect the gear cable.If the wing goes down it is the gear.If not the gear try to lok for an relay which is on pass.side under the dash-behing knee pad.This relay controls the manual and an electric operation.
Part number 964 618 212 00
ivan
[email protected]
2helpful
2answers
What coolant should i use for 2000 porsche 911 996
when you refill completely you should only use a non ethylene glycol anti freeze......(VW do there own)
1helpful
1985 911 Porsche that first gear won't engage.
Hello there
you propably had this problem fixed by now.
The most problem with 915 transmission is that your 1st synchro ring is broken or the so called Doog teeth are gone ... the trany has to be fixed.
trubka
1helpful
1990 Porsche 911 Carrara 2 Targa. power window not working
YOU TWO WINDOWS NOT WORKING OR ONE OF POWER WINDOW NOT WORKING. IF YOU HAVE TWO WINDOWS NOT WORKING YOU SHOULD CHECK THE HUGE BOX. IF ONE WINDOW NOT WORKING YOU SHOULD FULL OUT WORKING WINDOW SWITCH AND REPLACE WITH NOT WORKING SWITCH. IF IT DOES NOT WORKING YOU HAVE POWER WINDOW MOTOR.
1helpful
2answers
Transmission problem. The clutch does not discriminate. If the clutch was the cause rthe symptom would be in all gears.
2answers
1984 911 Carerra - Ignition switch, Locks, ACC
Just replace the electrical part of the ignition,that is the first step
proporsche
2helpful
Cannot shift into reverse although forward gears all functional
have ur shift linkage bushings replaced....most likely thse are torn or completely broken .. this is common on these models..also on some vw's of the same years
Top Porsche Experts
ROBERT GARCIA
ROBERT GARCIA
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Porsche Expert? Answer questions, earn points and help others
