Question about HP Office Equipment & Supplies
How to Remove Black Ink cartridge?? - HP Office Equipment & Supplies
  • 446 Answers
Simply slide back the cartridge towards you, be careful to do the same way as you have removed this when re-installing it back
Posted on Aug 08, 2008
I am having problem on how to change the ink cartrdges. I can't get it to go to the center to be able to change the ink. Pls. help
hi,
following images and steps may guide you.
first know the parts.
Tear open the black ink cartridge bag at the notch and remove the ink cartridge.
IMPORTANT: Insert the ink cartridge immediately to prevent any drying of the ink.
Remove and discard the orange cap.
IMPORTANT: Handle ink cartridge carefully to avoid ink transfer.
Insert the black ink cartridge into the printhead. User's
Press down on the ink cartridge until you hear it snap into position
Tear open the color ink cartridge bag at the notch and remove the ink cartridge.
Insert the color ink cartridge into the printhead
Press down firmly on the cartridge until you hear it snap into position
Close the printer access door.
regards,
cseian
Feb 16, 2011 | Kodak EASYSHARE 5300 All-In-One InkJet...
Replaced ink cartridge still shows ink low needs to be replaced but is printing? Can it be reset?
  1. Remove your current empty cartridge from your Dell printer. Turn on your printer and lift the cover and top half of the unit. You can suspend it in place by lifting the blue plastic lever and securing it to hold up the top of the printer. At this point the ink cartridges should move to the center of the printer and be easy to access. Follow the instructions locate on your printer to remove the cartridges. You can do this by pressing on the blue tab to remove the colored cartridge or the black tab to remove the black cartridge. Once you press the tab, the cartridge cover will pop open. Carefully pull out the exposed cartridge from it’s setting. Save the empty cartridge so it can be refilled.
    Remove the sticker from the newly refilled Dell ink cartridge. Follow the directions on the opened printer to insert the cartridge. Hold the cartridge so the writing is on the top and the ink spot is on the bottom. Gently push it into the opened setting until it is securely in place. Close the cover of the cartridge holder by pressing down on it gently until it clicks into place. Remember that the black cartridge goes into the black setting and the color cartridge goes into the blue setting. Close the top of the printer. You will hear the ink cartridges move back into place.
  2. Test your newly refilled Dell ink cartridge and load your printer with paper.Print a document so either in color or black and white (depending on the type of cartridge you had refilled). Review your printed document to make sure the color is consistent and you are pleased with the outcome.
    Repeat whenever you run out of ink.
Apr 30, 2010 | Dell V305w All-In-One R840635AU InkJet...
I have a lenmarx x5150 printer and have no manual with instructions.How do I use it and replace ink?
  • Press the "Power" button to turn on your Lexmark
  • Step 2 Open the top portion of the printer to reveal the ink cartridges.
  • Step 3 Lift the gray plastic cover on the left. Remove the empty black ink cartridge. Next, lift the purple plastic cover on the right and remove the empty color ink cartridge.
  • Step 4 Remove the new black ink refill cartridge from its packaging. Tear the protective strip of paper from the cartridge's sensor. Now, remove the new color ink refill cartridge from its packaging and tear the protective strip of paper from the cartridge's sensor.
  • Step 5 Turn the cartridges so that you can read the label. This is the way the cartridges should face when being put into the printer.
  • Step 6 Slide the black cartridge into the slot on the left side and push it down. Slide the color cartridge into the slot on the right side and push down.
  • Step 7 Push the gray plastic cover down over the cartridge until it clicks closed. Push the purple plastic cover down over the cartridge until it clicks closed.
  • Step 8 Close the top portion of the printer. Your new ink cartridges are installed, and your printer is ready to use.
Nov 19, 2009 | Office Equipment & Supplies
Where do you insert the ink cartridges on lexmark x4650
These are the instructions for X2500 Printer
1.Press the "Power" button to turn on your Lexmark X2500 3-in-1 printer.
2.Open the top portion of the printer to reveal the ink cartridges.
3.Lift the gray plastic cover on the left. Remove the empty black #28 ink cartridge. Next, lift the purple plastic cover on the right and remove the empty color #29 ink cartridge.
4.Remove the new black #28 ink refill cartridge from its packaging. Tear the protective strip of paper from the cartridge's sensor. Now, remove the new color #29 ink refill cartridge from its packaging and tear the protective strip of paper from the cartridge's sensor.
5.Turn the cartridges so that you can read the label. This is the way the cartridges should face when being put into the printer.
6.Slide the black #28 cartridge into the slot on the left side and push it down. Slide the color #29 cartridge into the slot on the right side and push down.
7.Push the gray plastic cover down over the #28 cartridge until it clicks closed. Push the purple plastic cover down over the #29 cartridge until it clicks closed.
8.Close the top portion of the printer. Your new ink cartridges are installed, and your printer is ready to use.
Oct 25, 2009 | Lexmark X2500 All-In-One Printer
Check Black Ink blinking...???
Remove the ink cartridges
Remove the printhead
Close the access door w/o anything in the printer
wait for a few minutes
Install the printhead only
install the color ink cartridge
install the black ink cartridge
if the error still there ( Repeat the cycle 5x)
or go to www.kodak.com/go/itg
Mar 24, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
New Cartridge error message
Follow the steps below to remove and replace the empty ink cartridge.
  1. Turn the printer on.
  2. Open the ink cartridge door. Figure 1: Opening the ink cartridge door c00819080.gif
  3. Squeeze the gray tab below an ink cartridge slot to release the gray latch and then lift the latch. Figure 2: Lifting the latch c00819081.gif 1 - Ink cartridge latch for the black ink cartridge 2 - Ink cartridge latches for the color ink cartridges
    NOTE: Theink cartridge areas are color-coded for easy reference. From left toright, the ink cartridges are black, yellow, light cyan, cyan, lightmagenta, and magenta.
  4. Pull the ink cartridge toward you out of it's slot to remove it. Figure 3: Removing an ink cartridge c00819082.gif
  5. Remove the new ink cartridge from the packaging.
  6. Hold the ink cartridge by the handle and then slide the ink cartridge into the empty slot.
    NOTE: Makesure that the ink cartridge is inserted into the slot that has the sameshaped icon and color as the ink cartridge. The copper-colored contactsshould be facing the printer as the ink cartridge is inserted. Figure 4: Inserting an ink cartridge c00819083.gif
  7. Press down on the gray latch until it clicks into place. Figure 5: Closing the gray latch c00819084.gif
  8. Repeat steps 3 through 7 for each ink cartridge that needs to be replaced.
    NOTE: All six cartridges must be installed. The printer will not work if an ink cartridge is missing.
  9. Close the ink cartridge door.
after Doing this all Follow the next step :-
Please Try This, I am sure it is going to workout.
Resetting the All-in-One
Press the On (fa37665.gif) button to turn off the unit.
  • Disconnect the power cord from the back of the unit.
  • Connect the power cord to the back of the unit.
  • Press the On (a477fdf.gif) button to turn on the unit.
Oct 21, 2008 | HP Photosmart C5180 All-In-One InkJet...
How to change black color inkonHp2175all in one
Supported HP ink cartridge part numbers The HP PSC 2100, 2170, and 2200 all-in-one series products use the ink cartridges listed in the table below. The HP 58 tri-color photo ink cartridge replaces the black ink cartridge for six-ink photo printing. Ink cartridges Part number HP 56 black ink cartridge (19 ml) C6656A HP 57 tri-color ink cartridge (17 ml) C6657A HP 58 tri-color photo cartridge* (17 ml) C6658A HP 27 low capacity black ink cartridge (10 ml) C8727A HP 28 low capacity tri-color ink cartridge (8 ml) C8728A * Replaces the black ink cartridge for six ink photo printing and includes cartridge holder. Replacing the ink cartridges The power must be turned ON to the all-in-one or the print carriage will not come to the center.
  1. Locate and raise the print cartridge access door on the front of the unit, just above the output tray. The print cartridge carriage will move into the middle of the access area. Figure 1: Raising the front access door and the ink cartridge latches c00224418.jpg
  2. Press down lightly on the top of the ink cartridge latch of the ink cartridge to be replaced and then pull the lower section of the latch toward you to unlatch the ink cartridge.
  3. Grasping the sides of the ink cartridge, pull the cartridge toward you to remove it as shown in Figure 2. Figure 2: Removing the cartridge after raising the latch c00224419.jpg
  4. Remove the replacement cartridge from its packaging, and touching only the black plastic, gently remove any tape covering the nozzles. Do not touch the gold-colored contacts. Figure 3: Removing the protective tape c00224420.jpg
  5. Holding the ink cartridge with the printed label up, slide the cartridges one at a time into the print carriage as shown in Figure 4. The black ink cartridge (HP 56 or HP 27) goes on the right side (with the gray latch) and the tri-color cartridge (HP 57 or HP 28) goes on the left side (with the blue latch). If the optional photo cartridge (HP 58) is installed for six-ink photo printing, it is installed in place of the black ink cartridge. Figure 4: Inserting the cartridge c00224421.jpg
  6. Place your hand on the latch as shown in Figure 5, with the thumb pulling the end of the latch toward you. While holding the end of the latch out, press down on the top of the latch until it stops and then release the lower portion of the latch with your thumb so that it catches under the tabs. Do not force the latches into place or damage to the unit might occur. Close the all-in-one after latching the ink cartridges in place. Figure 5: Latching the ink cartridges in place c00224422.jpg
  7. Close the print cartridge access door.
  8. A message will appear in the front panel display requesting that the ink cartridges be aligned. Press ENTER on the front panel to start the cartridge alignment. Two pages will print. Following the instructions printed on the second page, place the first page on the scanner glass in the lower-right corner and then press ENTER to finish aligning the cartridges. Remove the page from the scanner glass when complete.
Storing the option photo printing cartridge while not in use The optional photo print cartridge (HP 58) that may be purchased separately for six-ink photo printing includes an ink cartridge protector. The protector is designed to keep the photo cartridge from drying out when it is not in use and for holding and protecting the black cartridge when the photo cartridge is in use.
  • To insert a cartridge into the protector, slide it into the protector at a slight angle until it snaps in place.
  • To remove a cartridge from the protector, push down and back on the top of the protector to release the cartridge and then slide the cartridge out of the protector.
Figure 6: Inserting and removing ink cartridges from the ink cartridge protector c00224423.jpg Fixing error messages that appear after changing a cartridge After inserting the cartridge, one of the following messages appears:
  • Check the black (or color) cartridge
  • Replace the black (or color) cartridge
  • The wrong black (or color) cartridge is installed
These messages indicate that the ink cartridge is not making good electrical contact, is bad, or is the wrong cartridge. Complete the following steps to diagnose and correct the condition:
  1. Open the front of the unit to access the print cartridges (as shown in Figure 1).
  2. Remove the ink cartridge indicated in the message and inspect it.
  3. Verify that it is the correct part number and if it is, reinsert it.
  4. Close the lid to see if the problem is corrected.
  5. If the message is still displayed after a few seconds, remove the ink cartridge again.
  6. Unplug the power cord from the back of the unit.
  7. Clean the electrical contacts on the ink cartridge with a soft clean cloth, slightly dampened (not wet) with clean water. Each contact is very small and shaped like a rounded square. Figure 7: Cleaning the cartridge contacts c00224424.jpg
  8. Inside the HP all-in-one product, clean the contacts in the print carriage (the cartridge holder) with a clean cotton swab slightly dampened with clean water. Allow them to dry for five minutes before reinserting the cartridge(s) and turning on the printer. Figure 8: Contacts to be cleaned c00224425.jpg
  9. If the problem remains, replace the ink cartridge.
  10. If the problem still exists after trying all of the steps above, contact HP for assistance.
Oct 13, 2008 | HP Office Equipment & Supplies
Black ink not printing
Having had the same problem on my 425cn Brother with the black ink, I'm told that the solution is hot water. I goes something like this: remove cartridge, place in container with hot water for a while, remove allow to dry completely, replace, perform clean cycle and print test page. Apparently it's imperative to dry completely and stand cartridge upright. The warm water thins the ink, and remove (apparently) blockages. I cannot verify that this works, but will try it this weekend and let you know! If the housing that the ink cartridge can be readily removed, take that out and clean in warm water. Again dry very well before returning. Be care full that ink becomes runny and may leak out of cartridge and make a mess - so work carefully.
Feb 13, 2008 | Brother MFC-5840CN All-In-One InkJet...
41 people viewed this question
Seeker5211
Seeker5211
