Question about Fargo Persona C11 Thermal Printer
Color Print quality has declined
When I compare badges I printed a couple of years ago to ones I print today there is a marked difference in the vividness of the colors. I have been dilligent in cleaning. Fargo Support had me calibrate the sensors but that made no difference. . Thanks for any help you can offer.
Gayle
  • 526 Answers
Try increasing the brightness level in your printer drivers. also the best cards to use are ones by fargo.
Posted on Apr 23, 2009
Replaced black ink cartridge, but now it only prints a very faint line, cant make out what is printing
Sir/Madam
If your printed pages have a horizontal line in the text or graphics (as shown in the illustration below) or blank text, some of the nozzles may be clogged and need to be cleaned
Go to Section 2 for instructions on how to print the Alignment Check sheet and adjust the print alignment.
Section 1: Checking the print quality and cleaning the print head
  1. Print a Print Quality Check Sheet.
    1. Press Menu.
    2. Press the UP OR DOWN ARROW key or the dial pad to choose Ink Management and press OK.
    3. Press the UP OR DOWN ARROW key or the dial pad to choose Test Print and press OK.
    4. Press the UP OR DOWN ARROW key or the dial pad to choose Print Quality/Alignment and pressOK.
    5. Press Color (Colour) Start. The machine begins printing the Print Quality Check Sheet.
  2. Closely examine the Print Quality Check Sheet. Each of the four colors is represented by a slanted square pattern made up of individual blocks. The colors should appear in the following order from left to right: Black - Yellow - Cyan - Magenta.
  3. Compare the print quality of the Check Sheet you just printed with the three examples listed below:
    (A) One or more complete blocks of colors are missing:
(B) Most of the short diagonal lines are missing from one or more color blocks:
(C)Some parts of the short diagonal lines are missing from one or more color blocks:
  1. The display will then ask you if the print quality is OK for black. Press the DOWN ARROW key or 2 to choose Nofor black with the problem.
  2. The display will then ask you if the print quality is OK for Color. Press the DOWN ARROW key or 2 to chooseNo for color with the problem.
  3. The display will then show Start Cleaning? Yes No.
    Press the UP ARROW key or 1 to choose Yes and the machine will start cleaning the color ink cartridges.
  4. When the machine completes cleaning the print head, press Color (Colour) Start. Another Print Quality Check Sheet will print.
  5. Repeat the cleaning and the quality check process following the Step 4-7.
  6. Compare the second or third Print Quality Check Sheet with the first one you printed in step1:
9. Compare the second or third Print Quality Check Sheet with the first one you printed in step1:
  • If the print quality on the first Check Sheet matched Example (A) or (B) and you do not see any improvement on the second or third Check Sheet, please contact Brother Customer Service from "Contact Us."
  • If the print quality on the first Check Sheet matched Example (A) or (B) and you see some improvement on the second or third Check Sheet but it's not perfect, repeat the cleaning and the quality check process three more times (totally five times). If you do not see any further improvement after that, please contact Brother Customer Service from "Contact Us."
  • If the print quality on the first Check Sheet matched Example (C) and you do not see any improvement on the second or third Check Sheet, repeat the cleaning and the quality check process three more times (totally five times). If you still do not see any improvement, please contact Brother Customer Service from "Contact Us."
10. Press Stop/Exit.
Section 2: Checking the Print Alignment
  1. Press Menu.
  4. Press the UP OR DOWN ARROW key or the dial pad to choose Print Quality/Alignment and press OK.
  5. Press Black (Mono) Start or Color (Colour) Start. The machine begins printing the Alignment Check Sheet.
  6. By reviewing this Check Sheet, you can determine if the alignment needs adjustment.
  7. Examine the 600 dpi and 1200 dpi test prints on the Alignment Check Sheet. If the number 5 sample of both the 600 dpi and 1200 dpi most closely matches the 0 sample, press the UP ARROW key or 1 to choose Yes.
    If one of the other samples is a better match for the 0 sample, press the DOWN ARROW key to choose No. The display will then prompt you to choose the sample that most closely matches the 0 sample for 600 dpi and then 1200 dpi.
  8. Press Stop/Exit.
If the print quality continues to be poor, go to Section 1 to clean the print head.
If your question was not answered, please check...
Improve poor print quality Brother
Or
If You Still need Brother Printer Help then I suggest You follow Us On For: Brother Printer Support
Oct 09, 2012 | Brother Ink for Dcp-6690cw and Lc-1100
When you change the ink cartraige and clean printer and test the colours the quality of colour is not good on the test! what do you segested i try beacaue the machine has been on its 100th clean and...
    2. Press the Ink or Ink Management key on the control panel.
    3. Press the up or down arrow key to choose Test Print and press OK.
    4. Press the up or down arrow key to choose Print Quality and press OK.
    5. Press Color (Colour) start. The machine begins printing the Print Quality Check Sheet.
    1. Closely examine the Print Quality Check Sheet. Each of the four colors is represented by a slanted square pattern made up of individual blocks. The colors should appear in the following order from left to right: Black - Yellow - Cyan - Magenta.
    2. Compare the print quality of the Check Sheet you just printed with the three examples listed below:
    3. The display will then ask you if the print quality is OK for black. Press the down arrow key or 2 or "-" to choose No for black with the problem.
    4. The display will then ask you if the print quality is OK for Color. Press the down arrow key or 2 or "-" to choose No for color with the problem.
    5. The display will then show Start Cleaning? Yes No.
      Press the up arrow key or 1 or "+" to choose Yes and the machine will start cleaning the color ink cartridges.
    6. When the machine completes cleaning the print head, press Color(Colour) Start. Another Print Quality Check Sheet will print.
    7. Repeat the cleaning and the quality check process following the Step 4-7.
    Jun 02, 2011 | Brother MFC 6490CW InkJet Printer
    My brother MFC 665CW printer shows a 4F error and unable to clean. How do I get to the head to clean it?
    Do the following to clean the print head:
    1. Press INK key on the control panel.
    2. Press the DOWN arrow key until CLEANING appears on the LCD.
    3. Press OK.
    4. Press the DOWN arrow key to select BLACK, COLOR or ALL depending on what you want to clean.
    5. Press OK.
    The machine will clean the print head. When cleaning is finished, the machine will go back to Ready automatically. If you are experiencing a print quality issue, we recommend you repeat the print head cleaning for each color showing an issue at least five (4) times.
    If you are experiencing a print quality issue and want to see if the cleanings are improving the print quality, print a Print Quality Check Sheet (PQCS) after the first cleaning and then print another PQCS after repeating the print head cleaning steps at least three (3) more times (4 total cleanings). You can then compare the two Print Quality Check Sheets.
    Do the following to print a Print Quality Check Sheet:
    1. Press INK key on the control panel. TEST PRINT will appear on the LCD.
    2. Press OK. PRINT QUALITY will appear on the LCD.
    3. Press OK.
    4. Press COLOR START.
    NOTE: The machine will generate the Print Quality Check Sheet (PQCS). On the PQCS each of the four colors is represented by a slanted square pattern made up of 96 individual blocks. The colors should appear (from left to right): Black - Yellow - Cyan - Magenta. Cyan is the light blue color and Magenta is the pinkish color.
    Feb 21, 2011 | Brother MFC-665CW All-In-One InkJet...
    Print head is not printing seems to be clogged from non-use. Have tried test printing through several new cartridges and still not working. Can the old - dryed ink be cleaned off of the print heads?
    Hi, below is from the brother website for your model. Very common for the ink heads to become clogged /dry out. You probably have done this but here it is anyway. your print head is part of the machine, so it will need to be disassembled to clean it, That can be very difficult. Try the following anyway, it might help you. also, you could try using a Q-Tip wet with vinegar water to get under to the bottom of the print heads, if you can get the head to move off its dock and then unplug it when its moved over. anyway here is the Brother link info (without pictures-see the link above if you need the pictures)
    • Print a Print Quality Check Sheet.
      1. ress the Ink or Ink Management key on the control panel of the machine.
      2. Press the up or down arrow key to choose Test Print and press OK.
      3. Press the up or down arrow key to choose Print Quality and press OK.
      4. Press Color (Colour) start. The machine begins printing the Print Quality Check Sheet.
    3. The display will then ask you if the print quality is OK for black. Press the down arrow key or 2 or "-" to chooseNo for black with the problem.
    4. The display will then ask you if the print quality is OK for Color. Press down the arrow key or 2 or "-" to chooseNo for color with the problem.
    8. Compare the second or third Print Quality Check Sheet with the first one you printed in step1:
      Press Stop/Exit.
    Aug 29, 2010 | Brother MFC-5460CN InkJet Printer
    My magicard alto prints fine except the color quality is not very great. when i use the color ribbon and print black letters with it the letters come out gray and not black and it has a problem making the...
    The printer driver must be set to print text with the K resin panel.
    If the text is part of a bitmap image and not a true-type font then it will print from the coloured panels and be dark grey.
    To create the correct green on the card you need to change the RGB values so it prints correctly but look wrong on the badge design program. Even different printers print the same colour differently.
    Jan 29, 2010 | Magicard Alto Card Printer
    Canon i950 printing many blank strips/areas where text should be
    I'm afraid it looks like the printhead is broken. A quick google sees them at about £80. Compare this to the price of a new model. I think 5-6 years insn't too bad though
    Mar 23, 2009 | Canon i950 InkJet Photo Printer
    Color laser printers. Costs for toner vs. initial costs for ptr
    Have you thought about having your printer cartridges refilled? There are huge savings to be made in doing so and the quality can be just as good as the original cartridges (depending upon the refiller). Another option would be for you to purchase an older color laser printer such as the HP Color Laserjet 4500 or 4550. I use one myself and couldnt be happier with it. And as its an older printer, you can get the cartridges relatively cheap.
    Jan 24, 2009 | Xerox 4500 Laser Printer
    Epsom cx3200 off brand ink refill
    Make sure the print head nozzles are not clogged. You may need to clean the print head. This unclogs the nozzles so they can deliver ink properly. Print head cleaning uses ink, so clean it only if quality declines.
    When you don't turn on your EPSON CX3200 for a long time, the print quality can decline. It's a good idea to turn on your EPSON CX3200 at least once a month to maintain good print quality.
    1. Make sure the EPSON CX3200 is turned on but not printing, and the Error light is off.
    If the Error light is flashing or on, you may need to replace an ink cartridge.
    2. Press the left Menu button on the control panel several times until you see Cleaning and then press the Copy button.
    Cleaning takes about 30 seconds, during which the EPSON CX3200 makes some noise and the Operate light flashes. Never turn off the EPSON CX3200 while the Operate light is flashing, unless the EPSON CX3200 hasn't moved or made noise for more than 5 minutes. setViewedFAQCookie(14082, 31605);
    Oct 02, 2008 | Laser 3115cn All-In-One Printer
    HP Color Laserjet 3500 Problem
    If you are sure the diagnostics show the colours correctly, one thing I would look at is to see if it had a colour profile set up for it.Don't know whether this printer normally has, if it has not I would suggest reinstalling the driver. To check - Start/Printers & Faxes/ Rt click on printer then properties, look under Colour management tab. Pete
    May 25, 2006 | HP Color LaserJet 3500 Printer
    Fargo Persona C11 Thermal Printer Logo
    156 people viewed this question
    Top Fargo Office Equipment & Supplies Experts
    Safe-Card ID...
    Are you a Fargo Office Equipment and Supply Expert? Answer questions, earn points and help others
