Question about Garmin GPS
Continuously has trouble finding satellites from switching on model no nuvi 200w
5 Suggested Answers
  • 9 Answers
SOURCE: Nuvi 200W GPS power supply will not stay plugged in
hpd367 - If your Garmin has died within a year then call them for an RMA number and they will repair/replace it.
Tel 0808 238 0000
Moscow Nell - I had the same problem and got an adaptor from Halfords for about £5.
Posted on Apr 04, 2008
mmorlan
  • 51 Answers
SOURCE: sesrching for satellites
Okay well have you tried to return the item and see about getting it exchanged for a new one and see if that one works, it's not uncommon for a product that goes down an assembly line to have a few of them that don't work. I would try there and if they don't do anything for you I would call garmin directly.
Posted on Apr 16, 2008
mastersaintx
  • 928 Answers
SOURCE: Map was deleted by mistake from nuvi 200W garmin GPS
Connect your Garmin to the computer. Go to http://www8.garmin.com/support/download.jsp then click on mapping updates
Posted on Aug 31, 2008
rehortonjr
  • 47 Answers
SOURCE: Garmin Nuvi 200W
Hi!
This link will let you download ALL the manuals for this Garmin unit, not just the quick start:
http://www8.garmin.com/support/userManual.jsp?market=4&subcategory=41&product=010-00656-10
I didn't convert it to a Tiny URL, so make sure the whole link shows in your browser.
I would certainly appreciate a FixYa rating from those of you looking for the library, should you deem it appropriate. Thanks!
Bob
Posted on Oct 23, 2008
Handy Mike
  • 6 Answers
SOURCE: Nuvi 200w
Found this thru Garmin support
Question: Why will my nüvi 2xx not find satellite signals?
Answer:
p>If your nuvi 2xx is not acquiring satellite signals, you may need to download and run our WebUpdater program.
Go to:
http://www.garmin.com/products/webupdater/
If you are still having issues after updating the software on your unit, you may need to do a full master reset. Please note that a master reset erases Favorites and waypoints. Before proceeding, you may want to back up information you want to keep.
To do a full master reset to the nuvi 200 series unit:
1. Turn off the device.
2. Place your fingertip or the eraser end of a pencil in the bottom right corner of the touchscreen.
3. Apply pressure in the bottom right corner of the screen.
4. While pressing down on the screen, power on the unit and continue pressing on the screen. A message displays to confirm that you really want to delete all user data.
5. Touch Yes.
6. Your unit restarts automatically. You must go through the set up procedure again.
Once you complete the reset, place the nuvi unit outside where it has a clear unobstructed view of the sky for 15-30 minutes. Keep it in a stationary position until it reacquires satellites.
Garmin 200w has trouble aquireing satellites?
Go to the Garmin dot com website and follow prompts to download the software and the firmware and software updates - they are free.
Jun 12, 2010 | Garmin nuvi 200W GPS Receiver
Hellio, my garmin nuvi 200 cant find a satellite,
I can help you fix your Garmin Nuvi 200W.
There are three steps to take to get your Nuvi running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
___________________
Nuvi 200 series manuals available here.
Mar 24, 2010 | Garmin nuvi 200W GPS Receiver
Garmin nuvi 200w not getting any signal....
I recommend trying the hard reset and the newest webupdater (March 31, 2010) and se if you get better results.
I hope that helps.
___________________
Feb 08, 2010 | Garmin nuvi 200W GPS
My garmin cant find satelite
Acquisition of satellites has been addressed in new firmware / system updates for the Garmin Nuvi 200W .
I hope that helps.
___________________
Nov 28, 2009 | Garmin nuvi 200W GPS Receiver
Trouble acquiring satellites
try the reset
Note: A master reset will erase all waypoints or favorites and will restore your unit to the default factory settings.
with the unit off, try pressing and holding your finger on the low right corner of the screen and slide the power switch to the on position until you see the message "confirm if you really want to delete all user data?" hit yes and let it restart. then it will set up the nuvi again, so follow the prompts.
if that fails, hook up the nuvi to the web updater and get the latest update
(actually i would do this either way)
bill
Sep 07, 2009 | Garmin nuvi 200W GPS Receiver
Loosing satellite signal
Acquisition of satellites has been addressed in new firmware / system software updates for the Garmin Nuvi 200W .
I hope that helps.
___________________
Aug 08, 2009 | Garmin nuvi 200W GPS Receiver
My garmin nuvi has trouble locating satellites and losing signals. What happened? It used to be much more reliable.
Acquisition of satellite speed has been addressed in new firmware / system software updates for the Garmin Nuvi 200W .
I hope that helps.
___________________
Jul 18, 2009 | Garmin nuvi 200W GPS Receiver
Trouble locating satellites
Hi, my name is Vince & i had that very same problem with my nuvi 200w, have you tried to update it on your pc ?, i updated mine after travelling down the motorway at 40 miles an hour thinking that their was road works after the sat nav told me. I also found that updating it seemed to increase the signal strength too, try it, it may solve your problem.
Apr 24, 2009 | Garmin nuvi 260W GPS Receiver
Nuvi 200w
Answer:
Go to:
5. Touch Yes.
May 20, 2008 | Garmin nuvi 200W GPS Receiver
Sesrching for satellites
Feb 26, 2008 | Garmin nuvi 200W GPS Receiver
GPS Logo
297 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
