Question about Uniden TRU8885 Digital Answering Machine
Answering machine does not work for second number on our line
Hi:
We have a main number and a secondary number which according to telus is just a phone number which is distinguished by a different ring. When people call this second number they get a shrieking sound similar to when you phone a fax no. How can I get the answering machine to answer with the recording so people can leave messages when phoning this second number. I hope you can help!!
Sandra
  • Anonymous Mar 25, 2014
    when I call the phone, I can hear it ring in the phone I'm calling from , but the phone i'm calling does not ring.
Is there any chance that there is a fax machine or modem attached to this #?
Posted on Aug 22, 2008
Not receiving all incoming calls. Callers get "All circuits are busy" or "This number is no longer in service" when they call. Some calls do come through. We can call out.
My phone is from the same Panasonic line.
Since you can call out it seems to me that it is the phone company's error message..
"All circuits are busy" and "this number is no longer in service" are telephone company error messages.
Did you have this problem with other phones? Maybe you can take the phone to a friend's for family's home and try it there. If the phone is okay, call Telus back and let them know that the phone tested okay and ask what they are going to do to fix the problem.
Seems to me that their circuits are overloaded and they are blaming your phone because it is something they can't repair. Only fixed by them spending $$ to increase/ expand band width.
May 11, 2016 | Panasonic KX-TGEA20 Additional Digital...
My land lines are working but all my handsets say check tel line...no dial tone or response. Batteries are good according to tester. Anything I can do??
ck the red and green wire that goes to the system those 2 make the phones work just do the main main phone first , , it does not sound like the phones are broke you are not getting a dial tone due to no connection to the line itself
Dec 10, 2014 | Panasonic Kx-tga641m/kx-tga641 Cordless...
When telephone line is connected no dial tone,any number press ask by line,please check the number you dialled ,after some seconds the telephone line becomes disorder.
are you using a modem? do you have a fax machine? switch the fax off. if a modem is present the main phone must be connected to that modem and the additional phones place through out the house (using other phone jacks)
Jul 27, 2010 | Uniden 2.4 GHz Expandable Phone System...
How do I reset the fax machine to answer on my
Turn off auto receive and set to manual, or unplug phone line to fax when not in use. -Carl
Jul 14, 2009 | Brother IntelliFax-2820 Laser Fax
Fax and answring machine on same line
I assume you have distinctive ringing since both numbers are on the same line. According to the manufacturer's specs, the fax machine supports distinctive ringing. Set it up for the ring pattern assigned to the fax number and to answer on the first ring. Then it will pick up right away when someone calls the fax machine, and the answering machine will pick up the other number.
Nov 19, 2008 | AT&T (1718B) Digital Answering Machine
Uniden answering machine
Here is the manual.
As far as the transferring calls on a secondary line, use the flash button.
Sep 19, 2008 | Uniden TRU9480 Cordless Phone
NUMBER OF RINGS TO ANSWER FAX
The Rings to Answer setting is important if you have an answering machine on the
same phone line as the HP All-in-One, because you want the answering machine to
answer the phone before the HP All-in-One does. The number of rings to answer for
the HP All-in-One should be greater than the number of rings to answer for the
answering machine.
For example, set your answering machine to a low number of rings and the HP All-in-
One to answer in the maximum number of rings. (The maximum number of rings
varies by country/region.) In this setup, the answering machine will answer the call
and the HP All-in-One will monitor the line. If the HP All-in-One detects fax tones, the
HP All-in-One will receive the fax. If the call is a voice call, the answering machine will
record the incoming message.
To set the number of rings before answering from the control panel
1. Press Setup.
2. Press 4, and then press 2.
This selects Basic Fax Setup and then selects Rings to Answer.
3. Enter the appropriate number of rings by using the keypad, or press or to
change the number of rings.
4. Press OK to accept the setting.
May 14, 2008 | HP Officejet 4315v All-In-One InkJet...
Number of rings before answering system goes on
You can adjust the Answer Delay time by going to Menu then DTAD. Adjust the Answer Delay under this menu... 6 seconds per one ring.
If you have auto attendant set up to answer for you in a multiline system, set that delay accordingly. That will be the first system to pick up, You should set up one auto attendant for every voice line coming into your phones.
Dec 18, 2007 | Lands Phones
Uniden TRU8885 Digital Answering Machine Logo
78 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
