Model# L37W698, Serial# J877C2NK7A000578 We purchased an envision TV from Staples 12/24/07 and in July something happened to the picture, on one side it has color stripes/lines on about a 4th of the screen. We looked in the book and there is no mention of a warranty at all and that is our first question. The tv is on the wall with the right size and weight mount. We need help, please. Thanks Larry Smith 5092460517 and we live in Soap Lake WA
  • larrynima Aug 08, 2008
    We called Staples first and are waiting for a manager to return our call. Thanks
  • 4,234 Answers
Call Staples. Most sets carry a 1 year warranty. This could be as simple as poor connections inside the set, but opening up the set will VOID the warranty. Check with Staples first. If there is no warranty, update this and we'll look further for a solution.
Posted on Aug 08, 2008
Envision L37W698 tv
Could be either the main or power supply
Feb 05, 2018 | Televison & Video
My TV model l37w698 envision has picture but no sound it did for a little bit but now no sound comes out. Does anyone knows whats the issue.
Check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Pull up older posts. Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jan 12, 2017 | Envision Televison & Video
I own an envision flat screen tv L37W698. I was getting no sound unless I left it on for about 20 min. Then turned it off and back on immediately. Now that doesn't work. I get a wonderful p
Check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Nov 26, 2014 | Envision Televison & Video
Envision menu lock
Refer its user manual for details. Try this link to download the manual. Envision L19W698 LCD TV User Manual
Feb 03, 2014 | Envision Monitors L19W698 19 in. LCD TV
Envision tv
simply has moisture issue..button should be cleaned or hit slightly the button..may be it will help
Dec 17, 2013 | Televison & Video
Envision tv L37W698
Try to use a different code for remote control, sometimes all buttons not working properly
Envision L37W698 LCD TV sound will not come on when turned on unless we turn it off & on a few times. Then once it comes on, sometimes when we change channels (DirecTV) it will go off again.
I would suggest unplugging set and the box you are using--let sit for a while with no power and plug back up----both the set and box will power up and try to reboot as issue may be related (most likely) to one of them..
Another simple test you can try first is see if this happens when a DVD etc is played--if it does not I suspect a glitch with your box or set.
May 27, 2012 | Televison & Video
I have a n envision 22" flat panel TV purchased
I don't think there is still warranty for this TV. Usually, warranty last for 1 to 2 years... In summary there is not warranty for this TV, it must have expired.
To further confirm, check the receipt of purchase. The warranty duration should be stated there.
I hope you understand the above....
Good luck.
Mar 19, 2011 | Envision G22LWK 22" LCD Monitor
My tv will not turn on, it turned itself off and I can't turn it back on, there is no response at all when I hit the power. The day it stop working it was a very warm day. model L37W698.
Possible that the TV has a failed power supply , so check the mains power supplywhich is a SMPS. Please checck this link below for some tips
If the power supply works and there is voltage to the processor , the set must trigger. if not check the mains board for dry solderings, burnt drivers /capacitors.
Feb 05, 2011 | Envision Televison & Video
Headphone Jack on Envision LCD TV
just bought a coby tf-tv2617 our cable company uses a unilersal remote ur2-cbl-cv02 where can i find the code to make them work
Dec 26, 2008 | Televison & Video
Televison & Video Logo
78 people viewed this question
Top Televison & Video Experts
