Question about Creda W100FW Front Load Washer
Door interlock Initial problem with door interlock. Had to slam door shut several times before machine would start but now it does not start at all and power indicator is off. Have now replaced the door interlock but no joy. Please advise before i call engineer.
  • Creda Master
  • 3,463 Answers
Probably blown a track on the timer pcb, you need to remove the timer to check for short circuit.
Posted on Feb 10, 2009
  • Benn Barker Sep 06, 2013
    Hi, I have the w
    Hi, I have the W200FW model. I have just put a new door lock on, I get a flashing light and cycles won't start. I've seen people write that the timer could be the prob. Is that the part that houses the dial for the different cycle options on the control board? If so, what has caused that problem? regards, Benn
Malber combo doesn't start
This problem is usually the front door latch "interlock" is not engaging. This is the safety device which keeps you from opening the door and pouring gallons of water on your feet. When you close the door, if the machine DOESN'T recognize it's closed - all electricity is cut off and the machine does nothing. If the machine DOES recognize the door is latched, the latch will lock and you can't open the door (for about 90 secs after you turn it off or unplug it). Does the door LOCK when it's closed? If not, just close it harder several times. A medium "slam" almost always takes care of a "sticky" interlock - and it doesn't hurt anything.
Aug 01, 2012 | Malber WD1000 Front Load Washer/Dryer
Dryer won't turn off
Relay stuck closed in control circuit, usually the door interlock. Slam the door shut a couple of times to see if it frees the contacts.
May 15, 2012 | Washing Machines
Indesit wil 153 door red led is flashing after I set washer settings, doesn't start cycle ?
The flashing light means that the machine thinks the door is not closed (The door lock switch is not activating). 99% of the time this is simply a sticky switch and the solution is to give the door a good firm slam shut (Don't get silly here, but it will take a pretty good "teenager slamming the bedroom door in a temper tantrum" type slam).
In the event that this doesn't work, then you're looking at a faulty door interlock switch. They're not that hard to obtain or fit if you're fairly confident. Drop me a comment back here and let me know how you get on. Happy to help further if the above hasn't allowed you to solve the problem.
Aug 15, 2011 | Indesit W 123 Front Load Washer
The machine is dead,nothing is happeneing,no lock door switch light,changed the fuse in the 13 amp plug????????
I have the same problem. It appears to be the interlock switch on mine. Had you had problems with the door not shutting properly & therefore not starting unless you slammed the door? If so could well be the same thing. The new piece cost less than £10.00 including P& P so worth a try.
Nov 01, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Must repeatedly slam top loading door shut for machine to start
on the inside of the lid there is a lid switch hole that a plastic tab goes down through the switch could be bad or the screws holding the switch in could be lose or broken
Mar 28, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Bosch WFK 2401 Need to slam door several times to lock door
Sounds like you need the electric "door interlock" replaced. It is a simple matter of seperating the front of the machine enough to unplug the interlock mechanism, remove the two screws holding the mechanism in place and remove it from the back, reverse the procedure to install the new "updated" replacement part (- Bosch #170935 btw. about $37.00 from Sears). - time: approx 1/2 hour if you aren't mechanically inclined.
Jan 24, 2009 | Bosch Classixx WFL 2462 Front Load Washer
Ariston washing machine
Door not shut Check that the door is properly shut.Faulty interlock A faulty interlock might not allow the door to shut properly. Find your door interlock here and replace, or contact a qualified repairer.
No power Check the flex, plug wiring, fuse and mains supply for faults.
Faulty on/off switch Check the power light if fitted. Replace your on/off switch.
Water supply disconnected or off If a washer dryer cannot load water it cannot start a wash cycle. Check water supply.
Nov 17, 2008 | Ariston Technologies AW125NA 13 lbs. Load...
Washing machine
Jul 23, 2008 | GE WDSR2080D Top Load Washer
Machine came up with E91 and then powered down
Feb 19, 2008 | AEG Lavamat 72640 Front Load Washer
Creda W100FW Front Load Washer Logo
200 people viewed this question
Top Creda Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you a Creda Washing Machine Expert? Answer questions, earn points and help others
