Question about Linksys Wireless-G WRT54G Router
How do I set up a MAC Address on a Linksys Wireless Router?
I'm trying to find a way to setup a Wireless Lan in my house, but found out that Comcast Cable Internet restricts you to one MAC address per connection. So when I try to use the Internet with other machines than the first one I connected, it doesn't allow the connection to go thru. THen I learned that you can get around this by setting up a Router with a MAC address, and which fools the Comcast Internet connection to thinking its a single computer. Then somehow by cloning the MAC address - you can get other computers connected to the Router to share the Internet connection.
  • janjakajan Aug 08, 2008
    THis is very detailed answer. Thank you!
  • Linksys Master
  • 6,487 Answers
You just need to access the Linksys router setup using http://192.168.1.1 then use admin for the password leave the username blank, then you should see there a Setup tab then there's also a sub tab that says MAc address cloen , just enable it then click on the button that says clone PC mac then save the settings and thats it how you do the cloning on..
Hope that helps........
Posted on Aug 08, 2008
    Master:
  • 555 Answers
Yes, this can be done easily.
  • Matt Jurach
    Matt Jurach Aug 08, 2008
    There is less "fooling" involved than you may think.
    Routers always come with their own MAC address. This is the MAC address (and the *only* MAC address) which Comcast will see. All of the computers which you connect to the router (both wired and wireless) have their MACs hidden from Comcast. The router, true to its name, takes over the distribution of data between Comcast and all computers on your network.
    The only time you need to "clone" the MAC address on your router is if Comcast *already" has an authorized MAC for you. Which, in your case, they do--it is the MAC of the computer that you are currently using.
    You can either:
    1. Call Comcast and have them change the MAC address to that of your new router, or
    2. Tell the router to use the already-authorized MAC address from your computer. Comcast won't see the difference, and you are all set.
    Here are instructions for MAC cloning on the popular Linksys routers. It is very similar for other models as well.
Can't connect to my linksys wrt54gx2 router and even when I do, it tells me there is an ip address conflict and disconnects me
try to connect using a LAN Cable (Wired) connection. and then try to access 192.168.0.1 you should be able to see wireless settings there.
IP address must not be the same with the IP Address of other computers in your house. look for the Range and Increase it so that the router could have a wider range of IP Address to choose from.
Oct 02, 2010 | Linksys WRT54GX2 Wireless-G Broadband...
Router does not show wireless light. I have reset it but can't access it with the setup wizard. Any suggestions?
* NOTE: If you tried to set-up the WRT-150N Router previously, but failed, with the Router ON, press the "Reset" button on the back panel and hold it down for 10 seconds, then release. This will reset the Router to factory settings and erase all previous data.
then do this :
1. Hook up the Linksys WRT-150N Router to the Modem via a LAN cable.
2. Hook up the Linksys WRT-150N Router to your computer via a LAN cable with the LAN cable in Port #1 on the Linksys WRT-150N Router.
3. Type http://192.168.1.1 in the address bar of your web browser.
4. Log-on to the Linksys WRT-150N Router with these log-on credentials:
Username: linksys (lower-case)
Password: admin (lower-case)
5. Click on the "Clone PC MAC Address" tab.
6. Click the "Clone PC MAC Address" button.
7. Click "Save", click "Continue".
8. Click the "Wireless Security" tab.
9. Choose "WPA2 Personal - TKIP/AES" for encrypted security.
10. Enter encryption password (passphrase).
11. Click "Save", click "Continue".
12. Exit the web browser.
13. Disconnect the LAN cable from the computer and Port #1 on the Linksys WRT-150N Router.
In about 5 seconds, your wireless connection should be up and running.
Sep 15, 2010 | Linksys Wireless-N WRT150N Router
Cannot get wirelss connection through my WRT160N wireless router. Was working and now not. I can get internet connection through the LAN ports so I know that the router is working with a fixed cable
by default ip address of linksys is 192.168.1.1
to star config you need to be connected with ethernet cord rj-45
or conenct via wireless by conencting to linksys on wireless
admin user: blank
admin pws: admin
*choose a protocol on your linksys router on internect conenction type:
check isp protocol :
dhcp: needs serail number of mac address
it picks up automatic
pppoe: needs username and pws from isp
*the ip address has to be diferent from the isp modem:
isp modem 192.168.1.1 linksys 192.168.1.1 incorrect
isp modem 192.168.1.1 linksys 192.168.2.1 correct
change the ip on lan settings on your router
*wireless: ssid by default is linksys
ssid: linksys
wep : none
to setup wireless
access the wireless basic
change the ssid to any network name
enable the wireless password
choose wireless security
enable wep key 10 digit hex pws
make shure you saved settings on every setting
May 04, 2010 | Linksys WRT160N Wireless Router
I cant get a wireless signal
The Linksys wireless router needs the wireless settings configured and then the wireless card in the computer with these settings so it can communicate with the wireless router.
To set-up and secure the wireless router from unauthorized access, follow these steps: -
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL IP address.
3. Enter the router setup, login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WPA2 (if not then WPA).
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router wirelessly.
Nov 14, 2009 | Linksys Wireless-G WRT54G Router
Have a linksys wrt54g ver.6 router. I can not get a signal to my laptop. Is their something I am missing?
The wireless settings of the Linksys needs to e configured and the wireless card in the computer needs to be configured with the Linksys wireless router's settings so it can communicate with the Linksys wireless router.
Nov 13, 2009 | Computers & Internet
How do i secure my linksys WRT 150N?
Nov 09, 2009 | Linksys Wireless-N WRT150N Router
Instalaletion instrution
To configure the Linksys wireless router and the wireless card in the computer, sollow these steps :-
192.168.1.1.
3. Enter the router setup, login and password Login = admin PW-admin
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router.
Oct 24, 2009 | Linksys Wireless-G Broadband Router
How to setup the Linksys Wireless-G Broudband Rauter
3. Enter the router setup login and password
6. Setup encryption key the strongest is WAP2
Oct 06, 2009 | Linksys WUSB54GSC Compact Wireless-G USB...
Arimex comcast router won't talk to belkin wireless g plus mimo router
Comcast has a little known "trick" that they use when setting up users. Here's how it works:
When Comcast first comes to setup your new cable modem service, they insist on connecting it to your computer and "testing" it. Most people think nothing of it, and that it's good customer service ...truth be told, what they are doing is attaching your computer's MAC address to that cable modem, so that you cannot create a wireless network. This is because they want you to pay them $150 to do this for you.
In this situation, since the modem is a modem/wireless router in one, my guess is that the MAC address on your machine now does not match the MAC address on the new router, which is what Comcast has stored in their database(s).
Try this: on your computer (while connected to the modem), perform a release on your IP address (start, run, cmd, then type "ipconfig /release"). Disconnect the ethernet cable from the computer. Turn computer off completely. Hold down the reset button on the cable modem until it performs a reset. Once it's back up and running, boot up your computer with the cable back in the ethernet port.
The cable modem should assign a new address to your computer. However, that may or may not work ...this is an easy workaround with a Linksys router, but not necessarily with the all-in-one devices.
Worst case scenario: contact Comcast and notify them that the new modem is not recognizing your computer's MAC address and that it needs to be updated in their system. They will scan your computer (through the telnet interface on your modem) and get your computer's MAC address, then (hopefully) make the necessary changes on their end.
After that, everything should work flawlessly. If not, insist on a Comcast tech to "fix" the service that you are paying for.
Good luck - hope this helps :)
Sep 29, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Linksys Wireless-G WRT54G Router Logo
49 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
mark
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
